Same issue I had here. Everything was working fine. I did the 1.6.1 update. Powered off the Ender to change the bowden. Turned it back on the RPi does not see the Ender.
In the UI, I get:
State: **Offline after error**
No more candidates to test, and no working port/baudrate combination detected.
With only "Auto" as the options in Serial Port.
lsusb does not show the printer connected. Here's the dmesg | tail -n 20
[ 128.441939] usb 1-1.4: Device not responding to setup address.
[ 128.661716] usb 1-1.4: device not accepting address 10, error -71
[ 128.662047] usb 1-1-port4: unable to enumerate USB device
[ 157.291703] usb 1-1.4: new full-speed USB device number 11 using xhci_hcd
[ 162.771660] usb 1-1.4: new full-speed USB device number 12 using xhci_hcd
[ 162.871905] usb 1-1.4: device descriptor read/64, error -32
[ 163.311892] usb 1-1.4: device descriptor read/64, error -32
[ 163.531650] usb 1-1.4: new full-speed USB device number 13 using xhci_hcd
[ 163.631890] usb 1-1.4: device descriptor read/64, error -32
[ 163.851876] usb 1-1.4: device descriptor read/64, error -32
[ 163.971901] usb 1-1-port4: attempt power cycle
[ 164.631655] usb 1-1.4: new full-speed USB device number 14 using xhci_hcd
[ 164.631921] usb 1-1.4: Device not responding to setup address.
[ 164.851941] usb 1-1.4: Device not responding to setup address.
[ 165.071650] usb 1-1.4: device not accepting address 14, error -71
[ 165.171653] usb 1-1.4: new full-speed USB device number 15 using xhci_hcd
[ 165.172008] usb 1-1.4: Device not responding to setup address.
[ 165.391881] usb 1-1.4: Device not responding to setup address.
[ 165.611654] usb 1-1.4: device not accepting address 15, error -71
[ 165.611962] usb 1-1-port4: unable to enumerate USB device
lsusb
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
So its not even seeing the Ender in the OS. I thought it could be a Python 2 vs 3 so I ran the upgrade script. No changes.
- Different cords
- Different power supplies
- New image (.18 Octopi and 1.5.2 OctoPrint)
- New card
- New RPi
- Connecting with my Win 10 laptop and using Cura does work
Yes, no difference
octoprint.log (122.6 KB)
octoprint-systeminfo-20210601165135.zip (30.1 KB)
OctoPi 0.17
OctoPrint 1.6.1
Raspberry Pi 4 B
Ender 3 Pro
