Sorry if this is basic issue, but I do not have a lot of experience at the detail code level of Octopi/Octoprint so I don't understand what the Octoprint log is saying.
Updating to Octoprint 1.7.0 from Octoprint 1.6.1 keeps failing (first time I have ever had an Octoprint upgrade issue). In the Octoprint log it seems to show an error related to "plugin firmware check". I have tried searching for a similar issue on the forum, but did not find any. The relevant excerpt from the Octoprint log is shown below. It is the only item I can find in the log related to an error message. The piluginmanager and softwareupdate console logs are empty, not sure why.
2021-10-20 15:35:03,469 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2021-10-20 15:35:04,578 - octoprint.plugin.core - ERROR - Error loading plugin firmware_check
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/plugin/core.py", line 1264, in _import_plugin
module = _load_module(module_name, spec)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/plugin/core.py", line 69, in _load_module
return imp.load_module(name, f, filename, details)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint_firmware_check/init.py", line 45, in
"firmware-development": FirmwareDevelopmentChecks.as_dict(),
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint_firmware_check/checks/firmware_development.py", line 20, in as_dict
MarlinBugfixCheck(),
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint_firmware_check/checks/firmware_development.py", line 46, in init
super().init()
TypeError: super() takes at least 1 argument (0 given)
2021-10-20 15:35:05,080 - octoprint.plugin.core - INFO - Found 23 plugin(s) providing 23 mixin implementations, 53 hook handlers
Tried deleting Python 3 Compatibility check plugin (installed since last successful update so thought maybe that was an issue), but no change in result after deletion.
no
n/a
browser.user_agent : Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/94.0.4606.81 Safari/537.36 Edg/94.0.992.50
connectivity.connection_check : 1.1.1.1:53
connectivity.connection_ok : true
connectivity.enabled : true
connectivity.online : true
connectivity.resolution_check : octoprint.org
connectivity.resolution_ok : true
env.hardware.cores : 4
env.hardware.freq : 1500
env.hardware.ram : 915337216
env.os.bits : 32
env.os.id : linux
env.os.platform : linux2
env.plugins.pi_support.model : Raspberry Pi 4 Model B Rev 1.1
env.plugins.pi_support.octopi_version : 0.17.0
env.plugins.pi_support.throttle_state : 0x0
env.python.pip : 19.3.1
env.python.version : 2.7.16
env.python.virtualenv : true
octoprint.safe_mode : false
octoprint.version : 1.6.1
systeminfo.generator : systemapi
OctoPrint version 1.6.1, OctoPi version 0.17.0. Printer is an Anycubic Chiron.
