Error Probing Failed
Ok I will check that too.... Besides Smith3D I can only found another solution from th3dstudio.com, they provide a firmware for our printer but he way I see if changing the lcd firmware too.
Hi @Fil ,
I've done two things to try to fix the Probing Failed and until now I don't have any fail and I already have done lots of probing test through Octoprint...
1- I compiled myself the Marling with last version and with Smith3d menus (because the features they have);
2- I tightened the top screw of my BLtouch (half a turn in clockwise direction).
The firmware is ready for Ender 3 v2 with BLtouch v3.1
Try and give us feedback.
Download here
Thanks. Sounds promising I'll give it a shot. Didn't have the time this weekend to work on this.
Did you get this message?
Info: Firmware Development Build
Your printer's firmware is a development build. It might be more unstable than a release version and should be updated regularly.
Thanks,
Fil
So completed one short print and on just kicking off a 3hr print and so far so good.
Excellent news! Give us feedback after some more tries.
About the message is because the Marlin is the last Nightly Built, in other words, is the last version plus everyday fixes they do so of course there's a possibility to have some type of bugs but maybe little things that will not be important for us... who knows...
I also tried your compiled firmware, and so far it works perfect. I like the extra info at the bottom of the LCD, nice touch.
Cool, good to know.
That extra info comes already in this last Marlin build.
I will do some more tests and try to make the leveling a little more faster.
Btw I give more 1cm of possible bed using (23cm x 23cm) vs the 22cm x 22cm.
As I see it's possible to personalize the menus with GCODE macros (like Smith3D does) which is cool.
If anyone has ideas for useful things tell me... for now I'm using the menu's from Smith3D and I know the Marlin is open source but I don't know if Smith3D care about me using this part of their work
So far so good..have completed half a dozen prints with zero failures so I would say it was definitely something in the Smith3d firmware that was messed up.
Cool... I've done some prints too using Octoprint and everythings works fine too.
I suspect of a option to use 5v in BLtouch. for BLtouch version 3.0 and 3.1 that option is a must to have to have better stability in the BLtouch... but as I'm saying is just a suspecion...
I will try to study a little more the Marlin and maybe create some useful functions in the menus but without mess with the firmware core.
Hi folks,
Made some improvements/activation of features:
  • BLtouch is probing a little faster and doing 3 probes in each probing point and take the average of them (I think with my tests this approach is more reliable);
  • Activated EXTRAPOLATE_BEYOND_GRID function (to extrapolate probing grid where BLtouch can't go)
  • Activated M600 - Filament Change feature (see in Marlin manual);
  • Removed Smith3D url in titles (just aesthetics, the features in menu are 100% developed by them so all credits for them!)
firmware-20210222-172838.zip (119.1 KB)
It would be nice if you also include the sources
So other users can check which things you changed and build the firmware on their own :slight_smile:
I was just about to mention this. I like your (@phenriques3000) firmware very much, but I do intent to add a Bullseye mod (Petsfang v2) which requires custom values for my BLTouch offset in the firmware.
Unless there's another way off course?
Hi folks,
The only changes I made was in the configuration, the firmware core are based on the bugfix-2.x of Marlin.
Anyways please use my git repository, I made it public some minutes ago:
You're the greatest. I'm also running your latest firmware firmware-20210222-172838.zip and works great. :+1:t3:
Hi folks,
I have encountered the exact same issue. Same log, same fix with phenriques3000 firmware. Interesting thing : I had the issue with Jyer firmware, which replaced the smith3D one (see latest news here).
I could have stop here, but as grateful I am with phenriques work, I use a filament sensor which is not supported by this firmware. Building my own firmware is not a option at the moment, I would love to learn how to but I lack of time.
I read around here that it might have something to do with a "#define Z_PROBE_LOW_POINT" value. That's when it hit me : I have a -3.05 z-offset. I realized that Smith3D suggest to print a BL Touch mount. I didn't do that because I bought the creality BLTouch kit espacialy made for ender 3 v2, so a metal mount was already provided. So I printed the v2 version, which give me a -0.12 offset. I tried the Jyers firmware again and find out that with a lower z-offset, it works without any issue.
Did you guys used the original mount, and do you have a "big" z-offset value, around -3 ?
If that's the case, maybe we can make a suggestion for a pull request on the Jyers firmware to fix this value !
Z_PROBE_LOW_POINT defines the lowest probing point.
That means if a probing point is lower than that value (compared to the initial Z homing point) the probing will be stopped.
I guess your bed was very uneven if the probing failed because of that.
Thank for your answer PrintedWeezl and thank you for your work : without this forum, I would never have found a solution to this issue.
But no really, it isn't a matter of uneven bed: it was perfectly leveled, as that was the case for @Fil , @phenriques3000. I didn't save the bed levelling value at that time, but the fact was that I was able to print without any issue from SD card, and that the probing failure happens only with the Jyer firmware when trying to print from octoprint. Without modifiying leveling at all and only updating the firmware with @phenriques3000 one's, it solved the issue : I was able to print sucessfully from octoprint and the SD card with the same bed leveling.
What I'm trying to say here is that this is due to the firmware (old Smith3D or Jyers) which doesn't accept the z-offset that the official creality BLTouch mount need, which is around -3mm.
I don't have the skill to provide a fix for the Jyers firmware, but if someone met the same issue, we now have a explanation about why one firmware work and the other doesn't.
Hey all... I’m new to all this and usually make myself sound really, really stupid lol but I too was having these probing issues. Seemed I could print off the SD card fine but the moment octoprint came into the equation my probing success rate dropped to like ~30% success. I’m using the jyers firmware with some custom tweaks specific to my needs(mainly size, speeds and probing grid) I have tested from stock creality firmware(ew) to preconfigured firmwares(not just jyers) looking for a fix. Given how all of them gave me similar results I’ve settled on the jyers cuz damn is it awesome.
Per this thread I saw that enabling the 5v in configuration.adv fixed many’s issues here. I made that change myself in the firmware and was able to achieve a 100% success rate when it came to probing with prints using octoprint. Before @phenriques3000 found the 5v thing the workaround to this (per jyers GitHub)was to set octoprint to ignore errors however under these settings the probing would still fail at about the same failure/success rate as before I just wouldn’t have to power cycle the printer to get it out of its m112 state.I also wasn’t comfortable with it “skipping” however many points were left and just moving to the print. when I posted this potential fix on the jyers GitHub (here: BLTouch 3.0 and 3.1 Info/ Possible fix for M112 failed probing · Discussion #603 · Jyers/Marlin · GitHub )many on the GitHub are saying this is damaging to our printers. That the processor is a 3.3v system.
I’d love to help get a proper fix to this. I’m new to the whole 3D printing world but I am sorta tech savvy. Curious what others think about the whole 5v situation or not. Have you guys been running it with no errors this whole time?
I’d like to get 100% success rate in probing as well as use octoprint but I’m not sure if it’s the bltouch(which seems to work) octoprint(which also seems to work) or the printer(again all in good working order) or the firmware settings. I don’t want to fry my main board by over volting but I really want the same success in probing as my cr10 v3 with the exact same bltouch kit
Hi @DeathDonky,
If your BLTouch is the version 3.0 or 3.1 you can and must use the 5v.
This will not fry your mainboard, if something is possible to fry is the BLtouch if you are not using the correct one (after all we are controlling the output voltage from the mainboard to the BLtouch not the opposite...).
I'm still using the firmware I posted here and I can say that I print almost every days things in the printer and with 100% success rate since day 1 of the firmware!
Just for info the BLtouch have itself a couple of resistors to regulate the voltage inside from 3.3-5v input to 3.3v so this is why I think the BLtouch works better if we apply the maximum input voltage (5v, you can check this in documentation from Antlabs) and in this case if we have some input fluctuations it doesn't matter because the input voltage to the BLTouch will always be more than 3.3v.
Hope this explanation helps.
