Unable to launch OctoPrint on MacOS
I am unable to even launch Octoprint on MacOS. I followed the guide posted at link below, but when actually running the application with the command octoprint serve it doesn't launch, and gives errors.
Setting up OctoPrint on MacOS
I do not know how to fix this issue, so I have not attempted anything. I am not comfortable messing with the code.
No, I cannot run OctoPrint at all.
I am not able to get a Systeminfo Bundle at all, from neither the UI (cannot launch) or the CLI request (gives no output)
MacOS Ventura Version 13.2 Beta (22D5027d),
Last login: Wed Mar  1 10:25:24 on ttys000
nathanfender@Nathans-MacBook-Pro ~ % cd Documents
nathanfender@Nathans-MacBook-Pro Documents % cd octoprint
nathanfender@Nathans-MacBook-Pro octoprint % cd ..
nathanfender@Nathans-MacBook-Pro Documents % cd OctoPrint
nathanfender@Nathans-MacBook-Pro OctoPrint % source venv/bin/activate
(venv) nathanfender@Nathans-MacBook-Pro OctoPrint % octoprint serve
2023-03-01 10:45:14,395 - octoprint.startup - INFO - ******************************************************************************
2023-03-01 10:45:14,395 - octoprint.startup - INFO - Starting OctoPrint 1.8.6
2023-03-01 10:45:14,396 - octoprint.startup - INFO - ******************************************************************************
2023-03-01 10:45:14,645 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: online
2023-03-01 10:45:14,645 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 1.1.1.1:53 is working
2023-03-01 10:45:14,645 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is working
2023-03-01 10:45:14,648 - octoprint.plugin.core - INFO - Loading plugins from /usr/local/lib/python3.11/site-packages/octoprint/plugins, /Users/nathanfender/Library/Application Support/OctoPrint/plugins and installed plugin packages...
2023-03-01 10:45:14,976 - octoprint.plugin.core - ERROR - Error loading plugin announcements
  File "/usr/local/lib/python3.11/site-packages/octoprint/plugin/core.py", line 1274, in _import_plugin
    module = _load_module(module_name, spec)
  File "/usr/local/lib/python3.11/site-packages/octoprint/plugin/core.py", line 52, in _load_module
    return imp.load_module(name, f, filename, details)
  File "/usr/local/lib/python3.11/site-packages/octoprint/vendor/imp.py", line 238, in load_module
    return load_package(name, filename)
  File "/usr/local/lib/python3.11/site-packages/octoprint/vendor/imp.py", line 212, in load_package
    return _load(spec)
  File "<frozen importlib._bootstrap>", line 721, in _load
  File "<frozen importlib._bootstrap>", line 690, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 940, in exec_module
  File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
  File "/usr/local/lib/python3.11/site-packages/octoprint/plugins/announcements/__init__.py", line 22, in <module>
    from octoprint.server.util.flask import (
  File "/usr/local/lib/python3.11/site-packages/octoprint/server/__init__.py", line 46, in <module>
    from octoprint.server import util
  File "/usr/local/lib/python3.11/site-packages/octoprint/server/util/__init__.py", line 21, in <module>
    from . import flask, sockjs, tornado, watchdog  # noqa: F401
  File "/usr/local/lib/python3.11/site-packages/octoprint/server/util/flask.py", line 34, in <module>
    import octoprint.access.users
  File "/usr/local/lib/python3.11/site-packages/octoprint/access/users.py", line 11, in <module>
    import wrapt
  File "/usr/local/lib/python3.11/site-packages/wrapt/__init__.py", line 10, in <module>
    from .decorators import (adapter_factory, AdapterFactory, decorator,
  File "/usr/local/lib/python3.11/site-packages/wrapt/decorators.py", line 34, in <module>
    from inspect import ismethod, isclass, formatargspec
ImportError: cannot import name 'formatargspec' from 'inspect' (/usr/local/Cellar/python@3.11/3.11.2_1/Frameworks/Python.framework/Versions/3.11/lib/python3.11/inspect.py)
2023-03-01 10:45:15,012 - octoprint.plugin.core - ERROR - Error loading plugin softwareupdate
    return _load(spec)
  File "/usr/local/lib/python3.11/site-packages/octoprint/plugins/softwareupdate/__init__.py", line 24, in <module>
    from octoprint.server import BRANCH, NO_CONTENT, REVISION, VERSION
    import wrapt
2023-03-01 10:45:15,045 - octoprint.plugin.core - ERROR - Error loading plugin pluginmanager
    return _load(spec)
  File "/usr/local/lib/python3.11/site-packages/octoprint/plugins/pluginmanager/__init__.py", line 29, in <module>
    from octoprint.server import safe_mode
    import wrapt
2023-03-01 10:45:15,062 - octoprint.plugin.core - ERROR - Error loading plugin appkeys
    return _load(spec)
  File "/usr/local/lib/python3.11/site-packages/octoprint/plugins/appkeys/__init__.py", line 12, in <module>
    from octoprint.server import NO_CONTENT, admin_permission, current_user
    import wrapt
2023-03-01 10:45:15,109 - octoprint.plugin.core - ERROR - Error loading plugin backup
    return _load(spec)
  File "/usr/local/lib/python3.11/site-packages/octoprint/plugins/backup/__init__.py", line 8, in <module>
    import wrapt
2023-03-01 10:45:15,139 - octoprint.plugin.core - ERROR - Error loading plugin logging
    return _load(spec)
  File "/usr/local/lib/python3.11/site-packages/octoprint/plugins/logging/__init__.py", line 14, in <module>
    import wrapt
2023-03-01 10:45:15,184 - octoprint.plugin.core - INFO - Plugin Pi Support Plugin (2022.6.13) did not pass check, not loading.
2023-03-01 10:45:15,225 - octoprint.plugin.core - INFO - Found 11 plugin(s) providing 11 mixin implementations, 15 hook handlers
2023-03-01 10:45:15,243 - octoprint.cli.server - ERROR - Uncaught exception
  File "/usr/local/bin/octoprint", line 8, in <module>
    sys.exit(main())
  File "/usr/local/lib/python3.11/site-packages/octoprint/__init__.py", line 936, in main
    octo(args=args, prog_name="octoprint", auto_envvar_prefix="OCTOPRINT")
  File "/usr/local/lib/python3.11/site-packages/click/core.py", line 1130, in __call__
    return self.main(*args, **kwargs)
  File "/usr/local/lib/python3.11/site-packages/click/core.py", line 1055, in main
    rv = self.invoke(ctx)
  File "/usr/local/lib/python3.11/site-packages/click/core.py", line 1657, in invoke
    return _process_result(sub_ctx.command.invoke(sub_ctx))
  File "/usr/local/lib/python3.11/site-packages/click/core.py", line 1404, in invoke
    return ctx.invoke(self.callback, **ctx.params)
  File "/usr/local/lib/python3.11/site-packages/click/core.py", line 760, in invoke
    return __callback(*args, **kwargs)
  File "/usr/local/lib/python3.11/site-packages/click/decorators.py", line 26, in new_func
    return f(get_current_context(), *args, **kwargs)
  File "/usr/local/lib/python3.11/site-packages/octoprint/cli/server.py", line 317, in serve_command
    run_server(
  File "/usr/local/lib/python3.11/site-packages/octoprint/cli/server.py", line 145, in run_server
    from octoprint.server import CannotStartServerException, Server
    import wrapt
(venv) nathanfender@Nathans-MacBook-Pro OctoPrint % octoprint systeminfo
OctoPrint doesn't support python 3.11 yet.
Currently Python 3.7, 3.8, 3.9 and 3.10 are supported.
It's supposed to be included in 1.90.
I'm not familiar with MacOS, but if you can install a lower python version like 3.10 you can create the venv with that specific version.
Here is a small guide
update: 3.11 is supported now - just reinstall OctoPrint to update it to 1.8.7 and it should work
