Sorry for creating a second thread, but the earlier thread (8822) seems to be dead.
The filament will unload at the beginning of the 4th or 5th print.
I replied to a different thread (8822) with the same issue about 4 days ago. I included the log files requested but no one has replied. I started the serial port logging and two days later. The printer did the unloading. I went to the serial log, compressed it, and uploaded it. It is attached below.
latest_serial.log.zip (1.7 MB)
I am using a Rasberry Pi 3B+ with the 0.17.0 image on it and 1.3.21 OctoPrint.
I use a MacBook Pro, OS 10.14.6, with Firefox and Chrome Browsers to view the Octopi.local interface.
My printer is a Monoprice Maker Select Plus with ADV3i v4.0.3 firmware.
The problem has been occurring since I setup the Octopi server 3 weeks ago. If I re-boot the OctoPi the problem persists, but If I Powercycle the 3D printer, the problem will go away for 4 or 5 prints. The problem does not occur if I print from an SD card.
Thanks for your support on this issue.
Salty Doug
