**Camera model*Logitech C525'
**What is the problem?Will not stream - Webstream not loaded error
**What did you already try to solve it?Used all the settings for the C525 in tested camera FA
Logs ------------------------------------------------------------------------------
OctoPrint version : 1.4.2
OctoPi version : 0.17.0
**pi@octopi** : **~ $** lsusb
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 046d:0826 Logitech, Inc. HD Webcam C525
Bus 001 Device 003: ID 2c99:000c
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
**pi@octopi** : **~ $** /var/log/webcamd.log
Daemon log:
Oct 8 21:48:14 octopi systemd[1]: webcamd.service: Service RestartSec=100ms expired, scheduling restart.
Oct 8 21:48:14 octopi systemd[1]: webcamd.service: Scheduled restart job, restart counter is at 1.
Oct 8 21:48:14 octopi systemd[1]: Stopped the OctoPi webcam daemon with the user specified config.
Oct 8 21:48:14 octopi systemd[1]: Starting the OctoPi webcam daemon with the user specified config...
Oct 8 21:48:14 octopi webcamd[689]: Starting up webcamDaemon...
Oct 8 21:48:14 octopi webcamd[689]: --- Configuration: ----------------------------
Oct 8 21:48:14 octopi webcamd[689]: cfg_file: /boot/octopi.txt
Oct 8 21:48:14 octopi webcamd[689]: camera: USB
Oct 8 21:48:14 octopi webcamd[689]: usb options: -r 1280x720 -f 20 -y
Oct 8 21:48:14 octopi webcamd[689]: raspi options: -fps 10
Oct 8 21:48:14 octopi webcamd[689]: http options: -w ./www
Oct 8 21:48:14 octopi webcamd[689]: Explicitly USB device:
Oct 8 21:48:14 octopi webcamd[689]: -----------------------------------------------
Oct 8 21:48:14 octopi webcamd[689]: Found video devices:
Oct 8 21:48:14 octopi webcamd[689]: /dev/video0
Oct 8 21:48:14 octopi webcamd[689]: /dev/video1
Oct 8 21:48:14 octopi webcamd[689]: /dev/video10
Oct 8 21:48:14 octopi webcamd[689]: /dev/video11
Oct 8 21:48:14 octopi webcamd[689]: /dev/video12
Oct 8 21:48:14 octopi webcamd[689]: Scan again in two minutes
pi@octopi:~ $
I feel like the error has to do with the URL, but I have tried every combination I could find
