First I used the commandes lsusb and dmesg to confirm that I have indeed selected the correct Serial Port,I have the Baudrate set to auto, first it "Detecting serial connection" then it hangs on "connecting" intill it times out and i have changed the timeout time to 20 secs
I will try the tap trick and tell you what happen, for this problem "/home/pie/oprint/lib/python3.9/" that i believe is because the username I choose is pie and not pi, also thanks for responding.
You also don't need both temperature fix plugins for creality, I'd recommend sticking with the Creality-2x-temperature-reporting-fix (0.0.4) one and removing the other. And UI Customizer is way better than Themeify.
You could try manually setting the baud rate to 115200 instead of using Auto. And the 5v usb power isolation (tape fix or other) is definitely something you want to do.
one slight change all my cables are bad even though they can transfer data from my pc to my phone, what is a known working cable that is good for what I am trying to do?
Just to confirm, you're plugging into the front usb-c port on the printer, next to the SD card and OctoPrint sees the port, just never is able to connect properly?
For me because I have the ender 3 S-1 Pro The chip that I had was the "Stm32F103"so that is the firmware I did, if you do it wrong you might get an error saying "Your printer's firmware reported an error. Due to that OctoPrint will disconnect. Reported error: Must home axis first: 0.000 0.000 10.000 [0.000]"
