Please Help. I have two Creality Ender 3 S1 Pro's that I purchased last month. Been playing around with one of them which is working fine. I have a Raspberry Pi running Octoprint (Octopi) and everything is working fine. So I decided to hook up the second one which does not connect to Octopi due to a USB problem. I've provided the output of 'lsusb' before and after plugging in the working printer and then show the successful connection as shown in /var/log/syslog. I then plug in the second printer that does not connect as shown with a tail of /var/log/syslog file. Any ideas/suggestions?
Thanks very much!
1) No Devices Plugged In
pi@octopi:~ $ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 008: ID 046d:082c Logitech, Inc. HD Webcam C615
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
2) Tail syslog and plug in Creality Ender 3 S1 Pro #1 (Working Fine)
pi@octopi:~ $ tail -f /var/log/syslog
May 7 12:43:36 octopi kernel: [ 993.445602] usb 1-1.1: new full-speed USB device number 26 using xhci_hcd
May 7 12:43:36 octopi kernel: [ 993.581707] usb 1-1.1: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64
May 7 12:43:36 octopi kernel: [ 993.581727] usb 1-1.1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
May 7 12:43:36 octopi kernel: [ 993.581742] usb 1-1.1: Product: USB Serial
May 7 12:43:36 octopi kernel: [ 993.584617] ch341 1-1.1:1.0: ch341-uart converter detected
May 7 12:43:36 octopi kernel: [ 993.589882] usb 1-1.1: ch341-uart converter now attached to ttyUSB0
May 7 12:43:36 octopi mtp-probe: checking bus 1, device 26: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1"
May 7 12:43:36 octopi mtp-probe: bus: 1, device: 26 was not an MTP device
3) Creality Ender 3 S1 Pro #1 shows up as Bus 001 Device 26
pi@octopi:~ $ lsusb
Bus 001 Device 026: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter
4) Plug in Creality Ender 3 S1 Pro #2 (Second Device) which is not recognised by Octopi
May 7 12:45:58 octopi kernel: [ 1135.286568] usb 1-1.1: new full-speed USB device number 27 using xhci_hcd
May 7 12:45:58 octopi kernel: [ 1135.386918] usb 1-1.1: device descriptor read/64, error -32
May 7 12:45:58 octopi kernel: [ 1135.606878] usb 1-1.1: device descriptor read/64, error -32
May 7 12:45:58 octopi kernel: [ 1135.826559] usb 1-1.1: new full-speed USB device number 28 using xhci_hcd
May 7 12:45:59 octopi kernel: [ 1135.926799] usb 1-1.1: device descriptor read/64, error -32
May 7 12:45:59 octopi kernel: [ 1136.146784] usb 1-1.1: device descriptor read/64, error -32
May 7 12:45:59 octopi kernel: [ 1136.267266] usb 1-1-port1: attempt power cycle
May 7 12:46:00 octopi kernel: [ 1136.926570] usb 1-1.1: new full-speed USB device number 29 using xhci_hcd
May 7 12:46:00 octopi kernel: [ 1136.926792] usb 1-1.1: Device not responding to setup address.
May 7 12:46:00 octopi kernel: [ 1137.146934] usb 1-1.1: Device not responding to setup address.
May 7 12:46:00 octopi kernel: [ 1137.366591] usb 1-1.1: device not accepting address 29, error -71
May 7 12:46:00 octopi kernel: [ 1137.466574] usb 1-1.1: new full-speed USB device number 30 using xhci_hcd
May 7 12:46:00 octopi kernel: [ 1137.466788] usb 1-1.1: Device not responding to setup address.
May 7 12:46:00 octopi kernel: [ 1137.686789] usb 1-1.1: Device not responding to setup address.
May 7 12:46:01 octopi kernel: [ 1137.906598] usb 1-1.1: device not accepting address 30, error -71
May 7 12:46:01 octopi kernel: [ 1137.907288] usb 1-1-port1: unable to enumerate USB device
