I'm trying to install the Octolapse on my Raspberry 3B+. The installations stucks at "Building wheel for pillow" and the Rpi just hangs. )Octoprint 1.4.0
I am using the image provided by OctoPrint
Tried to install some dependencies. Didn't work out.
Building wheel for pillow (setup.py): startedFehler!Could not install plugin, unknown error, please consult octoprint.log for details
(Pluginmanager Log, nothing in the octoprint log)
2020-04-25 21:28:36,736 > Building wheel for pillow (setup.py): started
2020-04-25 22:24:02,664 /home/pi/oprint/bin/python2 -m pip --disable-pip-version-check install https://github.com/FormerLurker/Octolapse/archive/v0.3.4.zip --no-cache-dir
2020-04-25 22:24:05,698 > Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
2020-04-25 22:24:05,699 > Collecting https://github.com/FormerLurker/Octolapse/archive/v0.3.4.zip
2020-04-25 22:24:06,704 > Downloading https://github.com/FormerLurker/Octolapse/archive/v0.3.4.zip
2020-04-25 22:24:19,879 > Collecting pillow
2020-04-25 22:24:19,880 > Downloading Pillow-6.2.2.tar.gz (37.8 MB)
These messages show up:
Message from syslogd@octopi at Apr 25 22:25:27 ...
kernel:[ 2260.707747] 3860: a75138cc a7513870 8026f7d0 80264a30 a75138e4 80d04d48 80d8b740 00000002
kernel:[ 2260.710501] 3880: 00000001 80d8b740 b47bfc00 60000113 8085e0dc b7391d20 b741485c 298e7051
kernel:[ 2260.713384] 38a0: 00000001 b7391d1c 00000400 aa652ffc 80d04d48 aa652000 00000400 a75139dc
kernel:[ 2260.716405] 38c0: a75138fc a75138d0 802ad83c 8026f520 80284900 298e7051 00000001 75df8000
(and much more(100000 letters)
Dmesg command:
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.19.97-v7+ (dom@buildbot) (gcc version 4.9.3 (cros stool-NG crosstool-ng-1.22.0-88-g8460611)) #1294 SMP Thu Jan 30 13:15:58 GMT 202 0
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructio n cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] cma: Reserved 8 MiB at 0x37800000
[ 0.000000] On node 0 totalpages: 229376
[ 0.000000] Normal zone: 2016 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 229376 pages, LIFO batch:63
[ 0.000000] random: get_random_bytes called from start_kernel+0xac/0x4b4 with crng_init=0
[ 0.000000] percpu: Embedded 16 pages/cpu s36864 r8192 d20480 u65536
[ 0.000000] pcpu-alloc: s36864 r8192 d20480 u65536 alloc=16*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 227360
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 bcm2708_fb. fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:E B:BB:CE:98 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0, 115200 console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 886300K/917504K available (8192K kernel code, 653K rwdata , 2220K rodata, 1024K init, 822K bss, 23012K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xb8800000 - 0xff800000 (1136 MB)
lowmem : 0x80000000 - 0xb8000000 ( 896 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x(ptrval) - 0x(ptrval) (9184 kB)
.init : 0x(ptrval) - 0x(ptrval) (1024 kB)
.data : 0x(ptrval) - 0x(ptrval) ( 654 kB)
.bss : 0x(ptrval) - 0x(ptrval) ( 823 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 26860 entries in 79 pages
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 43980 46511078ns
[ 0.000023] Switching to timer-based delay loop, resolution 52ns
[ 0.000284] Console: colour dummy device 80x30
[ 0.000907] console [tty1] enabled
[ 0.000962] Calibrating delay loop (skipped), value calculated using timer fr equency.. 38.40 BogoMIPS (lpj=192000)
[ 0.001006] pid_max: default: 32768 minimum: 301
[ 0.001365] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001403] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002373] CPU: Testing write buffer coherency: ok
[ 0.002859] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.003539] Setting up static identity map for 0x100000 - 0x10003c
[ 0.003711] rcu: Hierarchical SRCU implementation.
[ 0.004532] smp: Bringing up secondary CPUs ...
[ 0.005446] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.006436] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.007351] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.007477] smp: Brought up 1 node, 4 CPUs
[ 0.007559] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.007584] CPU: All CPU(s) started in HYP mode.
[ 0.007604] CPU: Virtualization extensions available.
[ 0.008586] devtmpfs: initialized
[ 0.021602] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.021874] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma x_idle_ns: 19112604462750000 ns
[ 0.021924] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.022537] pinctrl core: initialized pinctrl subsystem
[ 0.023412] NET: Registered protocol family 16
[ 0.026405] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.032094] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.032130] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.032355] Serial: AMBA PL011 UART driver
[ 0.034720] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.050030] raspberrypi-firmware soc:firmware: Attached to firmware from 2020 -02-12 12:39, variant start_x
[ 0.060043] raspberrypi-firmware soc:firmware: Firmware hash is 53a54c770c493 957d99bf49762dfabc4eee00e45
[ 0.103216] bcm2835-dma 3f007000.dma: DMA legacy API manager at (ptrval), dma chans=0x1
[ 0.104895] SCSI subsystem initialized
[ 0.105137] usbcore: registered new interface driver usbfs
[ 0.105212] usbcore: registered new interface driver hub
[ 0.105325] usbcore: registered new device driver usb
[ 0.106851] clocksource: Switched to clocksource arch_sys_counter
[ 0.196923] VFS: Disk quotas dquot_6.6.0
[ 0.197035] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.197206] FS-Cache: Loaded
[ 0.197429] CacheFiles: Loaded
[ 0.207492] NET: Registered protocol family 2
[ 0.208352] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ 0.208418] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.208549] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.208753] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.208909] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.208978] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.209236] NET: Registered protocol family 1
[ 0.209843] RPC: Registered named UNIX socket transport module.
[ 0.209870] RPC: Registered udp transport module.
[ 0.209892] RPC: Registered tcp transport module.
[ 0.209914] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.211573] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counter s available
[ 0.214661] Initialise system trusted keyrings
[ 0.214869] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 0.224650] FS-Cache: Netfs 'nfs' registered for caching
[ 0.225244] NFS: Registering the id_resolver key type
[ 0.225297] Key type id_resolver registered
[ 0.225319] Key type id_legacy registered
[ 0.225350] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.227698] Key type asymmetric registered
[ 0.227727] Asymmetric key parser 'x509' registered
[ 0.227795] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 50)
[ 0.227978] io scheduler noop registered
[ 0.228002] io scheduler deadline registered (default)
[ 0.228206] io scheduler cfq registered
[ 0.228230] io scheduler mq-deadline registered (default)
[ 0.228255] io scheduler kyber registered
[ 0.231350] bcm2708_fb soc:fb: FB found 1 display(s)
[ 0.240342] Console: switching to colour frame buffer device 82x26
[ 0.247211] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 656 x416
[ 0.253925] bcm2835-rng 3f104000.rng: hwrng registered
[ 0.256610] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000 000(1024 MiB)
[ 0.261935] vc-sm: Videocore shared memory driver
[ 0.264689] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f2 00000
[ 0.280470] brd: module loaded
[ 0.293109] loop: module loaded
[ 0.296168] Loading iSCSI transport class v2.0-870.
[ 0.299356] libphy: Fixed MDIO Bus: probed
[ 0.301864] usbcore: registered new interface driver lan78xx
[ 0.304328] usbcore: registered new interface driver smsc95xx
[ 0.306686] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.336957] dwc_otg 3f980000.usb: base=(ptrval)
[ 0.539584] Core Release: 2.80a
[ 0.541960] Setting default values for core params
[ 0.544403] Finished setting default values for core params
[ 0.747185] Using Buffer DMA mode
[ 0.749572] Periodic Transfer Interrupt Enhancement - disabled
[ 0.751996] Multiprocessor Interrupt Enhancement - disabled
[ 0.754372] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.756719] Dedicated Tx FIFOs mode
[ 0.759414] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = b7904 000 dma = 0xf7904000 len=9024
[ 0.763996] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 0.774920] dwc_otg: Microframe scheduler enabled
[ 0.774976] WARN::hcd_init_fiq:457: FIQ on core 1
[ 0.777206] WARN::hcd_init_fiq:458: FIQ ASM at 8067fd10 length 36
[ 0.779414] WARN::hcd_init_fiq:497: MPHI regs_base at b8810000
[ 0.781666] dwc_otg 3f980000.usb: DWC OTG Controller
[ 0.783928] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 0.786249] dwc_otg 3f980000.usb: irq 56, io mem 0x00000000
[ 0.788574] Init: Port Power? op_state=1
[ 0.790809] Init: Power Port (0)
[ 0.793225] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bc dDevice= 4.19
[ 0.797751] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 0.800161] usb usb1: Product: DWC OTG Controller
[ 0.802525] usb usb1: Manufacturer: Linux 4.19.97-v7+ dwc_otg_hcd
[ 0.804945] usb usb1: SerialNumber: 3f980000.usb
[ 0.807908] hub 1-0:1.0: USB hub found
[ 0.810183] hub 1-0:1.0: 1 port detected
[ 0.812943] dwc_otg: FIQ enabled
[ 0.812949] dwc_otg: NAK holdoff enabled
[ 0.812955] dwc_otg: FIQ split-transaction FSM enabled
[ 0.812965] Module dwc_common_port init
[ 0.813231] usbcore: registered new interface driver usb-storage
[ 0.815685] mousedev: PS/2 mouse device common for all mice
[ 0.818890] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 0.821516] bcm2835-cpufreq: min=600000 max=1200000
[ 0.824346] sdhci: Secure Digital Host Controller Interface driver
[ 0.826755] sdhci: Copyright(c) Pierre Ossman
[ 0.829573] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
[ 0.832513] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ 0.835193] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.839304] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.842073] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.844842] usbcore: registered new interface driver usbhid
[ 0.847494] usbhid: USB HID core driver
[ 0.850813] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
[ 0.854919] [vc_sm_connected_init]: start
[ 0.863637] [vc_sm_connected_init]: end - returning 0
[ 0.867207] Initializing XFRM netlink socket
[ 0.869627] NET: Registered protocol family 17
[ 0.872127] Key type dns_resolver registered
[ 0.874947] Registering SWP/SWPB emulation handler
[ 0.878058] registered taskstats version 1
[ 0.880453] Loading compiled-in X.509 certificates
[ 0.889614] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 0.892129] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 81, base_baud = 0) is a PL011 rev2
[ 0.898887] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 0.901413] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[ 0.927646] sdhost: log_buf @ (ptrval) (f7907000)
[ 0.966208] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 0.970205] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.974063] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.978004] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 0.981464] of_cfs_init
[ 0.983708] of_cfs_init: OK
[ 0.986304] Waiting for root device PARTUUID=6c586e13-02...
[ 1.001023] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.026970] Indeed it is in host mode hprt0 = 00021501
[ 1.097109] random: fast init done
[ 1.126139] mmc0: host does not support reading read-only switch, assuming wr ite-enable
[ 1.134033] mmc0: new high speed SDHC card at address aaaa
[ 1.137542] mmcblk0: mmc0:aaaa SC32G 29.7 GiB
[ 1.145027] mmcblk0: p1 p2
[ 1.171509] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesyst em
[ 1.173889] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 1.174540] mmc1: new high speed SDIO card at address 0001
[ 1.236894] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.239363] Indeed it is in host mode hprt0 = 00001101
[ 1.477156] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcd Device= 2.00
[ 1.481948] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.485296] hub 1-1:1.0: USB hub found
[ 1.488031] hub 1-1:1.0: 5 ports detected
[ 1.719368] EXT4-fs (mmcblk0p2): recovery complete
[ 1.726280] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. O pts: (null)
[ 1.731683] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.745778] devtmpfs: mounted
[ 1.753520] Freeing unused kernel memory: 1024K
[ 1.756611] Run /sbin/init as init process
[ 1.806891] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 1.937221] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, b cdDevice= 2.00
[ 1.942698] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber =0
[ 1.948275] smsc95xx v1.0.6
[ 2.040483] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb- 1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:bb:ce:98
[ 2.367352] systemd[1]: System time before build time, advancing clock.
[ 2.514379] NET: Registered protocol family 10
[ 2.518763] Segment Routing with IPv6
[ 2.565962] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SEL INUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL + XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybr id)
[ 2.575777] systemd[1]: Detected architecture arm.
[ 2.601305] systemd[1]: Set hostname to <octopi>.
[ 3.483591] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.498028] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.506597] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 3.513340] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.516949] systemd[1]: Listening on udev Control Socket.
[ 3.524093] systemd[1]: Set up automount Arbitrary Executable File Formats Fi le System Automount Point.
[ 3.534934] systemd[1]: Created slice system-getty.slice.
[ 3.541371] systemd[1]: Reached target Swap.
[ 3.547921] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 3.555432] systemd[1]: Created slice User and Session Slice.
[ 4.337105] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 4.446067] systemd-journald[118]: Received request to flush runtime journal from PID 1
[ 5.041969] media: Linux media interface: v0.10
[ 5.068696] vc_sm_cma: module is from the staging directory, the quality is u nknown, you have been warned.
[ 5.075059] videodev: Linux video capture interface: v2.00
[ 5.079644] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 5.079850] [vc_sm_connected_init]: start
[ 5.089735] [vc_sm_connected_init]: installed successfully
[ 5.120204] bcm2835_mmal_vchiq: module is from the staging directory, the qua lity is unknown, you have been warned.
[ 5.120677] bcm2835_mmal_vchiq: module is from the staging directory, the qua lity is unknown, you have been warned.
[ 5.144350] bcm2835_v4l2: module is from the staging directory, the quality i s unknown, you have been warned.
[ 5.181564] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.242418] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.251029] bcm2835_audio soc:audio: card created with 8 channels
[ 5.355551] cfg80211: Loading compiled-in X.509 certificates for regulatory d atabase
[ 5.483109] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 5.556062] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[ 5.567357] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio f or chip BCM43430/1
[ 5.567623] usbcore: registered new interface driver brcmfmac
[ 5.772760] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 5.772799] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 5.775659] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio f or chip BCM43430/1
[ 5.775761] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2 ), device may have limited channels available
[ 5.776541] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Oct 22 2019 01:59:28 version 7.45.98.94 (r723000 CY) FWID 01-3b33decd
[ 5.780485] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 5.780524] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 5.784549] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 5.784588] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 7.958984] random: crng init done
[ 7.959004] random: 7 urandom warning(s) missed due to ratelimiting
[ 8.140890] uart-pl011 3f201000.serial: no DMA platform data
[ 8.232617] 8021q: 802.1Q VLAN Support v1.8
[ 8.414562] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:1 02396k SSFS
[ 8.635760] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.635780] brcmfmac: power management disabled
[ 9.048132] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 9.048320] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.109282] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 13.192699] Bluetooth: Core ver 2.22
[ 13.192754] NET: Registered protocol family 31
[ 13.192758] Bluetooth: HCI device and connection manager initialized
[ 13.192772] Bluetooth: HCI socket layer initialized
[ 13.192779] Bluetooth: L2CAP socket layer initialized
[ 13.192802] Bluetooth: SCO socket layer initialized
[ 13.210062] Bluetooth: HCI UART driver ver 2.3
[ 13.210073] Bluetooth: HCI UART protocol H4 registered
[ 13.210165] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 13.211802] Bluetooth: HCI UART protocol Broadcom registered
[ 13.460408] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 13.460416] Bluetooth: BNEP filters: protocol multicast
[ 13.460434] Bluetooth: BNEP socket layer initialized
