Good afternoon
I am unable to install the updates from the octo pi dashboard 1.5.2. fresh install.
I am also unable to install plugins.
I have gone into console and done an update
sudo apt get update
Sudo apt get upgrade
Complete Logs
Raspberry pi 3, 8gb memory cardoctoprint (1).log (73.5 KB)
Hello @georgew94 !
What's about this:
georgew94:
Complete Logs
Shot in the dark: Do you have this:
Starting with OctoPrint 1.3.10, the bundled "Pi Support Plugin" (only active when running on a Raspbery Pi) will regularly check if your Pi has detected any underlying issues via vcgencmd get_throttled.
This command can detect whether your Pi is currently throttled, or has been in the past, either due to undervoltage or overheating.
The Pi Support Plugin evaluates this information and displays corresponding icons in your navbar in case such a situation is detected:
[image]
In the above examp…
I can't see these symbols, I did have a voltage issue when I first started but have resolved this now, I cant attatch my logs im still a noob account
foosel
March 9, 2021, 2:18pm
4
Even completely new users are allowed to attach a file to their post... otherwise we wouldn't be so adamant on logs without which we btw can't help.
Thank you I have uploaded the file, I'm all abit new to this, bit overwhelming haha.
As I assumed before:
| pi_support:
| model: Raspberry Pi 3 Model B Rev 1.2
| octopi_version: 0.18.0
| throttle_state: '0x50005'
2021-03-09 13:55:42,953 - octoprint.plugins.pi_support - WARNING - This Raspberry Pi is reporting problems that might lead to bad performance or errors caused by overheating or insufficient power.
!!! UNDERVOLTAGE REPORTED !!! Make sure that the power supply and power cable are capable of supplying enough voltage and current to your Pi.
You have an undervoltage issue. You may provide your Raspberry Pi with a decent power supply.
Oh sorry thank you I thought I'd solved that before with it being a high voltage when I first started setting it up, perfect I shall sort this now thanks again.
Great! So could you please:
All topics you create in this category can be marked as "Solved" by clicking the little icon under the post that contains the solution:
[image]
Please make heavy use of it. Marking a topic as solved allows others to quickly see that a solution has been found and also displays the solution prominently right in the start post so that others with the same problem may find it easier, without having to scan through the whole thread.
Thank you!
