Ultimaker Cura (latest)
I note that Ultimaker Cure has the ability to link with Octopi. But I am not sure how to do this. I would be grateful for help with this. At the moment from I design with Tinkercad, .. download the stl to my Downloads.. then pick the design up with Ultimaker and save the code to an appropriate folder. I then set Octopi running and from that upload the code and follow procedure to print. This works well but any shortcuts would be welcome.
Just looked at Ultimaker without doing anything for fear of corrupting print quality.
N/A
N/A
Complete Logs
N/A
browser.user_agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_6) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.0.3 Safari/605.1.15
connectivity.connection_check: 8.8.8.8:53
connectivity.enabled: true
connectivity.online: true
env.hardware.cores: 4
env.hardware.freq: 1500
env.hardware.ram: 3966898176
env.os.bits: 32
env.os.id: linux
env.os.platform: linux2
env.plugins.pi_support.model: Raspberry Pi 4 Model B Rev 1.1
env.plugins.pi_support.octopi_version: 0.17.0
env.python.pip: 19.3.1
env.python.version: 2.7.16
env.python.virtualenv: true
octoprint.safe_mode: false
octoprint.version: 1.5.2
printer.firmware: Marlin Creality 3D
2 posts were merged into an existing topic: Cura OctoPrint Connection plugin
