when I press connect in the octoprint web server, to connect to my printer it tries to connect but doesn't succeed.
enable wait for start on connect option, get an otg data cable, correctly power the raspberry pi
run "dmesg" in ssh to see if the printer was seen by a usb driver, (it was). manually add the usb port to octoprint. manually set the bouderate and USB port in octoprint.
yes
no
OctoPrint version: 1.8.1, OctoPi version: the latest stable version, printer: creality CR-10 v2, firmware: merlin engine from tiny machines, browser: chrome , ... as much data as possible serial (2).log (1.6 KB) dmesg output.log (21.0 KB)
like 4, im now testing two i found from external hard drives. but i thought it might also be important to know that the pi only works with an ethernet cable, wifi does nothing
