Savel
April 14, 2023, 7:36pm
1
Cant Connect to Printer / No serial Port Found
yes
no
You can download this in OctoPrint's System Information dialog ... no bundle, no support! )
dont know how i can do that, i have an rasp pi 4.
thx
Hello @Savel !
Savel:
That is a link to more info too.
Savel:
What printer?
Savel
April 14, 2023, 7:52pm
3
There was a sequence with a quite proper communication with the printer, but just quite.
There is a not stable communication to the printer, check for a goof, high quality and as short as possible USB cable. Als check for EMI source nearby.
Also, as this is a Creality printer, try with/without the SD card in the printer's SD card slot and also this:
First of all this whole tutorial isn't a mandatory mod - you just need it if you run into issues (weird things are happening and you've already ruled out the more common suspects) or if the always running fan and illuminated display (even when the printer is turned off) disturbes you.
I'm starting with the why part:
If you connect a 3D printer via USB to your Raspberry Pi it can lead to all sorts of power related issues.
Most of the time those issues occur only if you turn on your pi before β¦
system
Closed
July 14, 2023, 5:57am
6
