Most of the time, after disconnecting from my printer, the connection process freezes on reconnect. From all outward appearances, it looks like a connection has been made (Terminal says it's connected and provides updates from the printer, temperature graph updates), but the state of the connection never updates. I can't start a print or control the printer.
Serial logs show that when the connection is successfully made, there is a handshake attempt after a connection attempt, a few GCODE commands are sent and the status is updated from "Detecting serial connection" to "Operational"
2024-01-25 18:42:33,264 - Changing monitoring state from "Offline" to "Detecting serial connection"
2024-01-25 18:42:33,475 - Performing autodetection with 7 port/baudrate candidates: /dev/ttyACM0@115200, /dev/ttyACM0@250000, /dev/ttyACM0@230400, /dev/ttyACM0@57600, /dev/ttyACM0@38400, /dev/ttyACM0@19200, /dev/ttyACM0@9600
2024-01-25 18:42:33,476 - Trying port /dev/ttyACM0, baudrate 115200
2024-01-25 18:42:33,498 - Connecting to port /dev/ttyACM0, baudrate 115200
2024-01-25 18:42:33,609 - Handshake attempt #1 with timeout 2.0s
2024-01-25 18:42:33,622 - Connected to: Serial<id=0x71a1f9a0, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2024-01-25 18:42:33,626 - Send: N0 M110 N0*125
2024-01-25 18:42:33,635 - Recv: ok
2024-01-25 18:42:33,667 - Changing monitoring state from "Detecting serial connection" to "Operational"
2024-01-25 18:42:33,710 - Send: N0 M110 N0*125
2024-01-25 18:42:33,792 - Recv: ok
2024-01-25 18:42:33,803 - Send: N1 M115*39
Safemode serial logs show that, during the failure, a connection was completed. However, there is no handshake attempt, and the status is updated from "Detecting serial connection" to "Connecting"
2024-01-25 18:43:40,992 - Changing monitoring state from "Offline" to "Opening serial connection"
2024-01-25 18:43:41,007 - Connecting to port /dev/ttyACM0, baudrate 115200
2024-01-25 18:43:41,031 - Changing monitoring state from "Opening serial connection" to "Connecting"
2024-01-25 18:43:41,036 - Connected to: Serial<id=0x6f0e6a48, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2024-01-25 18:43:41,588 - Recv: X:0.00 Y:220.00 Z:31.20 E:3670.10 Count X:0 Y:17512 Z:12543
2024-01-25 18:43:41,746 - Recv: Not SD printing
2024-01-25 18:43:42,615 - Recv: T:16.21 /0.00 B:16.51 /0.00 @:0 B@:0
2024-01-25 18:43:42,733 - Recv: Not SD printing
2024-01-25 18:43:43,734 - Recv: Not SD printing
2024-01-25 18:43:44,609 - Recv: T:16.24 /0.00 B:16.62 /0.00 @:0 B@:0
2024-01-25 18:43:44,733 - Recv: Not SD printing
2024-01-25 18:43:45,734 - Recv: Not SD printing
Refreshing browser: Still stuck on connecting
Opening WebUI in Incognito mode: Shows stuck on connecting.
Disconnect and reconnect: Off and on successes, mostly off.
Disconnect and wait for a few hours before reconnecting: 75% effective
Restart Octoprint: Connects on restart, if disconnected, won't reconnect reliably
Restart Octoprint in safe mode: Connects on restart, if disconnected, won't reconnect reliably
Restart system: Connects on startup, if disconnected, won't reconnect reliably
Power cycling the printer and reconnecting: (Just started trying this moments ago) seems to reliably connect....
Yes, problem persists
No, seeing exact same problem.
octoprint-systeminfo-20240125165725.zip (179.1 KB)
A failure captured in serial on safe mode
serial (1).log (3.1 KB)
A success on restart captured in serial logs, and a later failure on disconnect/reconnect on safe mode
serial (2).log (14.1 KB)
Syslog
OctoPrint Version: 1.9.3
OctoPi version: Build 2023.07.18.111854 with "webcamd", based on OctoPi 1.0.0, running on Raspberry Pi 3 Model B Rev 1.2
Ender 3 Pro, SKR Mini E3 V3
Custom Marlin bugfix-2.1.x Build (just printing parameters for max temp, z-probe, etc.... Nothing connection-y)
Chrome Version 120.0.6099.225 (Official Build) (64-bit) on Windows 11
This only surfaced in the last few days. I've been running on that firmware and this version of octopi/octoprint for months.
