When I go to octopi.local, it says that the site cannot be reached
I made sure everything is plugged in and turned on, I turned the pi off and on again, unplugged it waited for 10 seconds and then plugged back in, but I don't have any technical knowledge about so I'm not sure where to go from there. Because the server is down I cannot get my logs.
I have a raspberry pi 4, a Prusa i3 mk3, and I use chrome.
Sorry if there is information that you might need that is missing. This is the first time I have posted here and I am very new to octoprint and raspberry pis in general.
I only access mine by IP, though I give them a static IP (search and you'll see info on that). Here's the octopi.local thing- you can see it only works for specific cases and there are numerous places it can go wrong:
You don't need Bonjour on Windows. Windows has its own system already for this, but for some reason its not turned on by default. Its called NetBIOS via TCP/IP, you can enable this in your network adapter settings
To check if its Enabled type in your terminal "ipconfig /all"
it will show the following (all your network adapters will show, so check the one your using, in this case I'm using WIFI
