Flashforge creator - will it work
Will octoprint work with my creator. If not can I upgrade to creator pro or some other way to use octoprint
Nothing yet
Complete Logs
Hello @chuckuntulis!
This site has a quite good search function. Searching for Flashforge will give you 37 results. One of these is this:
I was wondering if anyone had checked into the anycubic kobra 2 pro. I would like to use octoprint, but I keep seeing that it will not connect. But I do not see it on your list. Can this be verified?
Hello @Radratonly !
This thread is about the Flashforge Creator.
There is another one for the Kobra 2
Please stick to the new thread, not the ancient ones.
