Filling this out properly makes it WAY more likely to get help quickly ~~~~~ -->
I am currently using Octoprint 1.16.1, with Python 2.7.16 and Octopi 1.17.0
I have had good experiences with this setup but see that I am well behind the current versions.
I am always wary of updating because of possible hicoughs that leave one with a mess and unable to get back to the setup that worked.
I am not comfortable with coding and easily get lost so generally do not update.
If I do try to update to latest setup versions am I heading to frustrations best ovoided?
All help will be appreciated/
Octoprint 1.16.1, with Python 2.7.16 and Octopi 1.17.0[date=2023-02-28 timezone="Europe/London"]
To start with, you will need to upgrade your Python version first to be able to update to 1.8.x versions, since your Python 2.7 is no longer supported.
See the below post for instructions for that:
I would probably recommend re-flashing OctoPi as the fastest way to get up to date. 1.6.1 is not that ancient (less than 2 years ago) so I wouldn't anticipate too many issues as the jump is not that huge.
As always - take a backup of your stuff first before doing large upgrades so you can go your data back is something goes wrong.
