Update to 1.8.3 fails on one of four Pi's.
try again after system reboot
yes.
nope
You can download this in OctoPrint's System Information dialog ... no bundle, no support! )
octoprint-systeminfo-20220926151204.zip (390.7 KB)
Four Pi's with identical setup. On 3 of them I had a successful update. Only this one produces errors.
Printer: Sovol SV04 stock firmware, Chrome browser on Win10 (all on current patch level).
Hi
Unfortunately it looks like a corrupted filesystem and/or a broken sd card.
If you're lucky a reinstall via command line will fix the issue:
Note: This process will not impact any saved data or plugin installs, so it is harmless to give it a try if recommended.
There are some occasions where you want to reinstall OctoPrint - like if OctoPrint doesn't start anymore after a failed update or if you can't update OctoPrint to a newer version because something went wrong during the update.
Sometimes it also helps in situations where the filesystem was damaged (for example after a pulled plug, a power outage, a crash an…
If that works I would download a backup and flash a new image to this or even better a new sd card.
(In case it doesn't work here a quick guide on how to backup it manually)
Starting with 1.3.10 OctoPrint will ship with a bundled Backup Plugin that should make backing up and restoring settings, files and plugins easy.
For versions prior to that, read on:
OctoPrint stores all its data in ~/.octoprint - uploads, timelapses, configuration, plugin data, etc. That makes backing them up quite easy. Third party plugins are installed into the virtual environment under ~/oprint and a bit trickier to backup since you can't just copy that folder (well, technically you could…
Fingers crossed
system
closed
December 25, 2022, 4:00pm
#3
