UI is showing garbage in all tabs
Hi all,
I've recently been getting this in my UI after the most recent update. I've tried to clear the cookies and cache but that didn't seem to help. Each tab has the same issue, filled with rubbish.
Has anyone else seen this and found a solution?
Andy
Looks like some kind of log output.
Unfortunately you deleted the template and didn't post the information we need to help you :wink:
(Please remember to attach the systeminfo bundle)
I'm quite impressed that your server still works at all, but it looks like you've got some kind of corruption going on there.
To fix OctoPrint, you could try reinstalling the update:
However, I would take it as a sign that your SD card may be dying. Keep regular backups to avoid data loss, and maybe look at swapping it for a different one.
So the solution to my weird UI issue was to reinstall Octoprint using the instructions found here - How to reinstall OctoPrint
