Webcam not working in control tab from a remote computer, but works if I put the address in a separate tab in the browser.
The webcam on control tab is working on the local Raspbian.
In settings the snapshot test works ok but not the stream test.
Tried to put the user:password@ in the address, but no success...
Nope
Nope
The stream address: http://192.168.1.37:8080/?action=stream
Like i sad, if I paste this address in a new tab in chrome it works (also in remote computer on my home network), but the same address inside Octoprint doesn't (Control Tab)
Since you are not using OctoPi we need to know how you have setup the webcam. You should aim to provide as much information about your setup as possible. In addition to a couple the questions I already asked.
I had problems like this, but I tried to use a usb camera and there were other old versions, I accessed it directly through the ip, but not through the octopi, the address was wrong
try this
"/webcam/?action=stream"
or "127.0.0.1/?action=stream"
I saw in the logs that it has an error when accessing ip .1.37
"2022-05-08 19:02:02,598 - zeroconf - WARNING - Error with socket 5 (('192.168.1.37', 5353))): [Errno 101] Network is unreachable"
Thanks for replying, but the "/webcam/?action=stream" could never work from another computer which is part of my problem:
using the following address to the camera http://192.168.1.37:8080/?action=stream:
The webcam work ok from the Octoprint Control tab on the local Octoprint computer.
The webcam work ok from another computer in a separate google tab.
The webcam does not work from another computer in the Octoprint Control Tab
Have you missed the several times I've asked you for details of how you've setup the webcam stream and how you are accessing OctoPrint? Or just choosing to ignore them?
Thank's for your attempt to help me. I got it working by accessing it by my external internet address and a port forwarding in my router. Still not understand why it didn't work with the LAN address...
So using "http://192.168.1.37:8080/?action=stream" didn't work but
"http://myexternalip:8080/?action=stream" and a port forwarding to 192.168.1.37 worked...
