Update to 1.7.3 from 1.6.1 is failing
Removed all third party plugins and also tried updating in safe mode
Yes
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/100.0.4896.88 Safari/537.36
connectivity.enabled: true
connectivity.online: true
env.hardware.cores: 4
env.hardware.freq: 1200
env.hardware.ram: 971055104
env.os.bits: 32
env.os.id: linux
env.os.platform: linux2
env.plugins.pi_support.model: Raspberry Pi 3 Model B Rev 1.2
env.plugins.pi_support.octopi_version: 0.17.0
env.plugins.pi_support.throttle_state: 0x50000
env.python.pip: 19.3.1
env.python.version: 2.7.16
env.python.virtualenv: true
octoprint.safe_mode: true
octoprint.version: 1.6.1
printer.firmware: Marlin TH3D UFW 2.13 (Dec 10 2020 15:21:33)
Pi does have a touchscreen installed running OctoDash - Innomaker Raspberry Pi LCD Display TFT Capacitive Touch Screen 3.5
Hello @3dKaos3d :blush:
You may have a look on this thread
Also:
does not look like that person on that thread solved their issue from what I can tell.
octoprint-systeminfo-20220418141543.zip (98.4 KB)
Here is the bundle sorry about that.. first time I had issue with it .
The thread is marked as solved.
At the end of the first post there is this:
So the issue was going to Python 3...
I am not quite sure how to do that.
This is your issue, from the logs in the bundle:
It is an issue that only affects legacy Python 2 installs. For upgrading to Python 3 (as the many blog posts & notifications have mentioned, and which you will have to do to upgrade to 1.8.0), you can look here:
