When the gcode file is uploaded to the SD card, the file name and suffix will change
When the gcode file is uploaded to the SD card, the file name and suffix will change. For example, xxxx.gco. The new file name generated cannot be recognized by the 3D printer. Can this file name be defined by yourself. need help. My printer model is creality3d cr6se
Hello @xiaoyu !
You may have a look on this:
