Bltouch 3.1 on Ender 3 v2 having issues with octoprint when doing the bed level probing and throwing a printer firmware error. If I print from the SD card it works 100% of the time. If I use Octoprint it works 30% of the time and the other 70% throws this error.
Running Smith3D firmware, reflashed with latest, both slow and fast and no difference.
Not sure if this is pertient or common buti hadn't mentioned it. When it crashes it locks up the Ender 3 v2 and it must be powered off and on to unlock it. So both OctoPrint and the Ender need to be reset.
Update Jan 29th - Did a full be releveling and reviewed in bed mesh. Still crashes.
yes
nope
Complete Logs
Recv: T:86.71 /205.00 B:45.02 /45.00 @:127 B@:38 W:?
Recv: echo:busy: processing
Recv: T:88.79 /205.00 B:45.05 /45.00 @:127 B@:26 W:?
Recv: T:89.45 /205.00 B:45.00 /45.00 @:127 B@:42
Recv: T:90.83 /205.00 B:45.00 /45.00 @:127 B@:42 W:?
Recv: T:93.22 /205.00 B:45.02 /45.00 @:127 B@:36 W:?
Recv: T:93.91 /205.00 B:45.02 /45.00 @:127 B@:35
Recv: T:95.26 /205.00 B:45.02 /45.00 @:127 B@:35 W:?
Recv: T:97.30 /205.00 B:45.00 /45.00 @:127 B@:40 W:?
Recv: T:97.96 /205.00 B:45.00 /45.00 @:127 B@:40
Recv: T:99.31 /205.00 B:45.02 /45.00 @:127 B@:34 W:?
Recv: T:101.56 /205.00 B:45.02 /45.00 @:127 B@:33 W:?
Recv: T:102.22 /205.00 B:45.02 /45.00 @:127 B@:33
Recv: T:103.47 /205.00 B:45.00 /45.00 @:127 B@:38 W:?
Recv: T:105.37 /205.00 B:45.00 /45.00 @:127 B@:37 W:?
Recv: T:106.01 /205.00 B:45.02 /45.00 @:127 B@:32
Recv: T:107.27 /205.00 B:45.03 /45.00 @:127 B@:26 W:?
Recv: T:109.43 /205.00 B:45.00 /45.00 @:127 B@:36 W:?
Recv: T:109.72 /205.00 B:45.02 /45.00 @:127 B@:31
Recv: T:111.29 /205.00 B:45.00 /45.00 @:127 B@:36 W:?
Recv: T:113.12 /205.00 B:45.00 /45.00 @:127 B@:36 W:?
Recv: T:113.75 /205.00 B:45.00 /45.00 @:127 B@:35
Recv: T:114.95 /205.00 B:44.98 /45.00 @:127 B@:41 W:?
Recv: T:117.05 /205.00 B:45.00 /45.00 @:127 B@:35 W:?
Recv: T:117.34 /205.00 B:45.00 /45.00 @:127 B@:35
Recv: T:118.83 /205.00 B:45.00 /45.00 @:127 B@:35 W:?
Recv: T:120.56 /205.00 B:45.00 /45.00 @:127 B@:35 W:?
Recv: T:121.16 /205.00 B:45.00 /45.00 @:127 B@:35
Recv: T:122.31 /205.00 B:45.02 /45.00 @:127 B@:30 W:?
Recv: T:123.97 /205.00 B:44.98 /45.00 @:127 B@:41 W:?
Recv: T:124.55 /205.00 B:45.02 /45.00 @:127 B@:29
Recv: T:125.96 /205.00 B:45.00 /45.00 @:127 B@:35 W:?
Recv: T:127.64 /205.00 B:45.00 /45.00 @:127 B@:35 W:?
Recv: T:128.21 /205.00 B:45.00 /45.00 @:127 B@:35
Recv: T:129.30 /205.00 B:45.00 /45.00 @:127 B@:35 W:?
Recv: T:130.90 /205.00 B:45.00 /45.00 @:127 B@:35 W:?
Recv: T:131.48 /205.00 B:45.00 /45.00 @:127 B@:35
Recv: T:132.80 /205.00 B:45.00 /45.00 @:127 B@:35 W:?
Recv: T:134.34 /205.00 B:45.00 /45.00 @:127 B@:35 W:?
Recv: T:134.87 /205.00 B:45.02 /45.00 @:127 B@:30
Recv: T:135.96 /205.00 B:45.00 /45.00 @:127 B@:35 W:?
Recv: T:137.56 /205.00 B:45.00 /45.00 @:127 B@:35 W:?
Recv: T:138.11 /205.00 B:45.02 /45.00 @:127 B@:29
Recv: T:139.37 /205.00 B:45.02 /45.00 @:127 B@:29 W:?
Recv: T:140.93 /205.00 B:45.02 /45.00 @:127 B@:29 W:?
Recv: T:141.42 /205.00 B:45.03 /45.00 @:127 B@:23
Recv: T:142.42 /205.00 B:45.00 /45.00 @:127 B@:33 W:?
Recv: T:143.90 /205.00 B:45.03 /45.00 @:127 B@:22 W:?
Recv: T:144.36 /205.00 B:45.00 /45.00 @:127 B@:33
Recv: T:145.57 /205.00 B:45.03 /45.00 @:127 B@:21 W:?
Recv: T:147.09 /205.00 B:45.05 /45.00 @:127 B@:15 W:?
Recv: T:147.54 /205.00 B:45.00 /45.00 @:127 B@:31
Recv: T:148.52 /205.00 B:45.02 /45.00 @:127 B@:25 W:?
Recv: T:149.90 /205.00 B:45.03 /45.00 @:127 B@:19 W:?
Recv: T:150.38 /205.00 B:45.02 /45.00 @:127 B@:24
Recv: T:151.59 /205.00 B:45.00 /45.00 @:127 B@:29 W:?
Recv: T:153.02 /205.00 B:45.02 /45.00 @:127 B@:24 W:?
Recv: T:153.44 /205.00 B:45.02 /45.00 @:127 B@:23
Recv: T:154.37 /205.00 B:45.02 /45.00 @:127 B@:23 W:?
Recv: T:155.74 /205.00 B:45.00 /45.00 @:127 B@:28 W:?
Recv: T:156.22 /205.00 B:45.00 /45.00 @:127 B@:28
Recv: T:157.14 /205.00 B:45.00 /45.00 @:127 B@:28 W:?
Recv: T:158.71 /205.00 B:45.00 /45.00 @:127 B@:28 W:?
Recv: T:159.15 /205.00 B:45.00 /45.00 @:127 B@:28
Recv: T:160.02 /205.00 B:45.00 /45.00 @:127 B@:28 W:?
Recv: T:161.41 /205.00 B:45.00 /45.00 @:127 B@:28 W:?
Recv: T:161.86 /205.00 B:45.00 /45.00 @:127 B@:28
Recv: T:162.76 /205.00 B:45.00 /45.00 @:127 B@:27 W:?
Recv: T:164.24 /205.00 B:45.03 /45.00 @:127 B@:16 W:?
Recv: T:164.74 /205.00 B:45.00 /45.00 @:127 B@:27
Recv: T:165.56 /205.00 B:45.02 /45.00 @:127 B@:22 W:?
Recv: T:166.86 /205.00 B:45.00 /45.00 @:127 B@:27 W:?
Recv: T:167.24 /205.00 B:45.00 /45.00 @:127 B@:27
Recv: T:168.06 /205.00 B:45.00 /45.00 @:127 B@:27 W:?
Recv: T:169.48 /205.00 B:45.00 /45.00 @:127 B@:27 W:?
Recv: T:169.72 /205.00 B:45.00 /45.00 @:127 B@:27
Recv: T:170.74 /205.00 B:45.00 /45.00 @:127 B@:27 W:?
Recv: T:172.01 /205.00 B:45.00 /45.00 @:127 B@:27 W:?
Recv: T:172.44 /205.00 B:45.02 /45.00 @:127 B@:21
Recv: T:173.18 /205.00 B:45.00 /45.00 @:127 B@:27 W:?
Recv: T:174.69 /205.00 B:45.00 /45.00 @:127 B@:27 W:?
Recv: T:174.80 /205.00 B:45.00 /45.00 @:127 B@:27
Recv: T:175.75 /205.00 B:45.00 /45.00 @:127 B@:27 W:?
Recv: T:177.00 /205.00 B:45.00 /45.00 @:127 B@:27 W:?
Recv: T:177.33 /205.00 B:45.02 /45.00 @:127 B@:21
Recv: T:178.15 /205.00 B:45.02 /45.00 @:127 B@:21 W:?
Recv: T:179.29 /205.00 B:45.00 /45.00 @:127 B@:26 W:?
Recv: T:179.67 /205.00 B:45.00 /45.00 @:127 B@:26
Recv: T:180.58 /205.00 B:45.00 /45.00 @:127 B@:26 W:?
Recv: T:181.83 /205.00 B:45.00 /45.00 @:127 B@:26 W:?
Recv: T:182.19 /205.00 B:45.00 /45.00 @:127 B@:26
Recv: T:182.98 /205.00 B:45.00 /45.00 @:127 B@:26 W:?
Recv: T:184.13 /205.00 B:45.00 /45.00 @:127 B@:26 W:?
Recv: T:184.50 /205.00 B:45.00 /45.00 @:127 B@:26
Recv: T:185.42 /205.00 B:45.00 /45.00 @:127 B@:26 W:?
Recv: T:186.64 /205.00 B:45.00 /45.00 @:127 B@:26 W:?
Recv: T:187.01 /205.00 B:45.00 /45.00 @:127 B@:26
Recv: T:187.55 /205.00 B:45.00 /45.00 @:127 B@:26 W:?
Recv: T:188.75 /205.00 B:45.00 /45.00 @:127 B@:26 W:?
Recv: T:189.17 /205.00 B:45.00 /45.00 @:127 B@:26
Recv: T:190.00 /205.00 B:45.00 /45.00 @:127 B@:26 W:?
Recv: T:190.99 /205.00 B:45.00 /45.00 @:127 B@:26 W:?
Recv: T:191.36 /205.00 B:45.00 /45.00 @:127 B@:26
Recv: T:192.22 /205.00 B:45.00 /45.00 @:127 B@:26 W:?
Recv: T:193.18 /205.00 B:45.00 /45.00 @:127 B@:26 W:?
Recv: T:193.64 /205.00 B:45.00 /45.00 @:127 B@:26
Recv: T:194.52 /205.00 B:45.00 /45.00 @:127 B@:26 W:?
Recv: T:195.45 /205.00 B:45.02 /45.00 @:127 B@:20 W:?
Recv: T:195.68 /205.00 B:45.02 /45.00 @:127 B@:20
Recv: T:196.36 /205.00 B:45.00 /45.00 @:126 B@:26 W:?
Recv: T:197.27 /205.00 B:45.00 /45.00 @:118 B@:26 W:?
Recv: T:197.61 /205.00 B:45.00 /45.00 @:114 B@:26
Recv: T:198.21 /205.00 B:45.00 /45.00 @:112 B@:26 W:?
Recv: T:199.09 /205.00 B:44.98 /45.00 @:105 B@:32 W:?
Recv: T:199.55 /205.00 B:45.00 /45.00 @:98 B@:26
Recv: T:200.00 /205.00 B:45.00 /45.00 @:96 B@:26 W:?
Recv: T:200.76 /205.00 B:45.00 /45.00 @:90 B@:26 W:?
Recv: T:201.11 /205.00 B:45.00 /45.00 @:86 B@:26
Recv: T:201.67 /205.00 B:45.00 /45.00 @:80 B@:26 W:?
Recv: T:202.22 /205.00 B:45.00 /45.00 @:81 B@:25 W:?
Recv: T:202.53 /205.00 B:45.00 /45.00 @:76 B@:25
Recv: T:202.78 /205.00 B:45.00 /45.00 @:77 B@:25 W:?
Recv: T:203.33 /205.00 B:44.98 /45.00 @:73 B@:31 W:?
Recv: T:203.33 /205.00 B:45.00 /45.00 @:76 B@:25
Recv: T:203.44 /205.00 B:45.02 /45.00 @:79 B@:19 W:?
Recv: T:203.89 /205.00 B:45.00 /45.00 @:76 B@:24 W:?
Recv: T:203.89 /205.00 B:45.00 /45.00 @:78 B@:24
Recv: T:203.89 /205.00 B:45.03 /45.00 @:82 B@:13 W:?
Recv: T:203.89 /205.00 B:45.02 /45.00 @:87 B@:18 W:?
Recv: T:203.89 /205.00 B:45.00 /45.00 @:89 B@:24
Recv: T:203.92 /205.00 B:45.00 /45.00 @:90 B@:23 W:?
Recv: T:204.24 /205.00 B:45.00 /45.00 @:86 B@:23 W:9
Recv: T:204.10 /205.00 B:45.00 /45.00 @:90 B@:23
Recv: T:204.41 /205.00 B:45.02 /45.00 @:85 B@:17 W:8
Recv: T:204.44 /205.00 B:45.00 /45.00 @:87 B@:23 W:7
Recv: T:204.41 /205.00 B:45.00 /45.00 @:89 B@:23
Recv: T:204.44 /205.00 B:45.02 /45.00 @:89 B@:17 W:6
Recv: T:204.44 /205.00 B:45.00 /45.00 @:92 B@:22 W:5
Recv: T:204.44 /205.00 B:45.00 /45.00 @:93 B@:22 W:4
Recv: T:204.51 /205.00 B:45.00 /45.00 @:93 B@:22 W:3
Recv: T:204.79 /205.00 B:45.00 /45.00 @:86 B@:22
Recv: T:205.00 /205.00 B:45.00 /45.00 @:82 B@:22 W:2
Recv: T:205.00 /205.00 B:45.00 /45.00 @:84 B@:22 W:1
Recv: T:205.04 /205.00 B:45.00 /45.00 @:84 B@:22 W:0
Recv: ok
Send: N8 M8217
Recv: ok
Send: N9 G92 E078
Recv: X:0.00 Y:0.00 Z:0.00 E:0.00 Count X:0 Y:0 Z:0
Recv: ok
Send: N10 G2834
Recv: T:205.51 /205.00 B:45.00 /45.00 @:73 B@:22
Recv: T:205.62 /205.00 B:45.00 /45.00 @:73 B@:22
Recv: T:205.62 /205.00 B:45.00 /45.00 @:73 B@:21
Recv: T:205.35 /205.00 B:45.00 /45.00 @:80 B@:21
Recv: T:205.00 /205.00 B:45.00 /45.00 @:85 B@:21
Recv: T:205.00 /205.00 B:45.00 /45.00 @:84 B@:21
Recv: T:205.00 /205.00 B:45.00 /45.00 @:83 B@:21
Recv: T:205.04 /205.00 B:45.00 /45.00 @:81 B@:21
Recv: T:205.47 /205.00 B:44.98 /45.00 @:70 B@:28
Recv: T:205.55 /205.00 B:44.98 /45.00 @:69 B@:28
Recv: T:205.12 /205.00 B:44.98 /45.00 @:81 B@:28
Recv: X:147.00 Y:117.00 Z:13.18 E:0.00 Count X:11760 Y:9360 Z:5272
Recv: ok
Send: N11 G2934
Recv: T:205.00 /205.00 B:45.00 /45.00 @:80 B@:22
Recv: T:204.86 /205.00 B:45.00 /45.00 @:83 B@:23
Recv: T:204.83 /205.00 B:45.00 /45.00 @:83 B@:23
Recv: T:204.93 /205.00 B:45.00 /45.00 @:81 B@:23
Recv: T:205.00 /205.00 B:45.00 /45.00 @:79 B@:23
Recv: T:205.00 /205.00 B:45.02 /45.00 @:80 B@:17
Recv: T:205.00 /205.00 B:45.00 /45.00 @:80 B@:23
Recv: T:205.00 /205.00 B:44.98 /45.00 @:80 B@:29
Recv: T:204.97 /205.00 B:45.02 /45.00 @:81 B@:17
Recv: T:205.00 /205.00 B:45.02 /45.00 @:80 B@:16
Recv: T:205.00 /205.00 B:45.03 /45.00 @:80 B@:10
Recv: T:205.00 /205.00 B:45.00 /45.00 @:80 B@:21
Recv: T:205.00 /205.00 B:45.02 /45.00 @:80 B@:15
Recv: T:205.00 /205.00 B:44.98 /45.00 @:80 B@:26
Recv: T:205.00 /205.00 B:45.00 /45.00 @:80 B@:20
Recv: T:205.00 /205.00 B:45.00 /45.00 @:80 B@:19
Recv: T:204.97 /205.00 B:45.00 /45.00 @:81 B@:19
Recv: T:204.93 /205.00 B:45.00 /45.00 @:82 B@:19
Recv: T:204.97 /205.00 B:45.00 /45.00 @:81 B@:20
Recv: T:205.00 /205.00 B:45.00 /45.00 @:81 B@:20
Recv: Error:Probing Failed
Changing monitoring state from "Printing" to "Error: Probing Failed"
Send: M112
Send: N12 M11218
Send: N13 M104 T0 S019
Send: N14 M140 S0*80
Changing monitoring state from "Error: Probing Failed" to "Offline (Error: Probing Failed)"
Octoprint : Version 1.5.3
OctoPi : Version 0.17.0, running on Raspberry Pi 3 Model B Rev 1.2
Printer : Ender 3 v2 running Smith3d 2.0.x.16 5x5 Fast 100121.bin
Sorry you've found it but at least now i know it's not just me. I've even reloaded octoprint on my raspberry pi 3 times now and it makes no difference. With plugins/without plugins, doesn't matter. I get at least an 80% failure rate and seems to be an octoprint issue only. Just like yourself I can print from the SD card on the printer directly with no failures.
