The extruder dont "split" out the filament, there is no extrusion
everything i knwow
octoprint (1).log (13.6 KB)
i use the new version, installed today, printer alfawise u30 pro, operating system, win 10
inital Gcode
; generated by PrusaSlicer 2.1.1+win64 on 2020-04-02 at 17:53:00 UTC
; external perimeters extrusion width = 0.40mm
; perimeters extrusion width = 0.45mm
; infill extrusion width = 0.50mm
; solid infill extrusion width = 0.40mm
; top infill extrusion width = 0.35mm
; support material extrusion width = 0.35mm
; first layer extrusion width = 0.50mm
M201 X9000 Y9000 Z500 E10000 ; sets maximum accelerations, mm/sec^2
M203 X500 Y500 Z12 E120 ; sets maximum feedrates, mm/sec
M204 P1500 R1500 T1500 ; sets acceleration (P, T) and retract acceleration (R), mm/sec^2
M205 X10.00 Y10.00 Z0.20 E2.50 ; sets the jerk limits, mm/sec
M205 S0 T0 ; sets the minimum extruding and travel feed rate, mm/sec
M107
M190 S50 ; set bed temperature and wait for it to be reached
M104 S200 ; set temperature
G90 ; use absolute coordinates
M83 ; use relative distances for extrusion
G28 ; home all axes
G1 Z5 F5000 ; lift nozzle
G92 E0.0
M109 S200 ; set temperature and wait for it to be reached
G21 ; set units to millimeters
M82 ; use absolute distances for extrusion
G92 E0
; Filament gcode
