Webcam stream not working in OctoPi
Microsoft Lifecam HD-3000
I get no webcam feed in the Control tab of OctoPi and I get no error message
To setup the webcam I used the following guide:
I used the following parameters "-r HD -f 20" which should be used with my cam according to the camera guide.
octoprint-systeminfo-20230629143147.zip (11.4 KB)
OctoPrint 1.7.3, OctoPi 0.17.0, Anycubic Vyper, browser: Chrome, operating system: Win 10.
According to the guide I followed camera_http_webroot= should be set to ''./www" (so two ' instead of one "), I assume this is incorrect and it should it be one "?
No one has any input regarding this at all??
What are the settings for the webcam under
OctoPrint Settings -> Features -> Webcam & Timelapse ?
These are the settings:
The URL is empty and the guide never mentioned anything about this. But I think per default there was an URL but I don't remember what it was so right now that field is just empty
Try with in Stream URL:
/webcam/?action=stream
Side Note:
This is for older OctoPirnt versions.
Recent versions like 1.9.0 onwards work different.
Tried it but it didn't work so I upgraded to Octoprint version 1.9.1 and now the webcam stream works in Octoremote mobile app using this URL http://MYIP/webcam/?action=stream
Is it possible to set up a WiFi webcam to Octopi or does the webcam have to be directly connected to my Octopi unit?
WiFi cams should work too. You have to use the URL/IP address of that cam then.
But not all cams like to cooperate with OctoPi/OctoPrint
That's good news cause I much rather use my WiFi cam instead due it having a lot more features and better quality. I have a TP-Link Tapo C200 and I found a guide to set up a stream using VLC Player.
The URL i used was in the following format: rtsp://username:password@MyIP/stream1
This worked fine in VLC and I could see the stream but when using the exact same URL in Octoremote it would not work.
OctoPrint (& I suspect all 3rd party apps) don't support RTSP streams. Also, in the browser, they don't allow embedding the username & password in the URL as it is not secure, so even if it was mjpg, you wouldn't be able to get through the authentication.
If the camera provides a plain mjpg stream, then that works otherwise you're out of luck with that camera I suspect. Perhaps someone else has a solution they came up with.
That does not sound promising but thanks for the info. I was able to find the datasheet for my cam and the supported protocols listed are:
TCP/IP, DHCP, ARP, ICMP ,DNS, NTP, HTTP, HTTPS, UDP, ONVIF, RTSP
and unfortunately MJPG is not listed as one of them, and I guess none of the others work?
