Octopi server not working
Can get octopi.local to start then get this error message: "Looks like something went wrong during startup, the server is gone again. You should check octoprint.log"
After this connecting using octopi.local, or IP does not work. Can still see octopi on the network however and ping from CMD.
Tried ethernet directly into router instead of WLAN, no difference.
Tried to access octoprint.log (not sure if I'm doing that correctly).
Using Raspberry Pi B rev 1.0 (issue here?)
Tried connecting from Win 10 PC (wired), Samsung S10, iPhone 6s (Bonjour?)
Hi @TheMcBlyat ,
I notice you say you tried to access the octoprint.log, but haven't posted them here. They can be found in ~/.octoprint/logs if you can't get into the server. Octoprint.log <- click this link to find out where to find them if you get stuck.
To help with issues like this, we really, really, really need the log, as it will more than likely explain the issue. Can you also try starting in safe mode < click the link to find out how
Hi @Charlie_Powell,
Have now got the log file, sorry for not posting it first. This was running in safe mode:
2020-08-10 12:06:53,057 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-08-10 12:07:33,972 - octoprint.plugin.core - INFO - Found 15 plugin(s) providing 15 mixin implementations, 17 hook handlers
2020-08-10 12:07:35,753 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2020-08-10 12:07:36,569 - octoprint.server - INFO - Intermediary server started
2020-08-10 12:07:36,593 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-08-10 12:08:05,158 - octoprint.plugin.core - INFO - Found 15 plugin(s) providing 15 mixin implementations, 17 hook handlers
        2020-08-10 12:08:36,195 - octoprint.startup - INFO - ******************************************************************************
2020-08-10 12:08:36,211 - octoprint.startup - INFO - Starting OctoPrint 1.3.10
2020-08-10 12:08:36,215 - octoprint.startup - INFO - ******************************************************************************
2020-08-11 09:33:37,661 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-08-11 09:34:03,792 - octoprint.plugin.core - INFO - Found 15 plugin(s) providing 15 mixin implementations, 17 hook handlers
2020-08-11 09:34:04,566 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2020-08-11 09:34:04,947 - octoprint.server - INFO - Intermediary server started
2020-08-11 09:34:04,958 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-08-11 09:34:10,965 - octoprint.plugin.core - INFO - Found 15 plugin(s) providing 15 mixin implementations, 17 hook handlers
2020-08-11 09:34:11,355 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2020-08-11 09:34:11,374 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2020-08-11 09:34:11,673 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2020-08-11 09:34:25,583 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-08-11 09:34:38,173 - octoprint.util.pip - INFO - Version of pip is 19.0.1
2020-08-11 09:34:38,189 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-08-11 09:34:38,200 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-08-11 09:34:38,244 - octoprint.plugin.core - INFO - Initialized 15 plugin implementation(s)
2020-08-11 09:34:38,328 - octoprint.plugin.core - INFO - 15 plugin(s) registered with the system:
|  Action Command Prompt Support (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/action_command_prompt
|  Announcement Plugin (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/announcements
|  Anonymous Usage Tracking (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/tracking
|  Application Keys Plugin (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/appkeys
|  Backup & Restore (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/backup
|  Core Wizard (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/corewizard
|  CuraEngine (<= 15.04) (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/cura
|  Discovery (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/discovery
|  Force Login (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/forcelogin
|  Logging (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/logging
|  Pi Support Plugin (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/pi_support
|  Plugin Manager (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/pluginmanager
|  Printer Safety Check (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/printer_safety_check
|  Software Update (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/softwareupdate
|  Virtual Printer (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/virtual_printer
2020-08-11 09:34:38,515 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
|  hardware:
|    cores: 1
|    freq: 700.0
|    ram: 122224640
|  os:
|    platform: linux2
|  plugins:
|    pi_support:
|      model: Raspberry Pi Model B Rev 1
|      octopi_version: 0.16.0
|  python:
|    pip: 19.0.1
|    version: 2.7.13
|    virtualenv: /home/pi/oprint
2020-08-11 09:34:38,591 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2020-08-11 09:34:38,609 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2020-08-11 09:34:41,333 - octoprint.server - INFO - Shutting down intermediary server...
2020-08-11 09:34:41,829 - octoprint.server - INFO - Intermediary server shut down
2020-08-11 09:34:41,850 - octoprint.events - INFO - Processing startup event, this is our first event
2020-08-11 09:34:41,865 - octoprint.events - INFO - Adding 0 events to queue that were held back before startup event
2020-08-11 09:34:41,887 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2020-08-11 09:34:41,916 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2020-08-11 09:34:42,138 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _http._tcp
2020-08-11 09:34:42,248 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _octoprint._tcp
2020-08-11 09:34:42,282 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2020-08-11 09:34:42,516 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2020-08-11 09:34:44,756 - octoprint.plugins.announcements - INFO - Loaded channel _important from https://octoprint.org/feeds/important.xml in 1.9s
2020-08-11 09:34:45,051 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from https://plugins.octoprint.org/plugins.json
2020-08-11 09:34:54,026 - octoprint.plugins.announcements - INFO - Loaded channel _releases from https://octoprint.org/feeds/releases.xml in 1.4s
2020-08-11 09:34:57,997 - octoprint.plugins.announcements - INFO - Loaded channel _blog from https://octoprint.org/feeds/octoblog.xml in 1.5s
2020-08-11 09:35:02,411 - octoprint.plugins.announcements - INFO - Loaded channel _plugins from https://plugins.octoprint.org/feed.xml in 1.7s
2020-08-11 09:35:12,333 - octoprint.plugins.announcements - INFO - Loaded channel _octopi from https://octoprint.org/feeds/octopi.xml in 3.2s
2020-08-11 09:35:18,924 - octoprint.plugins.pluginmanager - INFO - Loaded plugin notices data from https://plugins.octoprint.org/notices.json
2020-08-11 09:35:19,727 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-08-11 09:35:19,741 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-08-11 09:35:19,754 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-08-11 09:35:34,407 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-08-11 09:35:52,555 - octoprint.server.util.flask.PreemptiveCache - INFO - Adding entry for / and {'query_string': 'l10n=en', 'path': u'/', '_count': 1, '_timestamp': 1597134952.554238, 'base_url': 'http://192.168.0.19/'}
2020-08-11 09:37:01,160 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages/ (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-08-11 09:37:01,182 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-08-11 09:37:01,593 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2020-08-11 09:37:02,350 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://192.168.0.19/'}
2020-08-11 09:38:57,305 - octoprint.server.preemptive_cache - INFO - ... done in 114.96s
2020-08-11 09:39:42,300 - octoprint.server.util.flask.PreemptiveCache - INFO - Adding entry for / and {'query_string': 'l10n=en', 'path': u'/', '_count': 1, '_timestamp': 1597135182.299506, 'base_url': 'http://octopi.local/'}
2020-08-11 09:49:04,596 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-08-11 10:01:15,956 - octoprint.server - INFO - Shutting down...
2020-08-11 10:01:16,413 - octoprint.events - INFO - Processing shutdown event, this will be our last event
2020-08-11 10:01:16,709 - octoprint.events - INFO - Event loop shut down
2020-08-11 10:01:17,540 - octoprint.server - INFO - Goodbye!
2020-08-11 10:01:58,963 - octoprint.startup - INFO - ******************************************************************************
2020-08-11 10:01:59,001 - octoprint.startup - INFO - Starting OctoPrint 1.3.10
2020-08-11 10:01:59,004 - octoprint.startup - INFO - Starting in SAFE MODE. Third party plugins will be disabled!
2020-08-11 10:01:59,029 - octoprint.startup - INFO - ******************************************************************************
2020-08-11 10:02:26,664 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-08-11 10:02:48,987 - octoprint.plugin.core - INFO - Found 15 plugin(s) providing 15 mixin implementations, 17 hook handlers
2020-08-11 10:02:49,753 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2020-08-11 10:02:50,077 - octoprint.server - INFO - Intermediary server started
2020-08-11 10:02:50,088 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-08-11 10:02:56,033 - octoprint.plugin.core - INFO - Found 15 plugin(s) providing 15 mixin implementations, 17 hook handlers
2020-08-11 10:02:56,431 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2020-08-11 10:02:56,450 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2020-08-11 10:02:56,828 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2020-08-11 10:03:11,695 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-08-11 10:03:25,626 - octoprint.util.pip - INFO - Version of pip is 19.0.1
2020-08-11 10:03:25,650 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-08-11 10:03:25,666 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-08-11 10:03:25,747 - octoprint.plugin.core - INFO - Initialized 15 plugin implementation(s)
2020-08-11 10:03:25,840 - octoprint.plugin.core - INFO - 15 plugin(s) registered with the system:
2020-08-11 10:03:26,026 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
|  hardware:
|    cores: 1
|    freq: 700.0
|    ram: 122224640
|  os:
|    platform: linux2
|  plugins:
|    pi_support:
|  python:
|    pip: 19.0.1
|    version: 2.7.13
2020-08-11 10:03:26,111 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2020-08-11 10:03:26,259 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2020-08-11 10:03:29,861 - octoprint.server - INFO - Shutting down intermediary server...
2020-08-11 10:03:30,340 - octoprint.server - INFO - Intermediary server shut down
2020-08-11 10:03:30,361 - octoprint.events - INFO - Processing startup event, this is our first event
2020-08-11 10:03:30,377 - octoprint.events - INFO - Adding 0 events to queue that were held back before startup event
2020-08-11 10:03:30,403 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2020-08-11 10:03:30,425 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2020-08-11 10:03:30,614 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _http._tcp
2020-08-11 10:03:30,719 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _octoprint._tcp
2020-08-11 10:03:30,771 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2020-08-11 10:03:30,973 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2020-08-11 10:03:30,986 - octoprint.server - INFO - Server started successfully in safe mode as requested from config, removing flag
2020-08-11 10:03:32,182 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-08-11 10:03:51,430 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2020-08-11 10:03:57,403 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-08-11 10:03:57,426 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-08-11 10:03:57,436 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-08-11 10:03:57,887 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://192.168.0.19/'}
I am running the last version of octoprint (0.16.0) to see if it would help. Spoiler; it didn't. Same issue as 0.17.0
The recent version of OctoPrint 1.4.2 - referring your log, you are running 1.3.10.
0.16.0 is a former version of OctoPi - recent one is 0.17.0
No issues seen in the logs, so the server think's its alright. Try updating OctoPrint, 1.3.10 is quite ancient now, getting on for 2 years old.
Sorry, yes I mean't last version of Octopi. I'll try updating Octoprint and see what happens.
Updated to 1.4.2, still the same. Could it simply be the Pi is too old? B Rev 1.0?
(new log)
2020-08-11 12:06:11,028 - octoprint.startup - INFO - ******************************************************************************
2020-08-11 12:06:11,054 - octoprint.startup - INFO - Starting OctoPrint 1.4.2
2020-08-11 12:06:11,058 - octoprint.startup - INFO - ******************************************************************************
2020-08-11 12:06:22,058 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: online
2020-08-11 12:06:22,070 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 8.8.8.8:53 is working
2020-08-11 12:06:22,084 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is working
2020-08-11 12:06:22,505 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-08-11 12:06:38,723 - octoprint.plugin.core - INFO - Found 18 plugin(s) providing 18 mixin implementations, 32 hook handlers
2020-08-11 12:06:40,201 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2020-08-11 12:06:40,569 - octoprint.server - INFO - Intermediary server started
2020-08-11 12:06:40,582 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-08-11 12:06:51,337 - octoprint.plugin.core - INFO - Found 18 plugin(s) providing 18 mixin implementations, 32 hook handlers
2020-08-11 12:06:52,168 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2020-08-11 12:06:52,221 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2020-08-11 12:06:52,289 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_SHOW (needs: u"Need(method='role', value=u'plugin_action_command_notification_show')")
2020-08-11 12:06:52,302 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_CLEAR (needs: u"Need(method='role', value=u'plugin_action_command_notification_clear')")
2020-08-11 12:06:52,318 - octoprint.server - INFO - Added new permission from plugin action_command_prompt: PLUGIN_ACTION_COMMAND_PROMPT_INTERACT (needs: u"Need(method='role', value=u'plugin_action_command_prompt_interact')")
2020-08-11 12:06:52,336 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_READ (needs: u"Need(method='role', value=u'plugin_announcements_read')")
2020-08-11 12:06:52,354 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_MANAGE (needs: u"Need(method='role', value=u'plugin_announcements_manage'), Need(method='role', value=u'plugin_announcements_read')")
2020-08-11 12:06:52,367 - octoprint.server - INFO - Added new permission from plugin appkeys: PLUGIN_APPKEYS_ADMIN (needs: u"Need(method='role', value=u'plugin_appkeys_admin')")
2020-08-11 12:06:52,385 - octoprint.server - INFO - Added new permission from plugin backup: PLUGIN_BACKUP_ACCESS (needs: u"Need(method='role', value=u'plugin_backup_access')")
2020-08-11 12:06:52,408 - octoprint.server - INFO - Added new permission from plugin firmware_check: PLUGIN_FIRMWARE_CHECK_DISPLAY (needs: u"Need(method='role', value=u'plugin_firmware_check_display')")
2020-08-11 12:06:52,423 - octoprint.server - INFO - Added new permission from plugin logging: PLUGIN_LOGGING_MANAGE (needs: u"Need(method='role', value=u'plugin_logging_manage')")
2020-08-11 12:06:52,437 - octoprint.server - INFO - Added new permission from plugin pi_support: PLUGIN_PI_SUPPORT_STATUS (needs: u"Need(method='role', value=u'plugin_pi_support_check')")
2020-08-11 12:06:52,454 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_MANAGE (needs: u"Need(method='role', value=u'plugin_pluginmanager_manage')")
2020-08-11 12:06:52,473 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_INSTALL (needs: u"Need(method='role', value=u'plugin_pluginmanager_install'), Need(method='role', value=u'plugin_pluginmanager_manage')")
2020-08-11 12:06:52,490 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CHECK (needs: u"Need(method='role', value=u'plugin_softwareupdate_check')")
2020-08-11 12:06:52,504 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_UPDATE (needs: u"Need(method='role', value=u'plugin_softwareupdate_update')")
2020-08-11 12:06:53,429 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2020-08-11 12:07:09,277 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-08-11 12:07:24,440 - octoprint.util.pip - INFO - Version of pip is 19.0.1
2020-08-11 12:07:24,485 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-08-11 12:07:24,496 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-08-11 12:07:24,592 - octoprint.plugin.core - INFO - Initialized 18 plugin implementation(s)
2020-08-11 12:07:24,766 - octoprint.plugin.core - INFO - 18 plugin(s) registered with the system:
|  Action Command Notification Support (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/action_command_notification
|  Error Tracking (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/errortracking
|  File Check (2020.8.7) (bundled) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_file_check
|  Firmware Check (2020.6.22) (bundled) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_firmware_check
|  GCode Viewer (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/gcodeviewer
|  Login UI (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/loginui
2020-08-11 12:07:24,973 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
|  hardware:
|      cores: 1
|      freq: 700.0
|      ram: 122224640
|  os:
|      platform: linux2
|  plugins:
|      pi_support:
|  python:
|      pip: 19.0.1
|      version: 2.7.13
2020-08-11 12:07:25,117 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2020-08-11 12:07:25,329 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2020-08-11 12:07:37,391 - octoprint.server - INFO - Shutting down intermediary server...
2020-08-11 12:07:37,807 - octoprint.server - INFO - Intermediary server shut down
2020-08-11 12:07:37,832 - octoprint.events - INFO - Processing startup event, this is our first event
2020-08-11 12:07:37,849 - octoprint.events - INFO - Adding 0 events to queue that were held back before startup event
2020-08-11 12:07:37,872 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2020-08-11 12:07:37,902 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2020-08-11 12:07:37,922 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2020-08-11 12:07:37,952 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2020-08-11 12:07:38,136 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _http._tcp
2020-08-11 12:07:38,247 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _octoprint._tcp
2020-08-11 12:07:38,287 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2020-08-11 12:07:38,620 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2020-08-11 12:07:39,723 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-08-11 12:08:31,509 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-08-11 12:08:31,578 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-08-11 12:08:31,598 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-08-11 12:08:31,770 - octoprint.plugins.softwareupdate - INFO - Minimum free storage across all update relevant locations is 12.5GB. That is considered sufficient for updating.
2020-08-11 12:08:33,983 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://192.168.0.19/'}
2020-08-11 12:08:40,036 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
I've updated to latest Octoprint but still no luck? Same issue.
Can you try in safe mode? And exactly what message do you get? Not sure I've seen this one, maybe it comes from the intermediary server, before the main OctoPrint has started up.
This is the message I get when connecting: " Looks like something went wrong during startup, the server is gone again. You should check octoprint.log ."
2020-08-16 15:24:17,544 - octoprint.startup - INFO - ******************************************************************************
2020-08-16 15:24:17,569 - octoprint.startup - INFO - Starting OctoPrint 1.4.2
2020-08-16 15:24:17,573 - octoprint.startup - INFO - Starting in SAFE MODE. Third party plugins will be disabled!
2020-08-16 15:24:17,590 - octoprint.startup - INFO - Reason for safe mode: setting in config.yaml
2020-08-16 15:24:17,603 - octoprint.startup - INFO - ******************************************************************************
2020-08-16 15:24:28,067 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: online
2020-08-16 15:24:28,080 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 8.8.8.8:53 is working
2020-08-16 15:24:28,092 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is working
2020-08-16 15:24:28,510 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-08-16 15:24:44,713 - octoprint.plugin.core - INFO - Found 18 plugin(s) providing 18 mixin implementations, 32 hook handlers
2020-08-16 15:24:46,238 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2020-08-16 15:24:46,600 - octoprint.server - INFO - Intermediary server started
2020-08-16 15:24:46,615 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-08-16 15:24:55,311 - octoprint.plugin.core - INFO - Found 18 plugin(s) providing 18 mixin implementations, 32 hook handlers
2020-08-16 15:24:56,225 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2020-08-16 15:24:56,267 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2020-08-16 15:24:56,356 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_SHOW (needs: u"Need(method='role', value=u'plugin_action_command_notification_show')")
2020-08-16 15:24:56,387 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_CLEAR (needs: u"Need(method='role', value=u'plugin_action_command_notification_clear')")
2020-08-16 15:24:56,417 - octoprint.server - INFO - Added new permission from plugin action_command_prompt: PLUGIN_ACTION_COMMAND_PROMPT_INTERACT (needs: u"Need(method='role', value=u'plugin_action_command_prompt_interact')")
2020-08-16 15:24:56,449 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_READ (needs: u"Need(method='role', value=u'plugin_announcements_read')")
2020-08-16 15:24:56,480 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_MANAGE (needs: u"Need(method='role', value=u'plugin_announcements_manage'), Need(method='role', value=u'plugin_announcements_read')")
2020-08-16 15:24:56,517 - octoprint.server - INFO - Added new permission from plugin appkeys: PLUGIN_APPKEYS_ADMIN (needs: u"Need(method='role', value=u'plugin_appkeys_admin')")
2020-08-16 15:24:56,549 - octoprint.server - INFO - Added new permission from plugin backup: PLUGIN_BACKUP_ACCESS (needs: u"Need(method='role', value=u'plugin_backup_access')")
2020-08-16 15:24:56,582 - octoprint.server - INFO - Added new permission from plugin firmware_check: PLUGIN_FIRMWARE_CHECK_DISPLAY (needs: u"Need(method='role', value=u'plugin_firmware_check_display')")
2020-08-16 15:24:56,619 - octoprint.server - INFO - Added new permission from plugin logging: PLUGIN_LOGGING_MANAGE (needs: u"Need(method='role', value=u'plugin_logging_manage')")
2020-08-16 15:24:56,652 - octoprint.server - INFO - Added new permission from plugin pi_support: PLUGIN_PI_SUPPORT_STATUS (needs: u"Need(method='role', value=u'plugin_pi_support_check')")
2020-08-16 15:24:56,693 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_MANAGE (needs: u"Need(method='role', value=u'plugin_pluginmanager_manage')")
2020-08-16 15:24:56,734 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_INSTALL (needs: u"Need(method='role', value=u'plugin_pluginmanager_install'), Need(method='role', value=u'plugin_pluginmanager_manage')")
2020-08-16 15:24:56,760 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CHECK (needs: u"Need(method='role', value=u'plugin_softwareupdate_check')")
2020-08-16 15:24:56,796 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_UPDATE (needs: u"Need(method='role', value=u'plugin_softwareupdate_update')")
2020-08-16 15:24:58,379 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2020-08-16 15:25:15,855 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-08-16 15:25:32,290 - octoprint.util.pip - INFO - Version of pip is 19.0.1
2020-08-16 15:25:32,338 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-08-16 15:25:32,350 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-08-16 15:25:32,435 - octoprint.plugin.core - INFO - Initialized 18 plugin implementation(s)
2020-08-16 15:25:32,596 - octoprint.plugin.core - INFO - 18 plugin(s) registered with the system:
2020-08-16 15:25:32,811 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
|  hardware:
|      cores: 1
|      freq: 700.0
|      ram: 122224640
|  os:
|      platform: linux2
|  plugins:
|      pi_support:
|  python:
|      pip: 19.0.1
|      version: 2.7.13
2020-08-16 15:25:32,929 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2020-08-16 15:25:32,949 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2020-08-16 15:25:44,671 - octoprint.server - INFO - Shutting down intermediary server...
2020-08-16 15:25:45,083 - octoprint.server - INFO - Intermediary server shut down
2020-08-16 15:25:45,120 - octoprint.events - INFO - Processing startup event, this is our first event
2020-08-16 15:25:45,145 - octoprint.events - INFO - Adding 0 events to queue that were held back before startup event
2020-08-16 15:25:45,174 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2020-08-16 15:25:45,201 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2020-08-16 15:25:45,206 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2020-08-16 15:25:45,237 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2020-08-16 15:25:45,464 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _http._tcp
2020-08-16 15:25:45,580 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _octoprint._tcp
2020-08-16 15:25:45,630 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2020-08-16 15:25:45,896 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2020-08-16 15:25:45,909 - octoprint.server - INFO - Server started successfully in safe mode as requested from config, removing flag
2020-08-16 15:25:47,224 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-08-16 15:26:21,510 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-08-16 15:26:21,566 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-08-16 15:26:21,580 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-08-16 15:26:21,754 - octoprint.plugins.softwareupdate - INFO - Minimum free storage across all update relevant locations is 12.5GB. That is considered sufficient for updating.
2020-08-16 15:26:24,150 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://192.168.0.19/'}
Try a reinstall?
SSH into the Pi and run:
~/oprint/bin/pip install --force-reinstall --no-cache-dir octoprint
If that does not work, try getting a new image of OctoPi and flashing it, maybe?
Seeing as there is no error, it could simply be that something has got corrupted? Worth a try, maybe? not sure what else.
No difference after trying both. Maybe the Pi is just too old? Or a network issue?
Not old, but quite underpowered.
After a few reboots, I'm now getting this message, " OctoPrint server started, waiting for it to get ready..." Hasn't moved off this screen. Surely down to the lack of performance from that single core?
