WRITE HERE: (i'm new to this so bear with me please). I'm running the latest revision of the community firmware on my CR-6 the firmware works great and had no issues until I started with Octoprint. Machine heats up and homes, goes to the front left corner prints a (purge?) line from front left to rear left and then starts rear left to front left corner gets about half way stops, beeps and comes up with M112 error and machine has to be reset. Error message on the laptop shows that it keeps trying to send Line 29 but in the log shows there's a checksum issue. No idea on how to resolve this
Tried searching this forum, tried another file, printed same file directly from SD card a no issues so I know the file is good. Re-done ABL. Z axis when it stops jumps from 0.28mm to 2mm yet doesn't do this when running the machine standalone so believe it to be Octoprint issue and not hardware/firmware issue.
Yes
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/97.0.4692.71 Safari/537.36
connectivity.connection_check: 8.8.8.8:53
connectivity.enabled: True
connectivity.online: True
env.hardware.cores: 4
env.hardware.freq: 1800.0
env.hardware.ram: 1909063680
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi 4 Model B Rev 1.5
env.plugins.pi_support.octopi_version: 1.0.0
env.python.pip: 21.3.1
env.python.version: 3.9.2
env.python.virtualenv: True
octoprint.safe_mode: False
octoprint.version: 1.7.2
systeminfo.generator: zipapi
env.os.bits: 32
env.os.id: linux
