Logitech C270 Not working even if detected
Camera Model: Logitech C270
Once i've configured the octopi.txt file for my camera model, enable de camera interface in the rpi it does not show any image. Even if it shown in the lsusb output, it still does not work.
lsusb output
Bus 001 Device 005: ID 046d:0825 Logitech, Inc. Webcam C270
Bus 001 Device 004: ID 1eaf:0004
Bus 001 Device 006: ID 0424:7800 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
I tried check logs on /var/log/webcam.log, syslog and dmesg but it does not show any relevant information to help me solve the problem. I also modified the octopi.txt file with different configurations like specfiying a device, specifying different frame rates and the -y arg but nothing works (Followed the following supported cameras post).Any one can help me?
My Octopi.txt Configuration
camera="auto"
camera_usb_options="-r 1280x720 -f 30"
camera_http_webroot="./www"
camera_http_options=""
---------------------------------------------Logs---------------------------------------------
---------------/var/log/webcamd.log---------------
Starting up webcamDaemon...
/boot/octopi.txt: line 3: $'\r': command not found
/boot/octopi.txt: line 6: $'\r': command not found
/boot/octopi.txt: line 17: $'\r': command not found
/boot/octopi.txt: line 25: $'\r': command not found
/boot/octopi.txt: line 53: $'\r': command not found
/boot/octopi.txt: line 64: $'\r': command not found
/boot/octopi.txt: line 78: $'\r': command not found
cfg_file:      /boot/octopi.txt
camera:        usb
usb options:   -r 1280x720 -f 15
raspi options: -fps 10
 ttp options:  -w ./www
Explicitly USB device:
Found video devices:
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
Scan again in two minutes
/root/bin/webcamd: line 103: kill: (876) - No such process
Goodbye...
'---------------syslog---------------'
Starting the OctoPi webcam daemon with the user specified config...
Aug 23 14:20:28 octopi systemd[1]: webcamd.service: Start operation timed out. Terminating.
Aug 23 14:20:28 octopi systemd[1]: webcamd.service: Failed with result 'timeout'.
Aug 23 14:20:28 octopi systemd[1]: Failed to start the OctoPi webcam daemon with the user specified config.
Aug 23 14:20:29 octopi systemd[1]: webcamd.service: Service RestartSec=1s expired, scheduling restart.
Aug 23 14:20:29 octopi systemd[1]: webcamd.service: Scheduled restart job, restart counter is at 5.
Aug 23 14:20:29 octopi systemd[1]: Stopped the OctoPi webcam daemon with the user specified config.
---------------dmesg log---------------
Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.10.52-v7+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1441 SMP Tue Aug 3 18:10:09 BST 2021
[    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
[    0.000000] random: fast init done
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] Reserved memory: created CMA memory pool at 0x34000000, size 64 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000000000-0x0000000037ffffff]
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000037ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000037ffffff]
[    0.000000] On node 0 totalpages: 229376
[    0.000000]   DMA zone: 2016 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 229376 pages, LIFO batch:63
[    0.000000] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
[    0.000000] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 227360
[    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 console=ttyS0,115200 root=PARTUUID=96eda0b7-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[    0.000000] Kernel parameter elevator= does not have any effect anymore.
               Please use sysfs to set IO scheduler for individual devices.
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 826024K/917504K available (10240K kernel code, 1312K rwdata, 2948K rodata, 1024K init, 863K bss, 25944K reserved, 65536K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 32043 entries in 63 pages
[    0.000000] ftrace: allocated 63 pages with 6 groups
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] random: get_random_bytes called from start_kernel+0x3ac/0x580 with crng_init=1
[    0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.000023] Switching to timer-based delay loop, resolution 52ns
[    0.000310] Console: colour dummy device 80x30
[    0.001166] printk: console [tty1] enabled
[    0.001237] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[    0.001295] pid_max: default: 32768 minimum: 301
[    0.001516] LSM: Security Framework initializing
[    0.001773] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.001822] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.003269] cgroup: Disabling memory control group subsystem
[    0.003551] CPU: Testing write buffer coherency: ok
[    0.004049] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.005303] Setting up static identity map for 0x100000 - 0x10003c
[    0.005512] rcu: Hierarchical SRCU implementation.
[    0.006449] smp: Bringing up secondary CPUs ...
[    0.007606] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.008873] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.010177] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.010336] smp: Brought up 1 node, 4 CPUs
[    0.010389] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[    0.010420] CPU: All CPU(s) started in HYP mode.
[    0.010446] CPU: Virtualization extensions available.
[    0.011430] devtmpfs: initialized
[    0.028917] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[    0.029248] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.029308] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.032531] pinctrl core: initialized pinctrl subsystem
[    0.033706] NET: Registered protocol family 16
[    0.037760] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.043488] audit: initializing netlink subsys (disabled)
[    0.044395] thermal_sys: Registered thermal governor 'step_wise'
[    0.045256] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
[    0.045487] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.045527] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.045838] Serial: AMBA PL011 UART driver
[    0.064748] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[    0.080177] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-08-03T18:18:41, variant start_x
[    0.090188] raspberrypi-firmware soc:firmware: Firmware hash is 40787ee5905644f639a2a0f6e00ae12e517a2211
[    0.134517] Kprobes globally optimized
[    0.139573] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
[    0.142020] SCSI subsystem initialized
[    0.142289] usbcore: registered new interface driver usbfs
[    0.142375] usbcore: registered new interface driver hub
[    0.142476] usbcore: registered new device driver usb
[    0.144465] clocksource: Switched to clocksource arch_sys_counter
[    1.918276] VFS: Disk quotas dquot_6.6.0
[    1.918423] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.918647] FS-Cache: Loaded
[    1.918890] CacheFiles: Loaded
[    1.928879] NET: Registered protocol family 2
[    1.929149] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    1.930575] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    1.930755] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    1.930901] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    1.931115] TCP: Hash tables configured (established 8192 bind 8192)
[    1.931303] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    1.931380] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    1.932071] NET: Registered protocol family 1
[    1.932865] RPC: Registered named UNIX socket transport module.
[    1.932900] RPC: Registered udp transport module.
[    1.932929] RPC: Registered tcp transport module.
[    1.932957] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.934729] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[    1.938507] Initialise system trusted keyrings
[    1.938811] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    1.948394] zbud: loaded
[    1.950480] FS-Cache: Netfs 'nfs' registered for caching
[    1.951400] NFS: Registering the id_resolver key type
[    1.951472] Key type id_resolver registered
[    1.951501] Key type id_legacy registered
[    1.951672] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.951707] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    1.952913] Key type asymmetric registered
[    1.952946] Asymmetric key parser 'x509' registered
[    1.953017] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    1.953057] io scheduler mq-deadline registered
[    1.953086] io scheduler kyber registered
[    1.956555] bcm2708_fb soc:fb: FB found 1 display(s)
[    1.968149] Console: switching to colour frame buffer device 82x26
[    1.975355] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 656x416
[    1.983927] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[    1.987347] bcm2835-aux-uart 3f215040.serial: there is not valid maps for state default
[    1.994167] bcm2835-rng 3f104000.rng: hwrng registered
[    1.997309] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[    2.003480] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[    2.021526] brd: module loaded
[    2.036394] loop: module loaded
[    2.040803] Loading iSCSI transport class v2.0-870.
[    2.045175] libphy: Fixed MDIO Bus: probed
[    2.048181] usbcore: registered new interface driver lan78xx
[    2.050962] usbcore: registered new interface driver smsc95xx
[    2.053570] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    2.784372] Core Release: 2.80a
[    2.787015] Setting default values for core params
[    2.789671] Finished setting default values for core params
[    2.992682] Using Buffer DMA mode
[    2.995256] Periodic Transfer Interrupt Enhancement - disabled
[    2.997830] Multiprocessor Interrupt Enhancement - disabled
[    3.000374] OTG VER PARAM: 0, OTG VER FLAG: 0
[    3.002869] Dedicated Tx FIFOs mode
[    3.005863] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = b4114000 dma = 0xf4114000 len=9024
[    3.012779] FIQ FSM acceleration enabled for :
               Non-periodic Split Transactions
               Periodic Split Transactions
               High-Speed Isochronous Endpoints
               Interrupt/Control Split Transaction hack enabled
[    3.023646] dwc_otg: Microframe scheduler enabled
[    3.023724] WARN::hcd_init_fiq:457: FIQ on core 1
[    3.028034] WARN::hcd_init_fiq:458: FIQ ASM at 807c8de0 length 36
[    3.032449] WARN::hcd_init_fiq:497: MPHI regs_base at b8810000
[    3.036890] dwc_otg 3f980000.usb: DWC OTG Controller
[    3.039194] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[    3.041555] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
[    3.043867] Init: Port Power? op_state=1
[    3.046106] Init: Power Port (0)
[    3.048616] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    3.053173] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.055639] usb usb1: Product: DWC OTG Controller
[    3.057982] usb usb1: Manufacturer: Linux 5.10.52-v7+ dwc_otg_hcd
[    3.060358] usb usb1: SerialNumber: 3f980000.usb
[    3.063449] hub 1-0:1.0: USB hub found
[    3.065900] hub 1-0:1.0: 1 port detected
[    3.069479] dwc_otg: FIQ enabled
[    3.069493] dwc_otg: NAK holdoff enabled
[    3.069504] dwc_otg: FIQ split-transaction FSM enabled
[    3.069522] Module dwc_common_port init
[    3.069830] usbcore: registered new interface driver usb-storage
[    3.072622] mousedev: PS/2 mouse device common for all mice
[    3.076267] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[    3.081491] sdhci: Secure Digital Host Controller Interface driver
[    3.084011] sdhci: Copyright(c) Pierre Ossman
[    3.087274] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
[    3.090530] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[    3.093347] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.097719] ledtrig-cpu: registered to indicate activity on CPUs
[    3.100721] hid: raw HID events driver (C) Jiri Kosina
[    3.103465] usbcore: registered new interface driver usbhid
[    3.106094] usbhid: USB HID core driver
[    3.113580] Initializing XFRM netlink socket
[    3.116238] NET: Registered protocol family 17
[    3.118846] Key type dns_resolver registered
[    3.121862] Registering SWP/SWPB emulation handler
[    3.124354] registered taskstats version 1
[    3.126710] Loading compiled-in X.509 certificates
[    3.129905] Key type ._fscrypt registered
[    3.132221] Key type .fscrypt registered
[    3.134570] Key type fscrypt-provisioning registered
[    3.148501] uart-pl011 3f201000.serial: cts_event_workaround enabled
[    3.150980] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
[    3.157893] bcm2835-aux-uart 3f215040.serial: there is not valid maps for state default
[    3.163349] printk: console [ttyS0] disabled
[    3.165913] 3f215040.serial: ttyS0 at MMIO 0x3f215040 (irq = 86, base_baud = 50000000) is a 16550
[    4.286072] printk: console [ttyS0] enabled
[    4.293726] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[    4.305321] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[    4.313971] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[    4.323910] Indeed it is in host mode hprt0 = 00021501
[    4.405917] sdhost: log_buf @ (ptrval) (f4113000)
[    4.450238] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    4.460101] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    4.468271] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    4.479481] of_cfs_init
[    4.484624] of_cfs_init: OK
[    4.491292] Waiting for root device PARTUUID=96eda0b7-02...
[    4.498150] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    4.510642] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    4.544515] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    4.553592] Indeed it is in host mode hprt0 = 00001101
[    4.645102] mmc0: host does not support reading read-only switch, assuming write-enable
[    4.664025] mmc0: new high speed SDHC card at address aaaa
[    4.673047] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
[    4.685693]  mmcblk0: p1 p2
[    4.702746] mmc1: new high speed SDIO card at address 0001
[    4.720483] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    4.733311] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    4.752820] devtmpfs: mounted
[    4.765122] Freeing unused kernel memory: 1024K
[    4.795030] Run /sbin/init as init process
[    4.795338] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[    4.801618]   with arguments:
[    4.814941] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    4.815737] hub 1-1:1.0: USB hub found
[    4.824948]     /sbin/init
[    4.824961]   with environment:
[    4.831445]     HOME=/
[    4.831456]     TERM=linux
[    4.831552] hub 1-1:1.0: 4 ports detected
[    5.154524] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    5.284885] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[    5.298983] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    5.310191] hub 1-1.1:1.0: USB hub found
[    5.317127] hub 1-1.1:1.0: 3 ports detected
[    5.471880] systemd[1]: System time before build time, advancing clock.
[    5.647504] NET: Registered protocol family 10
[    5.654550] usb 1-1.1.2: new full-speed USB device number 4 using dwc_otg
[    5.656251] Segment Routing with IPv6
[    5.766968] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    5.798578] systemd[1]: Detected architecture arm.
[    5.847665] usb 1-1.1.2: New USB device found, idVendor=1eaf, idProduct=0004, bcdDevice= 2.00
[    5.862319] usb 1-1.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    5.875857] usb 1-1.1.2: Product: Maple
[    5.882674] usb 1-1.1.2: Manufacturer: LeafLabs
[    5.927679] systemd[1]: Set hostname to <octopi>.
[    5.987609] usb 1-1.1.3: new high-speed USB device number 5 using dwc_otg
[    6.346778] usb 1-1.1.3: New USB device found, idVendor=046d, idProduct=0825, bcdDevice= 0.10
[    6.361273] usb 1-1.1.3: New USB device strings: Mfr=0, Product=0, SerialNumber=2
[    6.375022] usb 1-1.1.3: SerialNumber: 09892B00
[    6.674533] usb 1-1.1.1: new high-speed USB device number 6 using dwc_otg
[    6.817747] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
[    6.832446] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    6.915093] random: systemd: uninitialized urandom read (16 bytes read)
[    6.940852] random: systemd: uninitialized urandom read (16 bytes read)
[    6.951743] systemd[1]: Listening on udev Control Socket.
[    6.994731] random: systemd: uninitialized urandom read (16 bytes read)
[    7.005382] systemd[1]: Listening on Journal Socket.
[    7.054909] systemd[1]: Starting Set the console keyboard layout...
[    7.097797] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    7.111160] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): No External EEPROM. Setting MAC Speed
[    7.130749] libphy: lan78xx-mdiobus: probed
[    7.149253] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    7.161046] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): int urb period 64
[    7.165002] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    7.224910] systemd[1]: Reached target Swap.
[    7.476973] mc: Linux media interface: v0.10
[    7.523753] videodev: Linux video capture interface: v2.00
[    7.585340] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[    7.603450] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[    7.612989] [vc_sm_connected_init]: start
[    7.613778] [vc_sm_connected_init]: installed successfully
[    7.642319] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    7.668169] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[    8.740819] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    9.045965] systemd-journald[136]: Received request to flush runtime journal from PID 1
[    9.626205] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[    9.635748] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[    9.635965] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[    9.636926] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[    9.637377] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[    9.637727] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[    9.637760] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[    9.637784] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[    9.637805] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[    9.637825] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[    9.638041] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[    9.653010] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[    9.653067] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[    9.676176] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[    9.676245] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[    9.679713] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[    9.679762] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[    9.822572] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[    9.830048] bcm2835_audio bcm2835_audio: card created with 8 channels
[   10.029859] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   10.182193] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   10.209817] cdc_acm 1-1.1.2:1.0: ttyACM0: USB ACM device
[   10.210968] usbcore: registered new interface driver cdc_acm
[   10.210988] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[   10.257615] brcmfmac: F1 signature read @0x18000000=0x15264345
[   10.262613] uvcvideo: Found UVC 1.00 device <unnamed> (046d:0825)
[   10.267387] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[   10.269350] usbcore: registered new interface driver brcmfmac
[   10.384876] input: UVC Camera (046d:0825) as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3:1.0/input/input0
[   10.386921] usbcore: registered new interface driver uvcvideo
[   10.386971] USB Video Class driver (1.1.1)
[   10.556666] random: crng init done
[   10.556686] random: 7 urandom warning(s) missed due to ratelimiting
[   10.578391] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[   10.578522] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[   10.590676] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
[   11.578127] usb 1-1.1.3: set resolution quirk: cval->res = 384
[   11.579241] usbcore: registered new interface driver snd-usb-audio
[   13.910342] 8021q: 802.1Q VLAN Support v1.8
[   13.998374] uart-pl011 3f201000.serial: no DMA platform data
[   14.410368] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[   14.464689] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
[   14.872469] 8021q: adding VLAN 0 to HW filter on device eth0
[   20.063531] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   21.050599] Bluetooth: Core ver 2.22
[   21.050720] NET: Registered protocol family 31
[   21.050730] Bluetooth: HCI device and connection manager initialized
[   21.051356] Bluetooth: HCI socket layer initialized
[   21.051374] Bluetooth: L2CAP socket layer initialized
[   21.051404] Bluetooth: SCO socket layer initialized
[   21.064922] Bluetooth: HCI UART driver ver 2.3
[   21.064941] Bluetooth: HCI UART protocol H4 registered
[   21.065035] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   21.065252] Bluetooth: HCI UART protocol Broadcom registered
[   21.528876] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   21.528890] Bluetooth: BNEP filters: protocol multicast
[   21.528906] Bluetooth: BNEP socket layer initialized
[   21.871356] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_time_ms instead
[   39.864522] usb 1-1.1.3: reset high-speed USB device number 5 using dwc_otg
OctoPrint version
1.6.1
OctoPi version
0.18.0
This looks like you've edited the octopi.txt on a Windows computer in something like notepad. If so, you need to use something that won't mangle the line endings, like notepad++.
So i edited it again with notepad++ and saved it but nothing changed. Just realiced that the \r is refered to the DOS newline encoding as specified in the following link.
Finally, after editing and saving the octopi.txt file with notepad++ and using the following commands through ssh i managed to have it working. Thank you so much for the reply @TTalkington !!
sudo apt install dos2unix
sudo dos2unix /boot/octopi.txt
sudo reboot
