on small printer jobs it sometimes says "too many lines to buffer, cut off" and it stops and makes some bubbles but not always and it prints a bit and then it happens again on the same printer job
I do not know what to try
I don't know
browser.user_agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_13_6) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/13.1.2 Safari/605.1.15
connectivity.enabled: True
connectivity.online: True
env.hardware.cores: 4
env.hardware.freq: 1400.0
env.hardware.ram: 914010112
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.octopiuptodate_build: 0.18.0-1.7.3-20220120112925
env.plugins.pi_support.throttle_state: 0x80000
env.python.pip: 20.3.3
env.python.version: 3.7.3
env.python.virtualenv: True
octoprint.last_safe_mode.date: 2022-06-25T07:58:50Z
octoprint.last_safe_mode.reason: incomplete_startup
octoprint.safe_mode: False
octoprint.version: 1.8.1
printer.firmware: Marlin 1.1.0-RC8 (Github)
systeminfo.generated: 2022-07-03T14:58:04Z
systeminfo.generator: zipapi
The two are not directly related, but may indicate part of the problem.
The 'too many lines to buffer' means that the lines are going too fast to the printer that they cannot be shown in the terminal in the UI - it is only impacting the UI.
However. It may be indicating that the resolution of the gcode file is too high to be printed. Can you share the file?
By the way:
Please test in safe mode to eliminate plugin issues.
BTW (although not completely necessary for the initial conversation here in this case, but good practice):
I don't think there's a flat surface anywhere on that object. I think we need to also see the gcode output from the slicer as well as some details on the slicer (make and version). We may need details on the slicer settings used as well.
