I'm unable to set nozzle temperature, I bed temperature is up not able to set nozzle temperature. it was working fine and ew cancel it is not working
I tried setting bed temperature manually from octoprint, it didn't work. tried restarting, didn't work
yes, it is still there
octoprint.log, serial.log or output on terminal tab at a minimum , browser error console if UI issue ... no logs, no support! Not log excerpts, complete logs.)
Version 1.4.2, OctoPi version,cr10s, meirlin 2 , crome, WIN 10
I tried restarting the whole pi systemoctoprint (3).log (2.3 MB) , then got the error "Your printer's firmware reported an error. Due to that OctoPrint will disconnect. Reported error: Heating failed, the system stopped! Heater_ID: bed - Printer halted. kill() called!
Please do not open a new thread for the same issue:
octoprint (1).log (187.5 KB)
I use cr10s, the octopi were working fine a few days ago, I haven't used it for some time. I tried running octopi and octoprint and got the error message. I have no SD inn my printer, no test mode and set Temperature interval (Auto report) to 0 (i.e. turn off Auto report. the octoprint is updating bed heating but not heating and no nozzle heating
As I told you there: you have a hardware problem:
2020-11-12 17:55:33,495 - octoprint.util.comm - WARNING - Received an error from the printer's firmware: Heating failed, system stopped! Heater_ID: bed - Printer halted. kill() called!
| Last lines in terminal:
| Recv: T:28.64 /0.00 B:28.22 /40.00 @:0 B@:127 W:?
| Recv: T:28.61 /0.00 B:28.28 /40.00 @:0 B@:127
| Recv: T:28.55 /0.00 B:28.28 /40.00 @:0 B@:127 W:?
| Recv: T:28.49 /0.00 B:28.12 /40.00 @:0 B@:127
| Recv: T:28.72 /0.00 B:28.37 /40.00 @:0 B@:127 W:?
| Recv: T:28.64 /0.00 B:28.25 /40.00 @:0 B@:127 W:?
| Recv: T:28.52 /0.00 B:28.25 /40.00 @:0 B@:127
| Recv: T:28.44 /0.00 B:28.25 /40.00 @:0 B@:127 W:?
| Recv: T:28.75 /0.00 B:28.31 /40.00 @:0 B@:127 W:?
| Recv: T:28.52 /0.00 B:28.16 /40.00 @:0 B@:127
| Recv: T:28.66 /0.00 B:28.31 /40.00 @:0 B@:127 W:?
| Recv: T:28.72 /0.00 B:28.25 /40.00 @:0 B@:127 W:?
| Recv: T:28.58 /0.00 B:28.25 /40.00 @:0 B@:127
| Recv: T:28.47 /0.00 B:28.16 /40.00 @:0 B@:127 W:?
| Recv: T:28.52 /0.00 B:28.31 /40.00 @:0 B@:127 W:?
| Recv: T:28.61 /0.00 B:28.19 /40.00 @:0 B@:127
| Recv: T:28.49 /0.00 B:28.19 /40.00 @:0 B@:127 W:?
| Recv: Error:Heating failed, system stopped! Heater_ID: bed
| Recv: Error:Printer halted. kill() called!
You have a thermal runaway issue. You set the bed to 40Β°C, but it does not heat up.
Check the cables of the bed.
Check if the bed thermistor is detached from the bed.
Check if the printer is powered on. -> The display may be lit, but than can be by an issue of the board the the processor and display is powered by the Pi.
