Cannot connect to SKR v1.3 board
I cannot connect to my SKR v.1.3 board. It will time out after a bit. Printer will move axis via marlin menu.
I have tried both a Pi v3B and a Pi 4b. Have replaced USB cable and updated both Marlin and Octoprint. Marlin is v 2.0.9.2 and the Pi is running 1.70
Yes
No change
octoprint-logs.zip (498.8 KB)
Marlin is v 2.0.9.2 and the Pi is running 1.70. The printer is a Hypercube 300 core x/y, the browser is Chrome and OS is MacOS 11.6
Hello @roontoon !
You may try more different USB cables. Those with ferrite beads at the ends are for data transfer.
You may try this:
Try to connect to your Mac with Pronterface
Hello,
I saw numerous errors reported with plugins from runs yesterday, no tests with a printer connected before noon today. The log does not contain a run with Safe Mode enabled.
I used grep --text -F "octoprint.util.comm" octoprint.log to condense the connection-related lines from the log, for some strange reason grep treated the .log as a binary file and I had to force it into text mode.
OctoPrint tries the serial port on 7 different baud rates and gets no handshake.
It might help to look what the kernel sees of the connection.
For this please
  • ssh into the pi
  • pi/raspberry
  • unplug the usb cable
  • type into the console: sudo dmesg -w
  • hit enter 2 or 3 times to make a visible empty line
  • now plug in the usb cable
  • wait a few seconds until there is no more new text in the console
  • copy the lines that appeared after plugging the cable and
  • post them here
Thanks for the help. Here is the log.
[  109.521681] sd 0:0:0:0: [sda] Asking for cache data failed
[  109.521690] sd 0:0:0:0: [sda] Assuming drive cache: write through
[  109.522803] sd 0:0:0:0: Attached scsi generic sg0 type 0
[  114.159742]  sda: sda1
[  114.167419] sd 0:0:0:0: [sda] Attached SCSI removable disk
[  261.669488] usb 1-1.1: USB disconnect, device number 6
[  304.981898] usb 1-1.1: new full-speed USB device number 7 using xhci_hcd
[  305.119911] usb 1-1.1: New USB device found, idVendor=1d50, idProduct=6029, bcdDevice= 1.00
[  305.119931] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  305.119948] usb 1-1.1: Product: Marlin USB Device
[  305.119964] usb 1-1.1: Manufacturer: marlinfw.org
[  305.119979] usb 1-1.1: SerialNumber: 0E00A01CAF3C8CA75CFDC539F50020C3
[  305.129026] cdc_acm 1-1.1:1.0: ttyACM0: USB ACM device
[  305.134062] usb-storage 1-1.1:1.2: USB Mass Storage device detected
[  305.137761] scsi host0: usb-storage 1-1.1:1.2
[  306.154835] scsi 0:0:0:0: Direct-Access     Marlin   SDCard 01        1.0  PQ: 0 ANSI: 0 CCS
[  306.156798] sd 0:0:0:0: Attached scsi generic sg0 type 0
[  306.163221] sd 0:0:0:0: [sda] 245760 512-byte logical blocks: (126 MB/120 MiB)
[  306.164689] sd 0:0:0:0: [sda] Write Protect is off
[  306.164708] sd 0:0:0:0: [sda] Mode Sense: 00 00 00 00
[  306.172168] sd 0:0:0:0: [sda] Asking for cache data failed
[  306.172188] sd 0:0:0:0: [sda] Assuming drive cache: write through
[  306.224263]  sda: sda1
[  306.231192] sd 0:0:0:0: [sda] Attached SCSI removable disk
The kernel complains of no errors, sees a product, manufacturer and even a serialNumber. On some level the connection seems to work.
Does your printer have a SD card inserted? If so, when you take it out, do you see any change?
Tried that. No change.
