I am unable to connect my printer to my Raspberry Pi.
The Raspberry Pi is a Raspberry Pi 4 Model B 8gb
The printer is an Ender 3 Pro
The board for the printer is the BTT SKR Mini E3 V2.0
The LCD for the printer is the BTT TFT35 E3 V3.0
There is a antclabs Bltouch attached to the printer
The printer operates normally with marlin and prints fine
I have tried 3 different power supplies: 1 with an output of 3.6 - 6.5 V 3A, 1 with an output of 5.0 V 3A and finally one with an output of 9 V 3A
I have recompiled my own marlin firmware starting from the github default base with the build environment set to STM32F103RC_btt
I have used the marlin examples for the Ender 3 Pro with the SKR Mini E3 V2.0
I changed the values SERIAL_PORT and SERIAL_PORT_2 with different combos of -1,0,1 and 2
I tried the Serial exception work around adding dwc_otg.speed=1 to /boot/cmdline.txt
I have put a strip of tape on the 5V pin of 3 different mini b usb cables (I've ordered another one just in case all the others were faulty too but it won't arrive till late next week)
I have tried disconnecting the TFT35 and using the original LCD + no LCD
I have tried using the most up to date version of Octoprint and Octopi (the 'logs indicate a slightly older version as this is the one that the imager installed on them.
'Logs (/var/log/webcamd.log, syslog, dmesg, ... no 'logs, no support)
octoprint.log (16.5 KB)
serial.log (2.7 KB)
terminalOutput.log (49.3 KB)
Have you tried running in 'safe mode?
Yes
Did running in 'safe mode solve the problem?
'Systeminfo
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/93.0.4577.63 Safari/537.36
connectivity.connection_check: 8.8.8.8:53
connectivity.enabled: true
connectivity.online: true
env.hardware.cores: 4
env.hardware.freq: 1500
env.hardware.ram: 8204619776
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi 4 Model B Rev 1.4
env.python.pip: 20.3.3
env.python.version: 3.7.3
env.python.virtualenv: true
octoprint.safe_mode: false
octoprint.version: 1.5.2
I have added apostrophes to some words as Markdown was auto hyperlinking them and I wasn't able to post.
