Ver 1.8.6 fails repeatedly but allows file to print
Since the above upgrade (today) octoprint web interface seems to freeze. Doing a page refresh will eventually work but only for a few seconds. In the meantime the file continues to print ok via my pi4
Reboot all parts of system, no change.
I do not presently have any logs
Same results from windows 10 on a Alienware M17 R4 using Microsoft edge, iPhone 11 Pro with iOS 16.1 and iPad Pro with iOS 16.1
Hello @Jmark0649 !
Sorry, but we do not know anything about your OctoPrint setup besides the version and that you use a Pi4
It also seems to be no network issue.
Please share the following infos:
OctoPrint version, OctoPi version, printer, firmware, browser, operating system, .... as much data as possible
