Unable to connect octoprint to printer after several months of no use
Octoprint is not able to connect to my printer when I was able to 10 months ago (when I last printed).
  • formatted sd card and reinstalled a fresh image of octopi
  • purchased officials raspberry pi power supply
  • tried various cables - I'm pretty sure the cable I'm using is a data transfer (Amazon basics) so should be fine.
  • increasing the connection timeout from 10 to 45s.
  • manually selecting the port and various baudrates. (i don't know what the baudrate is/should be) so now I just am always using Auto/Auto
  • restarting octoprint in safe mode
  • turning raspberry pi off and on
Here are some logs I was able to pull. The suspicious one is of course the No SD/TF-Card or error, after that it just continues to attempt connecting to the printer with no luck. This is after having formatted the card.
2023-04-19 20:06:34,879 - Recv: Update failed, No SD/TF-Card or error
2023-04-19 20:06:35,882 - Recv: Update failed, No SD/TF-Card or error
2023-04-19 20:06:36,884 - Recv: Update failed, No SD/TF-Card or error
2023-04-19 20:06:36,889 - Trying port /dev/ttyUSB0, baudrate 250000
2023-04-19 20:06:36,902 - Handshake attempt #1 with timeout 2.0s
2023-04-19 20:06:36,910 - Send: N0 M110 N0125
2023-04-19 20:06:39,891 - Handshake attempt #2 with timeout 2.0s
2023-04-19 20:06:39,922 - Send: N0 M110 N0
125
2023-04-19 20:06:42,901 - Handshake attempt #3 with timeout 2.0s
2023-04-19 20:06:42,917 - Send: N0 M110 N0*125
YES
NO
octoprint-systeminfo-20230422110704.zip (14.4 KB)
OctoPrint version, OctoPi version, printer, firmware, browser, operating system, .... as much data as possible
Ender 3 V2
OctoPrint 1.8.7
Python 3.9.2
OctoPi 1.0.0
MacOS Big Sur Version 11.6.8
Macbook Pro Mid 2014
Hello @printtip !
The connection from the Pi to the printer is not a network issue.
So please:
Hello, should I move it to another place? I thought it made most sense in the networking section given that i was not able to connect to my printer
I already moved to Get Help.
To get more knowledge on your issue, please post the infos that have been aked for in my last post.
I didn't realize there was information I had been missing, this has been corrected thank you!
