UI load looping every 2 seconds
Have used Octopi on Pi 3B for several years, all of a sudden it started asking for user name and password. I do not remember ever setting that up, it always just started up.
I tried the config.yaml remove routines, no help. "file does not exist"
Finally forced re-install of Octoprint. Twice.
Now when go to http://octopi.local, it starts with the "Loading UI, please wait" screen but that just loops every 2 seconds, UI never loads.
Yes, I think. Not sure that worked
No UI, Octoprint never completes loading, so cannot see system information
Octoprint 1.9.3
Windows 11
Pi 3B
Prusa MK3 printer
Hello @TNDave !
Have you tried a different browser?
Thanks for the suggestion. I just tried three browsers, Chrome, Edge, and Firefox. All do the same thing.
This is what it does:
I cannot upload a systeminfo package, no way to get it.
I tried the command line method, but all I get is "command not found". I added the trailing period, tried one space, and two spaces, nothing works.
Have you tried via SSH?
This may be caused by data corruption on the microSD card. If you have another microSD card, please flash a new OctoPi image and see if you can get through the initial startup.
As @Ewald_Ikemann asked, can you SSH into the RPi 3B? If so, it should print the OctoPrint and OctoPi versions on the terminal. Let us know what OctoPi version you have.
I flashed a new SD card, working now! Thanks
