Ok, I followed this youtube video on how to setup the octopi. Went easy and I was up and working pretty quick. I ran a few prints from the octoprint raspberry pi4. I then decided to add the camera to the pi. I turned off the raspberry pi and installed the camera.
I then opened up octoprint on my PC (the only way I have to access it) and while I could connect, there was no video feed coming in. I looked and found this post that seemed to maybe address my issue. So I followed it.
I downloaded putty and was able to follow the post to complete the "sudo raspi-config" I then went and enabled the camera.
I have not been able to access octoprint or the raspberry pi since.
I tried a few things I read, nothing worked, I eventually formatted the SD card and ran back through the entire setup process, and still the same.
If I try to open http://octopi.local I get a server not found error. I tried to go back into putty, I had to use the ip address(not sure if that's how I did it the first time) but the name http://octopi.local just gave an error.
When I put in the ip address I could enter the user:pi but the password was not working. I did not change the password from raspberry.
I am new to raspberry pi's and 3d printing in general, so I might just be missing something easy and obvious to everyone else.
No.
Don't know how??
EDIT Ok redid it all again and figured I should get this information while I had access.
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:88.0) Gecko/20100101 Firefox/88.0
connectivity.connection_check: 8.8.8.8:53
connectivity.enabled: true
connectivity.online: true
env.hardware.cores: 4
env.hardware.freq: 1500
env.hardware.ram: 8204619776
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi 4 Model B Rev 1.4
env.python.pip: 20.3.3
env.python.version: 3.7.3
env.python.virtualenv: true
octoprint.safe_mode: false
octoprint.version: 1.5.2
Ender 3 V2. bugfix-2.0.x firefox windows 10
