Separate Raspberry Pi running motionEye OS
Octopi stopped showing the camera stream. Was working before.
Checked Google...
Deactivated and re-activated webcam support
journalctl -u webcamd
-- Logs begin at Thu 2021-09-30 14:42:05 CEST, end at Fri 2021-10-01 12:04:02 CEST. --
Sep 30 14:42:09 octopi systemd[1]: Starting the OctoPi webcam daemon with the user specified config.
Sep 30 14:42:09 octopi webcamd[380]: Starting up webcamDaemon...
Sep 30 14:42:09 octopi webcamd[380]: --- Configuration: ----------------------------
Sep 30 14:42:09 octopi webcamd[380]: cfg_file:      /boot/octopi.txt
Sep 30 14:42:09 octopi webcamd[380]: camera:        auto
Sep 30 14:42:09 octopi webcamd[380]: usb options:   -r 640x480 -f 10
Sep 30 14:42:09 octopi webcamd[380]: raspi options: -fps 10
Sep 30 14:42:09 octopi webcamd[380]: http options:  -w ./www-octopi -n
Sep 30 14:42:09 octopi webcamd[380]: Explicitly USB device:
Sep 30 14:42:09 octopi webcamd[380]: -----------------------------------------------
Sep 30 14:42:10 octopi webcamd[380]: Found video devices:
Sep 30 14:42:10 octopi webcamd[380]: /dev/video10
Sep 30 14:42:10 octopi webcamd[380]: /dev/video11
Sep 30 14:42:10 octopi webcamd[380]: /dev/video12
Sep 30 14:42:10 octopi webcamd[380]: /dev/video13
Sep 30 14:42:10 octopi webcamd[380]: /dev/video14
Sep 30 14:42:10 octopi webcamd[380]: /dev/video15
Sep 30 14:42:10 octopi webcamd[380]: /dev/video16
Sep 30 14:42:10 octopi webcamd[380]: config file='/boot/octopi.txt':USB device was not set in option
Sep 30 14:42:10 octopi webcamd[380]: [70B blob data]
Sep 30 14:42:10 octopi webcamd[380]: <13>Sep 30 14:42:10 root: Starting USB webcam
Sep 30 14:42:10 octopi webcamd[380]: Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n -i
Sep 30 14:42:10 octopi mjpg_streamer[445]: MJPG-streamer [445]: starting application
Sep 30 14:42:10 octopi webcamd[380]: MJPG Streamer Version: git rev: 501f6362c5afddcfb41055f97ae4842
Sep 30 14:42:10 octopi mjpg_streamer[445]: MJPG-streamer [445]: MJPG Streamer Version: git rev: 501f
Sep 30 14:42:10 octopi webcamd[380]:  i: Using V4L2 device.: /dev/video10
Sep 30 14:42:10 octopi webcamd[380]:  i: Desired Resolution: 640 x 480
Sep 30 14:42:10 octopi webcamd[380]:  i: Frames Per Second.: 10
Sep 30 14:42:10 octopi webcamd[380]:  i: Format............: JPEG
Sep 30 14:42:10 octopi webcamd[380]:  i: TV-Norm...........: DEFAULT
Sep 30 14:42:10 octopi mjpg_streamer[445]: MJPG-streamer [445]: Using V4L2 device.: /dev/video10
Sep 30 14:42:10 octopi mjpg_streamer[445]: MJPG-streamer [445]: Desired Resolution: 640 x 480
Sep 30 14:42:10 octopi mjpg_streamer[445]: MJPG-streamer [445]: Frames Per Second.: 10
Sep 30 14:42:10 octopi mjpg_streamer[445]: MJPG-streamer [445]: Format............: JPEG
Sep 30 14:42:10 octopi mjpg_streamer[445]: MJPG-streamer [445]: TV-Norm...........: DEFAULT
Sep 30 14:42:10 octopi webcamd[380]: Error opening device /dev/video10: video capture not supported.
Sep 30 14:42:10 octopi webcamd[380]: Init v4L2 failed !! exit fatal
Sep 30 14:42:10 octopi webcamd[380]:  i: init_VideoIn failed
Sep 30 14:42:10 octopi mjpg_streamer[445]: MJPG-streamer [445]: init_VideoIn failed
Sep 30 14:42:11 octopi webcamd[380]: Done bring up all configured video device
Sep 30 14:42:11 octopi webcamd[380]: Goodbye...
Sep 30 14:42:11 octopi systemd[1]: webcamd.service: Succeeded.
Sep 30 14:42:11 octopi systemd[1]: Started the OctoPi webcam daemon with the user specified config.
Sep 30 14:42:11 octopi systemd[1]: webcamd.service: Service RestartSec=100ms expired, scheduling res
Sep 30 14:42:11 octopi systemd[1]: webcamd.service: Scheduled restart job, restart counter is at 1.
Sep 30 14:42:11 octopi systemd[1]: Stopped the OctoPi webcam daemon with the user specified config.
Sep 30 14:42:11 octopi systemd[1]: Starting the OctoPi webcam daemon with the user specified config.
Sep 30 14:42:11 octopi webcamd[462]: Starting up webcamDaemon...
Sep 30 14:42:11 octopi webcamd[462]: --- Configuration: ----------------------------
Sep 30 14:42:11 octopi webcamd[462]: cfg_file:      /boot/octopi.txt
Sep 30 14:42:11 octopi webcamd[462]: camera:        auto
Sep 30 14:42:11 octopi webcamd[462]: usb options:   -r 640x480 -f 10
Sep 30 14:42:11 octopi webcamd[462]: raspi options: -fps 10
Sep 30 14:42:11 octopi webcamd[462]: http options:  -w ./www-octopi -n
Sep 30 14:42:11 octopi webcamd[462]: Explicitly USB device:
Sep 30 14:42:11 octopi webcamd[462]: -----------------------------------------------
Sep 30 14:42:11 octopi webcamd[462]: Found video devices:
Sep 30 14:42:11 octopi webcamd[462]: /dev/video10
Sep 30 14:42:11 octopi webcamd[462]: /dev/video11
Sep 30 14:42:11 octopi webcamd[462]: /dev/video12
Sep 30 14:42:11 octopi webcamd[462]: /dev/video13
Sep 30 14:42:11 octopi webcamd[462]: /dev/video14
Sep 30 14:42:11 octopi webcamd[462]: /dev/video15
Sep 30 14:42:11 octopi webcamd[462]: /dev/video16
Sep 30 14:42:11 octopi webcamd[462]: config file='/boot/octopi.txt':USB device was not set in option
Sep 30 14:42:11 octopi webcamd[462]: [70B blob data]
Sep 30 14:42:11 octopi root[485]: Starting USB webcam
Sep 30 14:42:11 octopi webcamd[462]: <13>Sep 30 14:42:11 root: Starting USB webcam
Sep 30 14:42:11 octopi webcamd[462]: Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n -i
Sep 30 14:42:11 octopi mjpg_streamer[486]: MJPG-streamer [486]: starting application
Sep 30 14:42:11 octopi webcamd[462]: MJPG Streamer Version: git rev: 501f6362c5afddcfb41055f97ae4842
Sep 30 14:42:11 octopi mjpg_streamer[486]: MJPG-streamer [486]: MJPG Streamer Version: git rev: 501f
Sep 30 14:42:11 octopi webcamd[462]:  i: Using V4L2 device.: /dev/video10
Sep 30 14:42:11 octopi mjpg_streamer[486]: MJPG-streamer [486]: Using V4L2 device.: /dev/video10
Sep 30 14:42:11 octopi webcamd[462]:  i: Desired Resolution: 640 x 480
Sep 30 14:42:11 octopi mjpg_streamer[486]: MJPG-streamer [486]: Desired Resolution: 640 x 480
Sep 30 14:42:11 octopi webcamd[462]:  i: Frames Per Second.: 10
Sep 30 14:42:11 octopi mjpg_streamer[486]: MJPG-streamer [486]: Frames Per Second.: 10
Sep 30 14:42:11 octopi webcamd[462]:  i: Format............: JPEG
Sep 30 14:42:11 octopi mjpg_streamer[486]: MJPG-streamer [486]: Format............: JPEG
Sep 30 14:42:11 octopi webcamd[462]:  i: TV-Norm...........: DEFAULT
Sep 30 14:42:11 octopi mjpg_streamer[486]: MJPG-streamer [486]: TV-Norm...........: DEFAULT
Sep 30 14:42:11 octopi webcamd[462]: Error opening device /dev/video10: video capture not supported.
Sep 30 14:42:11 octopi webcamd[462]: Init v4L2 failed !! exit fatal
Sep 30 14:42:11 octopi webcamd[462]:  i: init_VideoIn failed
Sep 30 14:42:11 octopi mjpg_streamer[486]: MJPG-streamer [486]: init_VideoIn failed
Sep 30 14:42:12 octopi webcamd[462]: Done bring up all configured video device
Sep 30 14:42:12 octopi webcamd[462]: Goodbye...
Sep 30 14:42:12 octopi systemd[1]: webcamd.service: Succeeded.
Sep 30 14:42:12 octopi systemd[1]: Started the OctoPi webcam daemon with the user specified config.
Sep 30 14:42:13 octopi systemd[1]: webcamd.service: Service RestartSec=100ms expired, scheduling res
Sep 30 14:42:13 octopi systemd[1]: webcamd.service: Scheduled restart job, restart counter is at 2.
Sep 30 14:42:13 octopi systemd[1]: Stopped the OctoPi webcam daemon with the user specified config.
Sep 30 14:42:13 octopi systemd[1]: Starting the OctoPi webcam daemon with the user specified config.
Sep 30 14:42:13 octopi webcamd[490]: Starting up webcamDaemon...
Sep 30 14:42:13 octopi webcamd[490]: --- Configuration: ----------------------------
Sep 30 14:42:13 octopi webcamd[490]: cfg_file:      /boot/octopi.txt
Sep 30 14:42:13 octopi webcamd[490]: camera:        auto
Sep 30 14:42:13 octopi webcamd[490]: usb options:   -r 640x480 -f 10
Sep 30 14:42:13 octopi webcamd[490]: raspi options: -fps 10
Sep 30 14:42:13 octopi webcamd[490]: http options:  -w ./www-octopi -n
Sep 30 14:42:13 octopi webcamd[490]: Explicitly USB device:
Sep 30 14:42:13 octopi webcamd[490]: -----------------------------------------------
Sep 30 14:42:13 octopi webcamd[490]: Found video devices:
Sep 30 14:42:13 octopi webcamd[490]: /dev/video10
Sep 30 14:42:13 octopi webcamd[490]: /dev/video11
Sep 30 14:42:13 octopi webcamd[490]: /dev/video12
Sep 30 14:42:13 octopi webcamd[490]: /dev/video13
Sep 30 14:42:13 octopi webcamd[490]: /dev/video14
Sep 30 14:42:13 octopi webcamd[490]: /dev/video15
Sep 30 14:42:13 octopi webcamd[490]: /dev/video16
Sep 30 14:42:13 octopi webcamd[490]: config file='/boot/octopi.txt':USB device was not set in option
Sep 30 14:42:13 octopi webcamd[490]: [70B blob data]
Sep 30 14:42:13 octopi root[513]: Starting USB webcam
Sep 30 14:42:13 octopi webcamd[490]: <13>Sep 30 14:42:13 root: Starting USB webcam
Sep 30 14:42:13 octopi webcamd[490]: Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n -i
Sep 30 14:42:13 octopi mjpg_streamer[514]: MJPG-streamer [514]: starting application
Sep 30 14:42:13 octopi webcamd[490]: MJPG Streamer Version: git rev: 501f6362c5afddcfb41055f97ae4842
Sep 30 14:42:13 octopi mjpg_streamer[514]: MJPG-streamer [514]: MJPG Streamer Version: git rev: 501f
Sep 30 14:42:13 octopi webcamd[490]:  i: Using V4L2 device.: /dev/video10
Sep 30 14:42:13 octopi webcamd[490]:  i: Desired Resolution: 640 x 480
Sep 30 14:42:13 octopi webcamd[490]:  i: Frames Per Second.: 10
Sep 30 14:42:13 octopi webcamd[490]:  i: Format............: JPEG
Sep 30 14:42:13 octopi webcamd[490]:  i: TV-Norm...........: DEFAULT
Sep 30 14:42:13 octopi mjpg_streamer[514]: MJPG-streamer [514]: Using V4L2 device.: /dev/video10
Sep 30 14:42:13 octopi webcamd[490]: Error opening device /dev/video10: video capture not supported.
Sep 30 14:42:13 octopi webcamd[490]: Init v4L2 failed !! exit fatal
Sep 30 14:42:13 octopi webcamd[490]:  i: init_VideoIn failed
Sep 30 14:42:13 octopi mjpg_streamer[514]: MJPG-streamer [514]: Desired Resolution: 640 x 480
Sep 30 14:42:13 octopi mjpg_streamer[514]: MJPG-streamer [514]: Frames Per Second.: 10
Sep 30 14:42:13 octopi mjpg_streamer[514]: MJPG-streamer [514]: Format............: JPEG
Sep 30 14:42:13 octopi mjpg_streamer[514]: MJPG-streamer [514]: TV-Norm...........: DEFAULT
Sep 30 14:42:13 octopi mjpg_streamer[514]: MJPG-streamer [514]: init_VideoIn failed
Sep 30 14:42:14 octopi webcamd[490]: Done bring up all configured video device
Sep 30 14:42:14 octopi webcamd[490]: Goodbye...
Sep 30 14:42:14 octopi systemd[1]: webcamd.service: Succeeded.
Sep 30 14:42:14 octopi systemd[1]: Started the OctoPi webcam daemon with the user specified config.
Sep 30 14:42:14 octopi systemd[1]: webcamd.service: Service RestartSec=100ms expired, scheduling res
Sep 30 14:42:14 octopi systemd[1]: webcamd.service: Scheduled restart job, restart counter is at 3.
Sep 30 14:42:14 octopi systemd[1]: Stopped the OctoPi webcam daemon with the user specified config.
Sep 30 14:42:14 octopi systemd[1]: Starting the OctoPi webcam daemon with the user specified config.
Sep 30 14:42:14 octopi webcamd[518]: Starting up webcamDaemon...
Sep 30 14:42:14 octopi webcamd[518]: --- Configuration: ----------------------------
Sep 30 14:42:14 octopi webcamd[518]: cfg_file:      /boot/octopi.txt
Sep 30 14:42:14 octopi webcamd[518]: camera:        auto
Sep 30 14:42:14 octopi webcamd[518]: usb options:   -r 640x480 -f 10
Sep 30 14:42:14 octopi webcamd[518]: raspi options: -fps 10
Sep 30 14:42:14 octopi webcamd[518]: http options:  -w ./www-octopi -n
Sep 30 14:42:14 octopi webcamd[518]: Explicitly USB device:
Sep 30 14:42:14 octopi webcamd[518]: -----------------------------------------------
Sep 30 14:42:14 octopi webcamd[518]: Found video devices:
Sep 30 14:42:14 octopi webcamd[518]: /dev/video10
Sep 30 14:42:14 octopi webcamd[518]: /dev/video11
Sep 30 14:42:14 octopi webcamd[518]: /dev/video12
Sep 30 14:42:14 octopi webcamd[518]: /dev/video13
Sep 30 14:42:14 octopi webcamd[518]: /dev/video14
Sep 30 14:42:14 octopi webcamd[518]: /dev/video15
Sep 30 14:42:14 octopi webcamd[518]: /dev/video16
Sep 30 14:42:14 octopi webcamd[518]: config file='/boot/octopi.txt':USB device was not set in option
Sep 30 14:42:14 octopi webcamd[518]: [70B blob data]
Sep 30 14:42:14 octopi root[547]: Starting USB webcam
Sep 30 14:42:14 octopi webcamd[518]: <13>Sep 30 14:42:14 root: Starting USB webcam
Sep 30 14:42:14 octopi webcamd[518]: Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n -i
Sep 30 14:42:14 octopi mjpg_streamer[554]: MJPG-streamer [554]: starting application
Sep 30 14:42:14 octopi webcamd[518]: MJPG Streamer Version: git rev: 501f6362c5afddcfb41055f97ae4842
Sep 30 14:42:14 octopi mjpg_streamer[554]: MJPG-streamer [554]: MJPG Streamer Version: git rev: 501f
Sep 30 14:42:14 octopi webcamd[518]:  i: Using V4L2 device.: /dev/video10
Sep 30 14:42:14 octopi webcamd[518]:  i: Desired Resolution: 640 x 480
Sep 30 14:42:14 octopi webcamd[518]:  i: Frames Per Second.: 10
Sep 30 14:42:14 octopi webcamd[518]:  i: Format............: JPEG
Sep 30 14:42:14 octopi webcamd[518]:  i: TV-Norm...........: DEFAULT
Sep 30 14:42:14 octopi webcamd[518]: Error opening device /dev/video10: video capture not supported.
Sep 30 14:42:14 octopi webcamd[518]: Init v4L2 failed !! exit fatal
Sep 30 14:42:14 octopi webcamd[518]:  i: init_VideoIn failed
Sep 30 14:42:14 octopi mjpg_streamer[554]: MJPG-streamer [554]: Using V4L2 device.: /dev/video10
Sep 30 14:42:14 octopi mjpg_streamer[554]: MJPG-streamer [554]: Desired Resolution: 640 x 480
Sep 30 14:42:14 octopi mjpg_streamer[554]: MJPG-streamer [554]: Frames Per Second.: 10
Sep 30 14:42:14 octopi mjpg_streamer[554]: MJPG-streamer [554]: Format............: JPEG
Sep 30 14:42:14 octopi mjpg_streamer[554]: MJPG-streamer [554]: TV-Norm...........: DEFAULT
Sep 30 14:42:14 octopi mjpg_streamer[554]: MJPG-streamer [554]: init_VideoIn failed
Sep 30 14:42:15 octopi webcamd[518]: Done bring up all configured video device
Sep 30 14:42:15 octopi webcamd[518]: Goodbye...
Sep 30 14:42:15 octopi systemd[1]: webcamd.service: Succeeded.
Sep 30 14:42:15 octopi systemd[1]: Started the OctoPi webcam daemon with the user specified config.
Sep 30 14:42:16 octopi systemd[1]: webcamd.service: Service RestartSec=100ms expired, scheduling res
Sep 30 14:42:16 octopi systemd[1]: webcamd.service: Scheduled restart job, restart counter is at 4.
Sep 30 14:42:16 octopi systemd[1]: Stopped the OctoPi webcam daemon with the user specified config.
Sep 30 14:42:16 octopi systemd[1]: Starting the OctoPi webcam daemon with the user specified config.
Sep 30 14:42:16 octopi webcamd[594]: Starting up webcamDaemon...
Sep 30 14:42:16 octopi webcamd[594]: --- Configuration: ----------------------------
Sep 30 14:42:16 octopi webcamd[594]: cfg_file:      /boot/octopi.txt
Sep 30 14:42:16 octopi webcamd[594]: camera:        auto
Sep 30 14:42:16 octopi webcamd[594]: usb options:   -r 640x480 -f 10
Sep 30 14:42:16 octopi webcamd[594]: raspi options: -fps 10
Sep 30 14:42:16 octopi webcamd[594]: http options:  -w ./www-octopi -n
Sep 30 14:42:16 octopi webcamd[594]: Explicitly USB device:
Sep 30 14:42:16 octopi webcamd[594]: -----------------------------------------------
Sep 30 14:42:16 octopi webcamd[594]: Found video devices:
Sep 30 14:42:16 octopi webcamd[594]: /dev/video10
Sep 30 14:42:16 octopi webcamd[594]: /dev/video11
Sep 30 14:42:16 octopi webcamd[594]: /dev/video12
Sep 30 14:42:16 octopi webcamd[594]: /dev/video13
Sep 30 14:42:16 octopi webcamd[594]: /dev/video14
Sep 30 14:42:16 octopi webcamd[594]: /dev/video15
Sep 30 14:42:16 octopi webcamd[594]: /dev/video16
Sep 30 14:42:16 octopi webcamd[594]: config file='/boot/octopi.txt':USB device was not set in option
Sep 30 14:42:16 octopi webcamd[594]: [70B blob data]
Sep 30 14:42:16 octopi root[617]: Starting USB webcam
Sep 30 14:42:16 octopi webcamd[594]: <13>Sep 30 14:42:16 root: Starting USB webcam
Sep 30 14:42:16 octopi webcamd[594]: Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n -i
Sep 30 14:42:16 octopi mjpg_streamer[618]: MJPG-streamer [618]: starting application
Sep 30 14:42:16 octopi webcamd[594]: MJPG Streamer Version: git rev: 501f6362c5afddcfb41055f97ae4842
Sep 30 14:42:16 octopi mjpg_streamer[618]: MJPG-streamer [618]: MJPG Streamer Version: git rev: 501f
Sep 30 14:42:16 octopi webcamd[594]:  i: Using V4L2 device.: /dev/video10
Sep 30 14:42:16 octopi webcamd[594]:  i: Desired Resolution: 640 x 480
Sep 30 14:42:16 octopi webcamd[594]:  i: Frames Per Second.: 10
Sep 30 14:42:16 octopi webcamd[594]:  i: Format............: JPEG
Sep 30 14:42:16 octopi webcamd[594]:  i: TV-Norm...........: DEFAULT
Sep 30 14:42:16 octopi webcamd[594]: Error opening device /dev/video10: video capture not supported.
Sep 30 14:42:16 octopi webcamd[594]: Init v4L2 failed !! exit fatal
Sep 30 14:42:16 octopi webcamd[594]:  i: init_VideoIn failed
Sep 30 14:42:16 octopi mjpg_streamer[618]: MJPG-streamer [618]: Using V4L2 device.: /dev/video10
Sep 30 14:42:16 octopi mjpg_streamer[618]: MJPG-streamer [618]: Desired Resolution: 640 x 480
Sep 30 14:42:16 octopi mjpg_streamer[618]: MJPG-streamer [618]: Frames Per Second.: 10
Sep 30 14:42:16 octopi mjpg_streamer[618]: MJPG-streamer [618]: Format............: JPEG
Sep 30 14:42:16 octopi mjpg_streamer[618]: MJPG-streamer [618]: TV-Norm...........: DEFAULT
Sep 30 14:42:16 octopi mjpg_streamer[618]: MJPG-streamer [618]: init_VideoIn failed
Sep 30 14:42:17 octopi webcamd[594]: Done bring up all configured video device
Sep 30 14:42:17 octopi webcamd[594]: Goodbye...
Sep 30 14:42:17 octopi systemd[1]: webcamd.service: Succeeded.
Sep 30 14:42:17 octopi systemd[1]: Started the OctoPi webcam daemon with the user specified config.
Sep 30 14:42:17 octopi systemd[1]: webcamd.service: Service RestartSec=100ms expired, scheduling res
Sep 30 14:42:17 octopi systemd[1]: webcamd.service: Scheduled restart job, restart counter is at 5.
Sep 30 14:42:17 octopi systemd[1]: Stopped the OctoPi webcam daemon with the user specified config.
Sep 30 14:42:17 octopi systemd[1]: webcamd.service: Start request repeated too quickly.
Sep 30 14:42:17 octopi systemd[1]: webcamd.service: Failed with result 'start-limit-hit'.
Sep 30 14:42:17 octopi systemd[1]: Failed to start the OctoPi webcam daemon with the user specified
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/94.0.4606.61 Safari/537.36
connectivity.enabled: true
connectivity.online: true
env.hardware.cores: 4
env.hardware.freq: 1200
env.hardware.ram: 915722240
env.os.bits: 32
env.os.id: linux
env.os.platform: linux2
env.plugins.pi_support.model: Raspberry Pi 3 Model B Rev 1.2
env.plugins.pi_support.octopi_version: 0.17.0
env.plugins.pi_support.throttle_state: 0x50005
env.python.pip: 19.3.1
env.python.version: 2.7.16
env.python.virtualenv: true
octoprint.safe_mode: false
octoprint.version: 1.6.1
printer.firmware: Marlin Creality 3D
Octopi and MotionEye are running on two separate Raspberrys Model 3.
Webcam support in Octopi was showing the camera stream.
Since a couple days there is no more camera stream, but this error message:
"Webcamstream nicht geladen
Es liegt evtl. eine Fehlkonfiguration vor oder es werden Logindaten benötigt. Du kannst die URL des Streams unter "Einstellungen" > "Webcam & Zeitraffer" > "Webcam" > "Stream-URL" ändern. Falls du keine Webcam hast kannst du Webcam-Unterstützung dort auch deaktivieren.
Aktuell konfigurierte Stream-URL: http://192.168.10.40:8081"
When clicking on the stream-URL (it is actually a link), another browser tab opens and shows the camera stream, which is proof that the camera responds at this URL.
I could not find this exact problem so far online.
