TP Link Tapo Smart Plug not connecting to Octoprint
Hi All, i have an ender 3v2 Running Octo Print and a TPLink Tapo Smart plug to the printer which has been turning off my printer when the print finishes, but unfortunatly now all i get is a grey symbol spinning for the smart plug in octoprint where as before it would not spin and be a bright green to say its connected. has anyone else suffered this issue lately?
thanks
Hello @m999 !
What plugin do you use for the smart plug and where has this gone?:
You can download this in OctoPrint's System Information dialog ... no bundle, no support! )
OctoPrint version, OctoPi version, printer, firmware, browser, operating system, .... as much data as possible
Hi thanks for the reply, I am using the "Tapo Smartplug" Plugin and i have labeled it as" Ender 3 main" i have installed a couple of others but they are not working either. it just spins around grey and wont shut the printer off anymore, cheers
I can't find it in the OctoPrint repository.
Where did you get it from?
And again:
I suspect it's this fork of my plugin....
Hi thanks for the reply, i have tried to manual install but it says install unknown?
You might want to try this forked version (there's an open PR with a fix).
https://github.com/a0s/OctoPrint-TapoSmartplug/archive/refs/heads/master.zip
thanks ill give it a try :slight_smile:
Hi Its still the same unfortunately
we think we worked through the issue here with the Tapo plugin. The problem stems from the upstream module forcing a requests module version that is incompatible with OctoPrint. You can try installing my modified version of that module by running
/home/pi/oprint/bin/pip install https://github.com/jneilliii/TapoP100/archive/refs/heads/main.zip
prior to installing the plugin. That way the module dependency is satisfied and doesn't conflict with OctoPrint's minimum version requirement of requests. I do not know if this will actually fix the issue, but it should at least allow you to get the plugin installed and check yourself.
potentially found a simpler solution. someone forked the original plugin and module dependency and has put them together, so you may be able to just use this URL to install.
https://github.com/harisjmd/OctoPrint-TapoSmartplug/archive/refs/heads/master.zip
thank you ill try now :slight_smile:
Still no joy im afraid
system info bundle may help diagnose the error then.
thanks ill give it a go :slight_smile:
its says
2022-03-10 17:12:18,098 - octoprint.server.api - ERROR - Error calling SimpleApiPlugin taposmartplug
this pops up alot
Cheers
