I cannot connect to my SKR v.1.3 board. It will time out after a bit. Printer will move axis via marlin menu.
I have tried both a Pi v3B and a Pi 4b. Have replaced USB cable and updated both Marlin and Octoprint. Marlin is v 2.0.9.2 and the Pi is running 1.70
Yes
No change
You can download this in OctoPrint's System Information dialog ... no bundle, no support!) octoprint-logs.zip (498.8 KB)
Marlin is v 2.0.9.2 and the Pi is running 1.70. The printer is a Hypercube 300 core x/y, the browser is Chrome and OS is MacOS 11.6
I saw numerous errors reported with plugins from runs yesterday, no tests with a printer connected before noon today. The log does not contain a run with Safe Mode enabled.
I used grep --text -F "octoprint.util.comm" octoprint.log to condense the connection-related lines from the log, for some strange reason grep treated the .log as a binary file and I had to force it into text mode.
OctoPrint tries the serial port on 7 different baud rates and gets no handshake.
It might help to look what the kernel sees of the connection.
For this please
ssh into the pi
pi/raspberry
unplug the usb cable
type into the console: sudo dmesg -w
hit enter 2 or 3 times to make a visible empty line
now plug in the usb cable
wait a few seconds until there is no more new text in the console
copy the lines that appeared after plugging the cable and
