Thanks For Letting me in. How to find the IP address of this software?
You can can check for the ip on your router or try http://octopi.local / http://octopi
If http://octopi.local doesn't work read this
login to the console, after you've done the raspi-config routine, rebooted a few times, changed your password. Run the command "ifconfig" lists all the IP Info... Like IPconfig in Windoooows.
Iirc ifconfig isn't installed by default anymore.
Use ip a instead
You can also install this plugin and it will send the ip address to the printer on a successful connection.
