my old Pi3 (which was working fine externally) got broke and so I have just purchased a new Pi4, I have installed the test build from Raspberry Pi 4 is out
logged in and completed config using local IP, All Good...
using my external access I get the login window, but when I enter the username and password, upon pressing the login button I get a quick flash of the shaded background with the spinning dots and I am then returned to the login window with the URL amended from https://octopi.server.com to https://octopi.server.com/?
So I believe it to be an issue with my Letsencrypt Docker NGINX setup, however, this was working fine on my old setup with a Pi3
is it the case that it does not yet work on a Pi4? or do I need to adjust my config somehow now I am using a Pi4?
if I use the local IP then it is functioning as expected
thanks for the great software and any advice in advance
