Hello community!
I made my custom D-bot 3D-printer like 3 years ago. And first of all I started to use OctoPrint. And it was perfect until version 1.3.7 I guess when I first get this error. After searching forums for same problems and found troubles like underpower and wrong USB cables, not last version of OctoPrint and tryed solutions from that topics - it not helped. So I tried to use Repetier Server to be shure that it is not a hardware problem - and printer works perfectly. After like 1.5 years of printing I noticed that Repetier develops slowly and don't implement different interesting functions. And now, when I started to develop 2 new 3D-printers I decidet to try again OctoPrint infrastructure for all my projects. So I get another SD card, installed new version of OctoPrint (1.3.12) and... found same problem on my first printer. Another searches on forum was not successfull - still tere are same usb or underpower problems and more new troubles with Creality and other comercial printers that are not my case.
After preheat procedures and 20-25 minutes of printing target temperature drops to zero and OctoPrint stops print when it get Cold Extrusion error from firmware.
Searched on different forums for same problems;
Checked hardware problems like good power supply for Raspberry Pi, good USB-cable;
Using fresh OctoPrint version 1.3.12;
Build TestUnit to check everything twice.
Logs (octoprint.log
, serial.log
or output on terminal tab at a minimum, browser error console if UI issue ... no logs, no support!)
OctoPrint log file:
octoprint.log (42.7 KB)
Serial log:
serial.log (1.4 MB)
OctoPrint version: OctoPrint 1.3.12
OctoPi version: OctoPi-buster-lite-0.17.0
printer: Custom D-bot Printer
firmware: MarlinKimbra V4.3.8
hardware: Arduino DUE + Raspberry Pi 3B
browser: Google Chrome latest
operating system: Windows 10 x64
Slicing software: Simplify3D v4.1
Original Screenshot from my D-bot:
Hope together we can find solution because I really like flexibility of OctoPrint and want to use it in my further developments.
Thanks to everyone for any help and assistance!
