Died 8 hrs into a 10 hr print
  • moved it to Get Help - (Why do people use General when the need help?)
So, first this:
2021-01-31 14:00:38,400 - octoprint.plugins.pi_support - WARNING - This Raspberry Pi is reporting problems that might lead to bad performance or errors caused by overheating or insufficient power.
!!! UNDERVOLTAGE REPORTED !!! Make sure that the power supply and power cable are capable of supplying enough voltage and current to your Pi.
and then this:
2021-01-31 16:18:20,643 - octoprint.plugins.pi_support - WARNING - This Raspberry Pi is reporting problems that might lead to bad performance or errors caused by overheating or insufficient power.
!!! FREQUENCY CAPPING DUE TO OVERHEATING REPORTED !!! Improve cooling on the Pi's CPU and GPU.
You also have various issues with TSD
That is a surprise. Have a 3b+ with it's own supply--2.5 Amps. Will change to the supply for a 4. It shouldn't have overheated...It was a fileserver ever since the 3b came out and was on 24/7. The room the printer is in, is cold compared to the room it was in as a fileserver. According to NavBar it's been running from 55 or so up to almost 70. Oh, just looked at the times closer...I tried having the printer in the Creality enclosure, but was having problems with the print, so took it out of the enclosure. It could have been hot in the enclosure. Sorry, should have mentioned that. Is there a simple way to clear or rotate the logs when starting a new print?
I saw that, but my firmware is:Ender3-V2-Stock-20201225 from last December and I have done a 12 hr print recently. Did that firmware have problems like this?
Every Creality firmware has issues (especially the 32 bit ones), we are yet to see a 32 bit firmware for Ender 3 from Creality that doesn't have some sort of issue with it.
Do you recommend putting the latest (2021-02-02 on?
There's a reason we have
in
:wink:
No.
Not using from Creality...Have subscription with Marlin. I signed up with a subscription the day I got my printer, just after Christmas, because the facebook page talked about all the problems with the firmware shipped with the printer.
In that case @Charlie_Powell 's other recommendation applies:
On the Marlin site, I don't see those numbers. The latest for my printer looks to be: Ender3-V2-Stock-20210202?
I take it you are talking about https://marlin.crc.id.au/ when you say "the Marlin site"? Yes, we know, for some reason that page only seems to provide nightly builds, or at least doesn't mark up stable releases. Maybe as a paying customer that is feedback you should provide back to them.
In any case I fear I can't help you there and would have to refer you to building a stable build yourself if it can't be sourced from this service. The only thing I can tell you is this:
which is why we recommend a stable Marlin build, and what has already been said in this thread.
So, where do I get the Stable build? From Creality? I do not want to compile it myself, which is why I paid for a subscription. Sorry, meant to reply to Charlie_Powell.
As I said, if you can't download it from that service, you'll have to build it yourself. All you get from Creality is their own builds, and then we are back at recommending against THAT because their firmware sadly has even worse issues than the current Marlin nightlies.
I know this is frustrating, especially for a newbie, and I'm sorry for that experience. In general i can only recommend to learn how to build your own firmware from the source instead of relying on others to do it for you. As far as I can see, a matching firmware configuration should be here.
A 3d printer is far from a finished key ready product, requires tinkering, and firmware is part of that. You should take control over your experience. Luckily (or sadly, depending on how you look at it) that just involves learning.
Ok, I built the default config, but how do we know for example: which thermisistor in in our machine, or many of the others things, especially for temperatures. I followed the video for Marlin Auto Build. Is the default configuration ok to use? For instance I do not have BL touch, but I do have a Smart Filament Sensor.
On the Marlin site, there is are ready to use configuraion files:
Also here is info:
Yes, used it for trying to compile with auto build marlin, but what is enabled in the default there? Is the configuration what is described here: Ender 3 V2 - Stock - Marlin Firmware Service? Ei: stock with filament runout enabled?
You may have to check step by step what feature you need or not.
See above, I have no idea what components are shipped with the printer.
It explains everything on that site you linked that they have done to create that firmware:
If you take the stock config for Ender 3 V2 (out of the configurations repo linked to you above), then you add the things that they have mentioned (arc support, filament change, advanced ok, classic jerk, s curve acceleration, etc.), you reach the firmware build they have on the site. It is worth learning what components you have on your printer, since they can break, need adjusting, need replacing. You should be able to search the keywords in either Configuration.h and Configuration_adv.h files.
So what is said here is NOT in the provided config example? Are the 'Adds' there? For a new person who already has trouble with the terminology of the printer this is real confusing. The printer itself is not confusing. I am familiar with all the parts I see and have repaired my mainboard also. The terms for how all of them work is confusing. I am a Retired IT professional and have programmed an STM32 in the Blue pill, so basic programming is not the issue. It''s the terminology and the sheer number of all the things to worry about that makes it daunting.
