Octoprint Crashing
I have a Raspberry Pi 4 with 1 gig on board memory, a 32 gig Sandisk card, and a 3amp Raspberry Pi power supply.
Octoprint or the Pi has crashed several times now. The hot end stays hot and so does the bed, but when going back to my computer it says "Server is offline". At this point I have to restart my Octopi by unplugging it and plugging it back in.
I am using a brand new Tevo Tornado. The printer works fine when I use the SD card directly into the printer.
I am not very computer savy so I am not sure what to do. I would love some help with this.
Continuing the discussion from Octoprint Crashing:
I have as much information as I can provide. I can't find any logs to be able to help out beyond this. I AM NOT A COMPUTER PERSON.
Version of Octoprint would the be latest. I am sorry you couldn't parse that out from "I am new to this"
and that everything I have is NEW.
There is also information that you are asking for that I don't know how to find out.
I am just looking for some answers.
Every time I have asked about this in FB groups all I get is the same answer.
"What's your power supply?" or "What is your memory card?"
I am looking for more here. There has to be someone who is familiar with this problem.
This is an Octoprint Problem not a problem with my version of Cura (newest) or the printer.
The printer works fine off of the SD card.
It only crashes when I use Octoprint.
It is the Octopi itself that crashes.
Well I am sorry you couldn't parse that no logs, no support means no logs, no support.
We can't look into our crystal balls and tell you what is wrong.
This will tell you how to get to the logs
read the link I provided and post the logs and change your attitude to something more friendly
You will have to forgive my frustration. When you pay money for items, like the pi, power supply, make a case, buy an SD card, upgrade the printer cable, and it doesn't work as advertised...it is a major pain. Not to mention the loss of time and all the wasted filament because of the failure of a program.
I just want some answers as to why my Octoprint keeps crashing.
If you are asking about the "serial.log" files are empty.
Here is the catch 22. You can enable logging but it can negatively impact performance.
I think the analogy here is that we're remote doctors who can't see your printer. So we rely upon you to provide the information needed in order to diagnose "the patient".
It's necessary to remote into the Pi via a terminal in order to fetch the log(s) in question.
ssh pi@octopi.local # password by default is "raspberry"
cd ~/.octoprint/logs
cat octoprint.log
This activity is unfortunate because it can possibly have the effect of corrupting your microSD card.
You might try to bring it up in Safe Mode. Like earlier, when "logs" was a clickable link, "safe mode" is here as well. Follow this link to figure out how to start it in safe mode. This will temporarily turn off third-party plugins which might be causing the problem.
Thank for the helpful reply. I am turned logging back on and have tried a couple of longer prints.
At this point it has not crashed yet.
I am on hour 18 of a 36 hour print and it seems ok at the moment.
Ok, so on my 3rd long print it crashed again...
2020-01-03 03:05:19,806 - Changing monitoring state from "Offline" to "Detecting serial port"
2020-01-03 03:05:19,933 - Serial port list: ['/dev/ttyUSB0']
2020-01-03 03:05:19,934 - Connecting to: /dev/ttyUSB0
2020-01-03 03:05:20,004 - Changing monitoring state from "Detecting serial port" to "Opening serial port"
2020-01-03 03:05:20,006 - Connected to: Serial<id=0xac625710, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=120.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-01-03 03:05:20,007 - Starting baud rate detection...
2020-01-03 03:05:20,009 - Changing monitoring state from "Opening serial port" to "Detecting baudrate"
2020-01-03 03:05:50,040 - Trying baudrate: 115200
2020-01-03 03:05:50,049 - Recv: �Np|4f6|>,JpOF6��B�jQ�B� or�DA��� af�6�P�H�J�b�� :�]�'��)
2020-01-03 03:05:50,055 - Send: N0 M110 N0*125
2020-01-03 03:07:50,153 - Baudrate test retry #1
2020-01-03 03:07:50,160 - Send: N0 M110 N0*125
2020-01-03 03:08:00,159 - Baudrate test retry #2
2020-01-03 03:08:00,169 - Send: N0 M110 N0*125
2020-01-03 03:08:10,171 - Baudrate test retry #3
2020-01-03 03:08:10,185 - Send: N0 M110 N0*125
2020-01-03 03:08:20,187 - Baudrate test retry #4
2020-01-03 03:08:20,197 - Send: N0 M110 N0*125
2020-01-03 03:08:30,205 - Trying baudrate: 250000
2020-01-03 03:08:30,211 - Send: N0 M110 N0*125
2020-01-03 03:08:30,212 - Recv: �0jV>h.&a|��0e�b�a"*�MMrC6d"�p|@�e�E@�B�k�e�A`�Atp:EePe>�P.`�pt(Y�@�J�J�@��@\&v�B�JTe�Te���%�C�2"6XB�}�<p|,�B�J�Z�BQ� PJtt8n�eB:he�bf�J�B�B�J�)p%�@��eN>`}�j�Ka7.aCP�..iCKe�*�v�B�J�%TB�%�A�!TJp|PGmB�:M�&e�>S&�E�&e�:�eAgY�6fLe�{66�Ce2��;aB�J�I�r�B�(%� %�0�B��H�*�Qa2B�Z�I�rN�X�"&2|&B*e^v�B�K� BJ�@�C�(B!P:zO>�v�B�J�Jza9�T�@�B�J�-��~R
 B�;echo:Unknown command: ""
2020-01-03 03:08:30,216 - Recv: ok
2020-01-03 03:08:30,228 - Changing monitoring state from "Detecting baudrate" to "Operational"
2020-01-03 03:08:30,378 - Send: N0 M110 N0*125
2020-01-03 03:08:30,379 - Recv: ok
2020-01-03 03:08:30,381 - Send: N1 M115*39
2020-01-03 03:08:30,382 - Recv: ok
2020-01-03 03:08:30,386 - Send: N2 M21*18
2020-01-03 03:08:30,391 - Recv: FIRMWARE_NAME:Marlin TORNADO (Github) SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:TEVO Tornado EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
2020-01-03 03:08:30,411 - Recv: Cap:EEPROM:1
2020-01-03 03:08:30,412 - Recv: Cap:AUTOREPORT_TEMP:1
2020-01-03 03:08:30,414 - Recv: Cap:PROGRESS:0
2020-01-03 03:08:30,415 - Recv: Cap:PRINT_JOB:1
2020-01-03 03:08:30,416 - Recv: Cap:AUTOLEVEL:0
2020-01-03 03:08:30,417 - Recv: Cap:Z_PROBE:0
2020-01-03 03:08:30,421 - Recv: Cap:LEVELING_DATA:0
2020-01-03 03:08:30,422 - Recv: Cap:SOFTWARE_POWER:0
2020-01-03 03:08:30,423 - Recv: Cap:TOGGLE_LIGHTS:0
2020-01-03 03:08:30,425 - Recv: Cap:CASE_LIGHT_BRIGHTNESS:0
2020-01-03 03:08:30,426 - Recv: Cap:EMERGENCY_PARSER:0
2020-01-03 03:08:30,429 - Recv: ok
2020-01-03 03:08:30,430 - Send: M155 S2
2020-01-03 03:08:31,364 - Recv: Error:volume.init failed
2020-01-03 03:08:31,371 - Recv: ok
2020-01-03 03:08:31,374 - Recv: ok
2020-01-03 03:08:33,365 - Recv:  T:17.50 /0.00 B:16.84 /0.00 @:0 B@:0
2020-01-03 03:08:35,365 - Recv:  T:16.60 /0.00 B:16.76 /0.00 @:0 B@:0
2020-01-03 03:08:37,365 - Recv:  T:17.15 /0.00 B:17.42 /0.00 @:0 B@:0
2020-01-03 03:08:37,857 - Changing monitoring state from "Operational" to "Starting"
2020-01-03 03:08:37,962 - Send: N3 M117 ETA: -*96
2020-01-03 03:08:37,969 - Recv: ok
2020-01-03 03:08:37,973 - Changing monitoring state from "Starting" to "Cancelling"
2020-01-03 03:08:38,032 - Send: N4 M108*46
2020-01-03 03:08:38,105 - Changing monitoring state from "Cancelling" to "Printing"
2020-01-03 03:08:38,210 - Recv: ok
2020-01-03 03:08:38,219 - Send: N0 M110 N0*125
2020-01-03 03:08:38,225 - Send: N1 M84*30
2020-01-03 03:08:38,226 - Recv: ok
2020-01-03 03:08:38,268 - Send: N2 M104 T0 S0*35
2020-01-03 03:08:38,270 - Recv: ok
2020-01-03 03:08:38,337 - Send: N3 M140 S0*102
2020-01-03 03:08:38,339 - Recv: ok
2020-01-03 03:08:38,341 - Send: N4 M106 S0*99
2020-01-03 03:08:38,451 - Recv: ok
2020-01-03 03:08:38,482 - Changing monitoring state from "Printing" to "Operational"
2020-01-03 03:08:38,484 - Recv: ok
2020-01-03 03:08:39,365 - Recv:  T:18.12 /0.00 B:17.27 /0.00 @:0 B@:0
2020-01-03 03:08:41,365 - Recv:  T:18.16 /0.00 B:16.76 /0.00 @:0 B@:0
2020-01-03 03:08:43,366 - Recv:  T:16.80 /0.00 B:16.91 /0.00 @:0 B@:0
2020-01-03 03:08:45,365 - Recv:  T:16.95 /0.00 B:16.68 /0.00 @:0 B@:0
2020-01-03 03:08:47,364 - Recv:  T:16.60 /0.00 B:16.64 /0.00 @:0 B@:0
2020-01-03 03:08:49,364 - Recv:  T:16.76 /0.00 B:16.84 /0.00 @:0 B@:0
2020-01-03 03:08:51,365 - Recv:  T:16.64 /0.00 B:16.80 /0.00 @:0 B@:0
2020-01-03 03:08:53,364 - Recv:  T:17.15 /0.00 B:16.95 /0.00 @:0 B@:0
2020-01-03 03:08:55,364 - Recv:  T:16.64 /0.00 B:16.52 /0.00 @:0 B@:0
2020-01-03 03:08:57,364 - Recv:  T:17.38 /0.00 B:17.38 /0.00 @:0 B@:0
2020-01-03 03:08:59,364 - Recv:  T:17.54 /0.00 B:17.19 /0.00 @:0 B@:0
2020-01-03 03:09:01,148 - Changing monitoring state from "Operational" to "Starting"
2020-01-03 03:09:01,310 - Send: N5 M117 ETA: -*102
2020-01-03 03:09:01,314 - Recv: ok
2020-01-03 03:09:01,317 - Changing monitoring state from "Starting" to "Cancelling"
2020-01-03 03:09:01,324 - Send: N6 M108*44
2020-01-03 03:09:01,385 - Recv: ok
2020-01-03 03:09:01,393 - Changing monitoring state from "Cancelling" to "Printing"
2020-01-03 03:09:01,396 - Recv:  T:17.03 /0.00 B:16.60 /0.00 @:0 B@:0
2020-01-03 03:09:01,504 - Send: N0 M110 N0*125
2020-01-03 03:09:01,507 - Send: N1 M84*30
2020-01-03 03:09:01,510 - Recv: ok
2020-01-03 03:09:01,543 - Recv: ok
2020-01-03 03:09:01,555 - Send: N2 M104 T0 S0*35
2020-01-03 03:09:01,618 - Recv: ok
2020-01-03 03:09:01,622 - Send: N3 M140 S0*102
2020-01-03 03:09:01,639 - Send: N4 M106 S0*99
2020-01-03 03:09:01,656 - Recv: ok
2020-01-03 03:09:01,678 - Recv: ok
2020-01-03 03:09:01,688 - Changing monitoring state from "Printing" to "Operational"
2020-01-03 03:09:03,363 - Recv:  T:17.93 /0.00 B:16.68 /0.00 @:0 B@:0
2020-01-03 03:09:05,363 - Recv:  T:16.76 /0.00 B:16.72 /0.00 @:0 B@:0
2020-01-03 03:09:07,364 - Recv:  T:17.15 /0.00 B:17.11 /0.00 @:0 B@:0
2020-01-03 03:09:09,364 - Recv:  T:17.54 /0.00 B:16.72 /0.00 @:0 B@:0
2020-01-03 03:09:11,364 - Recv:  T:17.46 /0.00 B:17.11 /0.00 @:0 B@:0
2020-01-03 03:09:13,364 - Recv:  T:16.33 /0.00 B:17.42 /0.00 @:0 B@:0
2020-01-03 03:09:15,363 - Recv:  T:16.84 /0.00 B:16.99 /0.00 @:0 B@:0
2020-01-03 03:09:17,363 - Recv:  T:16.80 /0.00 B:16.29 /0.00 @:0 B@:0
2020-01-03 03:09:19,363 - Recv:  T:16.91 /0.00 B:16.68 /0.00 @:0 B@:0
2020-01-03 03:09:21,380 - Recv:  T:17.23 /0.00 B:17.62 /0.00 @:0 B@:0
2020-01-03 03:09:23,380 - Recv:  T:16.87 /0.00 B:16.37 /0.00 @:0 B@:0
2020-01-03 03:09:25,380 - Recv:  T:16.64 /0.00 B:16.52 /0.00 @:0 B@:0
2020-01-03 03:09:27,379 - Recv:  T:17.30 /0.00 B:16.87 /0.00 @:0 B@:0
2020-01-03 03:09:29,380 - Recv:  T:17.42 /0.00 B:16.68 /0.00 @:0 B@:0
2020-01-03 03:09:31,380 - Recv:  T:17.46 /0.00 B:18.16 /0.00 @:0 B@:0
2020-01-03 03:09:33,379 - Recv:  T:16.95 /0.00 B:16.91 /0.00 @:0 B@:0
2020-01-03 03:09:35,379 - Recv:  T:16.56 /0.00 B:17.23 /0.00 @:0 B@:0
2020-01-03 03:09:37,379 - Recv:  T:16.99 /0.00 B:17.15 /0.00 @:0 B@:0
According to the cryptic lines in the log, it seems there is an issue with the USB connection.
You may have a look ont the hints here: OctoPrint randomly loses connection to the printer with a "SerialException"
Seems weird. It was working away, then dead.
I was sitting in the same room. I opened up my laptop and it wouldn't connect to the octopi until I unplugged the power from it (the pi) and plugged it back in.
Anyway, what would cause an issue like this?
In this case the octoprint.log would be quite handy and the complete serial.log too.
It could be a lot of things: Undervoltage, unstable mains power, interference from another home device, a plugin that has issues...
I am not sure I can post all 6000 lines in that log...
did that work?
octoprint.log (751.6 KB)
No problem with the size...
Ok, there are a lot of errors with thespaghettidetective. You may start OctoPrint in safemode.
Some errors a caused by internet connection problems (assumingly the thespaghettidetective is affected by these).
Seems that they are getting rid of the Octo-anywhere and recommending The Spaghetti Detective as the way to monitor prints online.
So, having that not working makes having the Octoprint useless.
Unless there is something else that I am missing.
If I disable the spaghetti detective then I can't watch my prints when I am not at home.
Looks like you have both the get-anywhere plugin and TSD plugin installed. This is not supported by TSD.
I removed the get-anywhere plugin and reinstalled the spaghetti detective
Hey guys,
I have a similar problem with octopi crashing. Here are the last lines from the log file. I hope you'll find my problem cause. Thanks
2020-11-22 08:02:35,809 - octoprint.util.comm - INFO - Changing monitoring state        from "Starting" to "Printing"
2020-11-22 08:02:37,862 - octoprint.util.comm - INFO - Printer seems to support        the busy protocol, will adjust timeouts and set busy interval accordingly
2020-11-22 08:02:49,174 - octoprint.util.comm - INFO - Telling the printer to se        t the busy interval to our "communicationBusy" timeout - 1s = 2s
2020-11-22 08:03:43,023 - octoprint.plugins.mattacloud - ERROR - Socket send_msg        : EOF occurred in violation of protocol (_ssl.c:1829)
2020-11-22 08:03:44,073 - octoprint.plugins.mattacloud - ERROR - ws_on_error: [S        SL: SSLV3_ALERT_BAD_RECORD_MAC] sslv3 alert bad record mac (_ssl.c:1946), URL: h        ttps://cloud.mattalabs.com, Token: 4303780960580e50
2020-11-22 08:03:44,123 - octoprint.plugins.mattacloud - INFO - Closing websocke        t...
2020-11-22 08:03:44,121 - octoprint.plugins.mattacloud - ERROR - Socket send_msg        : TLS/SSL connection has been closed (EOF) (_ssl.c:1829)
2020-11-22 08:03:46,129 - octoprint.plugins.mattacloud - ERROR - Attempt: 1
2020-11-22 08:03:46,135 - octoprint.plugins.mattacloud - INFO - Connecting webso        cket
2020-11-22 08:03:47,668 - octoprint.plugins.mattacloud - INFO - Opening websocke        t...
For the good of our eyes, please either upload the entire file (using the little up arrow in the editor, or drag and drop), or use the </> button to format it. That's not the complete log file, so it's really difficult to know.
Try safe mode. The errors in your log come from a plugin - make sure that the plugin is not the cause. Really difficult to tell from such a small amount of information, but try it.
Someone else was seeing stability issues and data corruption with the mattacloud plugin:
I'm not using mattacloud plugin, but I've not experienced any crash with 1.5.0rc2!
The only strange behavior is occouring now, Octoprint is consuming 97% of raspberry 4 cpus and the web interface is blocking the browser!
