Octoprint keeps crashing
Octoprint server keeps crashing, raspberry pi is still available with putty. A few times the sd card has been corrupted and had to be recreated.
Tried different Raspberry pi's (both 2b and 3 b nodels), different sd cards, different power supplies.
octoprint.log (704.3 KB)
Octoprint - 1.3.12
Octopi - 0.17.0
Anet A8
Th3d firmawre
Chrome
Windows 10
When I run the command to see it the server is running it doesn't show anything. When I try to run the command to restart it complains about a missing library
/bin/systemd-tty-ask-password-agent: error while loading shared libraries: dkblzma.so.5
DibYSl.so.1.1: cannot open shared object file: No such file or directory
If I reboot the PI the server starts up again and runs for a couple hours and quits again.
At least this node got undervoltage issues.
Use a sufficient psu (not a phone charger).
If your printer draws too much current via usb you might want to try this
I still have the problem after changing power supplies. I have a 2.5 amp power supply on it now. I will try the tape trick. I also occasionally get server connection has been lost when I am connecting remotely.
octoprint.log (202.5 KB) after changing power supplies. I will try the tape trick.
I think I'd run:
sudo apt-get update
sudo apt-get upgrade
