Octoprint stopped connecting to my Ender 5 plus last month after it had always worked flawlessly before, I thought maybe it needed an update, but after update still did not connect.
Performing autodetection with 0 port/baudrate candidates:
Changing monitoring state from "Detecting serial connection" to "Error: No more candidates to test, and no working port/baudrate combination detected."
Changing monitoring state from "Error: No more candidates to test, and no working port/baudrate combination detected." to "Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)"
Ever thought you’re going crazy and turns out it’s too late?
I've been on it for more than a week without success, I've read all the posts I could find, but I'm really stuck.
I understand that the Octoprint can’t see the printer, thus cannot connect, the question is why?
Is there a port conflict or something?
I can’t imagine with all the below that it’s the USB cable or the board, all is ok, didn’t drop it or anything, just stopped one day, maybe Covid?
- Bigtreetech SKR1.4 turbo board with 4xTMC5160 SPI mode and S42B closed loop x driver => nope
- Same setup with TMC2209 UART => nope
- Tried 4 different micro-SD cards => nope
- Tried 3 different USB cables => nope
- Tried Octoprint in safe mode => nope
- Tried with laptop usb C power supply 5A => nope
- Tried Octoprint version 2021-01-11_2020-08-20-octopi-buster-arm64-lite-0.18.0 => nope
- Tried Octoprint version octopi-buster-lite-0.17.0 => nope
- Tried Octoprint version octopi-buster-armhf-lite-0.18.0 => nope
- Swapped back to original Creality v2.2 (8 bit) silentboard => nope
- Updated Creality firmware Ender-5PlusBLTouch_0904_V1.70.1 BL => nope and nope
- Tried Octoprint serial settings with and without Wait for
starton connect => nope and nope - Tried with and without Request exclusive access to the serial port => nope
- Tried with and without Enable automatic firmware detection=> nope
- Tried raising Initial baudrate detection pause to 2 or 3 seconds => nope
- Tried adding dev/ttyAMA0 => nope
- Tried adding dev/ttyS0 => nope
- Tried adding dev/ttyUSB => nope
- Tried baudrate 115200 as well as auto => nope
- Tried without Pi Cam connected => nope
- Tried all NL and GB locales => nope
- Tried Raspi-config serial on/on, off/on, on/off => nope, nope and nope
- Tried Raspi-config webcam off and on => nope and nope
- Tried tty port cleaner plugin => nope
- Tried firmware detection plug in upgrade => nope
- Tried rpi update (and immediately after, back to safe version) => nope and after still nope
- Tried apt-get upgrade => nope
- Tried apt-get update => nope
- Tried apt-get update -missing-fix => nope
- Tried chmod 666 /dev/ttyS0 and USB, USB0, USB1=> noperdenopenope
- Tried chmod 777 /dev/ttyS0 and USB, USB0, USB1 => still noperdenopenope
Printer connects with PC and Pronterface without problems in all configurations, motherboards and USB cables, Raspberry Pi? (you know by now,…..yeeeaaahhh => nope)
