Trying to get OcpPi setup in new home different state. I had Octopi and Obico working on two printers in NY state. Was on a Spectrum Network with mesh networking extension running printers via ethernet.
Since we moved to NC, I can't get the OctoPrint Server to spin up.
I have tried rebuilding the Pies using Raspberry Pi imager multiple times. I have tried it on the Raspberry Pi 3B and my newer Raspberry Pi 4B multiple times.
I have tried both WiFi and ethernet connections with the same results. I am no longer using the Mesh Network as the signal strength of our new Spectrum Router in NC is excellent. I can see the Raspberry Pi 4B in my connected devices on the router, both WiFi and Ethernet and can get the IP #s for them. I am able to connect to the Pi using the .local connection method and via the IP number from my browser but it always throws the same error screen.
It says " The OctoPrint server is currently not running"
I can connect via Putty to the system and log in using the Login and Password that I configured in the RaspBerry Pi Imager but unfortunately that's as far as I can get. I don't know the SSH command structure well enough to get the suggested commands to work.
I know there's not a lot to go on here but I'm stumped and have spent hours trying to find what's missing. Thanks so much for any help/suggestions!
I can't get that far from the command line in Putty.
I appreciate the no bundle, no support! comment but I don't know how to get far enough into the system to get one sinc the Octoprint interface never loads.
Octopi version: 1.0.0
Octoprint version: 1.10.3 (build 20241105092907)
Connected to a: Prusa MK3S+
Browser: Chrome
OS: Windows 11
