Raspberry Pi 4 up and running using the Nightly build img.
Functionality is working perfectly, great prints, I cant get the desktop environment to load. Is this due to that functionality not being present for the current build?
My Pi has internet access. I have a secured network but it the credentials are correctly configured and before I flashed octoprint, I could easily access google or the web chromium through raspian. When I run the script to install the desktop environment, a good portion runs ok, but there are some files that show unreachable.
Am I misunderstanding something? I apologize for any ignorance.
I can certainly try. Ill be home this evening and Ill try that.
So I flashed the nightly build for the Pi 4.
then it prompts with the script to install the desktop environment.
I run the script, some of it processes, and some doesnt, then it says its finished and asks if id like it setup so that it boots to desktop environment to which I answer yes. But it never does. Ive tried selecting it in config as well.
Rule of thumb: "it gives an error" is never enough information to help. Always copy down the error and any lines preceding it precisely and provide it when seeking help with something. That doesn't only apply to OctoPrint, it's a good idea in general. Error messages are supposed to help to figure out what went wrong. They can't serve that purpose if they are kept secret
I am not sure this is the case, but I have had problems with IPv6 to complete install packages or updates for raspbian. It says the same, it was unable to get some files. This is not a problem from the side of the raspberry pi. The router gave the raspberry pi IPv4 and IPv6 address, and so, it tries to reach some sites (software mirrors) on IPv6 when possible. I haven't pinpoint where the IPv6 resolution fails, but the end result is that some mirrors are unreachable and some of them just hang without for response stalling the installation of sofware. I may guess is a problem with settings on the internet service provider, like there is no good routing for IPv6. I can't change setting on the router to avoid assigning IPv6 to the devices at home.
Mi solution is to disable IPv6 for the raspberry pi, and then it works fine when trying to install packages or update. I have follow this guide: tech republic - how to disable ipv6
I hope this helps.
