Have you tried the port lister plugin?
First things first, try the plugin as suggested. I'm sure it's simpler than what I do.
Look for your controller board:
lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 03eb:8a6e Atmel Corp.
Bus 001 Device 004: ID 1d50:6015 OpenMoko, Inc. Smoothieboard <- TARGET
Bus 001 Device 003: ID f055:9800
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Note the ID information for that. It's 1d50 + 6015 in my case.
Look for an existing udev rule for serial ports:
ls -l /etc/udev/rules.d/99-usb-serial.rules
-rw-r--r-- 1 root root 309 Mar 12 19:31 /etc/udev/rules.d/99-usb-serial.rules
In my case, I have one and I'll need to edit it. It's also possible that it doesn't exist and could be created. If it doesn't exist then
sudo touch /etc/udev/rules.d/99-usb-serial.rulesto create an empty one. Next,sudo chmod 644 /etc/udev/rules.d/99-usb-serial.rulesso that the rights are correct.
Edit it:
Note how I've plugged in the idVendor and idProduct which we learned earlier. Also note that I'm creating an alias of /dev/smoothieboard for my board. Yours will likely be different so make the necessary adjustments for your setup. Be careful not to use anything as an alias which might already be used so feel free to call it chewbacca or something unique.
sudo nano /etc/udev/rules.d/99-usb-serial.rules
# --- Contents follow, adding this
SUBSYSTEM=="tty", ATTRS{idVendor}=="1d50", ATTRS{idProduct}=="6015", SYMLINK+="smoothieboard"
# --- End of contents to add
(Carefully) edit your config.yaml:
Note that yaml files are finicky about whitespace at the beginning of lines.
# Safety first, save the original one
cp ~/.octoprint/config.yaml ~/.octoprint/config.yaml.saveme
nano ~/.octoprint/config.yaml
# --- You need this paragraph; it may be necessary to edit the existing
# --- section, noting that the main headings are alphabetically-sorted.
serial:
additionalPorts:
- /dev/smoothieboard
autoconnect: true
baudrate: 112500
port: /dev/smoothieboard
# --- End of edits
In my config.yaml the prefixing whitespace is exactly four space characters.
Reboot everything and check to see if it's happier. Keep that copy of your config.yaml.saveme in case bad things happen.
Yes, I have had PortLister for about a day now. It refreshes the serial ports list, tries and fails to auto connect, and that is about it.
When I tried this before I didn't set the permissions and didn't edit the yaml file.
It works now however. I can finally walk up to the printer, turn it on, and print something with OctoScreen without fussing with my phone or WebUI. Huge thanks for the guide. I am sure it will come in handy for others that have this issue until it is fixed.
False alarm, I am having more issues now.
On a fresh reboot I can sometimes get it to connect but most times I get an "[Errno 11] Could not exclusively lock port". This is with the PiCam disconnected. Also tested a different USB cable on the other bank of USB ports. Disabled all plugins except PSU Control (I would have to disassemble the printer and re-wire).
I have another Pi. I am going to try to test a fresh installation without the PiCam/PiTFT but at this point I am thinking about just reverting to 1.3
Connecting to: /dev/EZBoard
Changing monitoring state from "Offline" to "Opening serial port"
Connected to: Serial<id=0x69b862f0, open=True>(port='/dev/EZBoard', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Changing monitoring state from "Opening serial port" to "Connecting"
Send: N0 M110 N0*125
Recv: ok
Changing monitoring state from "Connecting" to "Operational"
Recv: ok
Recv: ok
Send: N1 M115*39
Recv: FIRMWARE_NAME:Marlin TH3D U2.R1.A3 SOURCE_CODE_URL:TH3DStudio.com PROTOCOL_VERSION:1.0 MACHINE_TYPE:TH3D EZABL EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
Recv: Cap:SERIAL_XON_XOFF:0
Recv: Cap:BINARY_FILE_TRANSFER:0
Recv: Cap:EEPROM:1
Recv: Cap:VOLUMETRIC:0
Recv: Cap:AUTOREPORT_TEMP:1
Changing monitoring state from "Offline" to "Error: Connection error, see Terminal tab"
Recv: Cap:PROGRESS:0
Recv: Cap:PRINT_JOB:1
Recv: Cap:AUTOLEVEL:1
Recv: Cap:Z_PROBE:1
Unexpected error while connecting to serial port: /dev/EZBoard SerialException: '[Errno 11] Could not exclusively lock port /dev/EZBoard: [Errno 11] Resource temporarily unavailable' @ comm.py:_openSerial:2691 (hook default)
Recv: Cap:LEVELING_DATA:1
Recv: Cap:BUILD_PERCENT:1
Recv: Cap:SOFTWARE_POWER:0
Recv: Cap:TOGGLE_LIGHTS:0
Recv: Cap:CASE_LIGHT_BRIGHTNESS:0
Recv: Cap:EMERGENCY_PARSER:0
Recv: Cap:PROMPT_SUPPORT:0
Recv: Cap:AUTOREPORT_SD_STATUS:1
Recv: Cap:THERMAL_PROTECTION:1
Recv: Cap:MOTION_MODES:0
Recv: Cap:CHAMBER_TEMPERATURE:0
Recv: ok
Send: M155 S2
Try lowercase for the device alias. I know of no other devices which include uppercase characters in them.
Also after rebooting and during troubleshooting, the udev rule should actually create the device tree entry for you: ls -l /dev | grep lrwxrwxrwx
And yet, it's throwing an error to suggest that it can't lock the device.
Quoting myself from the github issue:
Can those of you running into this issue try if it gets solved by this plugin?
https://github.com/OctoPrint/OctoPrint-Remove-ttyS-Ports
It monkey patches the serial list to remove
/dev/ttySentries from the port list again and thus should work around this issue on what seems to be most of the system that so far ran into issues.If this works I'll push it to the repository as a workaround until I have pushed a proper solution with 1.4.1 (hopefully).
Re-installed from scratch and I have my Pi Cam and Touchscreen installed. Everything is up to date. I have PSU Control and Port Lister installed and I no longer have any issues. I've restarted and turned the printer/Raspberry Pi on/off several times and it just works now. No idea why.
Still waiting for feedback here, @5ft24, @kallsop, @kubik256, @Mortimus, would love to get feedback if this fixes it for y'all:
This is working on both my A8 and my Girlfriends Ender 3
Works here too! Thank you
Machine: Ender3 with SKR E3 mini
Octoprint on Intel NUC / x64 - Ubuntu 19.10 (GNU/Linux 5.3.0-42-generic x86_64)
Update: This plugin also fixed Tasmota autoconnect feature - setup 40-60s delay (for E3 mini) and it works like a charm
AWESOME
It works for me, thanks.
Unfortunately it does not solve the problems I have with orange pi zero. Armbian does not create /dev/ttyS ... but there is a virtual serial connected to the USB otg present in the Orange Pi zero /dev/ttyGS0 which probably should also be ignored.
Perhaps it would be the case to create a global pattern exclusion with preset values that the user can however modify in case of need.
If you're a coder and you wanted a quick fix you could fork the work-around plugin and make it do what you need.
Of course I can do it but I could also make Armbian not load the UsbOTG virtual serial driver.
Even more simple I can give up automatic search of the printer port connection and set it by hand on ttyUSB0.
My intent was only to report that the problem is also present with other devices and excluding only ttyS .. it may not be exhaustive.
It would also be possible to take advantage of the "Additional serial ports" field of the settings and exclude from the recognized devices those negated for example
/dev/ttyAMA*
!/dev/ttyS*
!/dev/ttyGS*
Yeah... I did
your suggestion since it's a good idea.
/dev/ttyG* is not and never was part of the port patterns
This morning I did a test, I put g_serial in the blacklist so that ttyGS0 is not created.
First the list of tty devices is this :
pi@octopi:~$ ls /dev/tty*
tty tty31 tty55 ttya3 ttybd ttyd7 ttyp1 ttyqb ttys5 ttytf ttyv9 ttyx3 ttyyd
tty0 tty32 tty56 ttya4 ttybe ttyd8 ttyp2 ttyqc ttys6 ttyu0 ttyva ttyx4 ttyye
tty1 tty33 tty57 ttya5 ttybf ttyd9 ttyp3 ttyqd ttys7 ttyu1 ttyvb ttyx5 ttyyf
tty10 tty34 tty58 ttya6 ttyc0 ttyda ttyp4 ttyqe ttys8 ttyu2 ttyvc ttyx6 ttyz0
tty11 tty35 tty59 ttya7 ttyc1 ttydb ttyp5 ttyqf ttys9 ttyu3 ttyvd ttyx7 ttyz1
tty12 tty36 tty6 ttya8 ttyc2 ttydc ttyp6 ttyr0 ttysa ttyu4 ttyve ttyx8 ttyz2
tty13 tty37 tty60 ttya9 ttyc3 ttydd ttyp7 ttyr1 ttysb ttyu5 ttyvf ttyx9 ttyz3
tty14 tty38 tty61 ttyaa ttyc4 ttyde ttyp8 ttyr2 ttysc ttyu6 ttyw0 ttyxa ttyz4
tty15 tty39 tty62 ttyab ttyc5 ttydf ttyp9 ttyr3 ttysd ttyu7 ttyw1 ttyxb ttyz5
tty16 tty4 tty63 ttyac ttyc6 ttye0 ttypa ttyr4 ttyse ttyu8 ttyw2 ttyxc ttyz6
tty17 tty40 tty7 ttyad ttyc7 ttye1 ttypb ttyr5 ttysf ttyu9 ttyw3 ttyxd ttyz7
tty18 tty41 tty8 ttyae ttyc8 ttye2 ttypc ttyr6 ttyt0 ttyua ttyw4 ttyxe ttyz8
tty19 tty42 tty9 ttyaf ttyc9 ttye3 ttypd ttyr7 ttyt1 ttyub ttyw5 ttyxf ttyz9
tty2 tty43 > ttyGS0 ttyb0 ttyca ttye4 ttype ttyr8 ttyt2 ttyuc ttyw6 ttyy0 ttyza
tty20 tty44 ttyS0 ttyb1 ttycb ttye5 ttypf ttyr9 ttyt3 ttyud ttyw7 ttyy1 ttyzb
tty21 tty45 ttyS1 ttyb2 ttycc ttye6 ttyq0 ttyra ttyt4 ttyue ttyw8 ttyy2 ttyzc
tty22 tty46 ttyS2 ttyb3 ttycd ttye7 ttyq1 ttyrb ttyt5 ttyuf ttyw9 ttyy3 ttyzd
tty23 tty47 ttyS3 ttyb4 ttyce ttye8 ttyq2 ttyrc ttyt6 ttyv0 ttywa ttyy4 ttyze
tty24 tty48 ttyS4 ttyb5 ttycf ttye9 ttyq3 ttyrd ttyt7 ttyv1 ttywb ttyy5 ttyzf
tty25 tty49 ttyS5 ttyb6 ttyd0 ttyea ttyq4 ttyre ttyt8 ttyv2 ttywc ttyy6
tty26 tty5 ttyS6 ttyb7 ttyd1 ttyeb ttyq5 ttyrf ttyt9 ttyv3 ttywd ttyy7
tty27 tty50 ttyS7 ttyb8 ttyd2 ttyec ttyq6 ttys0 ttyta ttyv4 ttywe ttyy8
tty28 tty51 > ttyUSB0 ttyb9 ttyd3 ttyed ttyq7 ttys1 ttytb ttyv5 ttywf ttyy9
tty29 tty52 ttya0 ttyba ttyd4 ttyee ttyq8 ttys2 ttytc ttyv6 ttyx0 ttyya
tty3 tty53 ttya1 ttybb ttyd5 ttyef ttyq9 ttys3 ttytd ttyv7 ttyx1 ttyyb
tty30 tty54 ttya2 ttybc ttyd6 ttyp0 ttyqa ttys4 ttyte ttyv8 ttyx2 ttyyc
From here we can see that the only "strange" device is ttyGS0
After blacklisting the result is:
/dev/tty /dev/tty41 /dev/ttya0 /dev/ttyc5 /dev/ttyea /dev/ttyqf /dev/ttyt4 /dev/ttyv9 /dev/ttyxe
/dev/tty0 /dev/tty42 /dev/ttya1 /dev/ttyc6 /dev/ttyeb /dev/ttyr0 /dev/ttyt5 /dev/ttyva /dev/ttyxf
/dev/tty1 /dev/tty43 /dev/ttya2 /dev/ttyc7 /dev/ttyec /dev/ttyr1 /dev/ttyt6 /dev/ttyvb /dev/ttyy0
/dev/tty10 /dev/tty44 /dev/ttya3 /dev/ttyc8 /dev/ttyed /dev/ttyr2 /dev/ttyt7 /dev/ttyvc /dev/ttyy1
/dev/tty11 /dev/tty45 /dev/ttya4 /dev/ttyc9 /dev/ttyee /dev/ttyr3 /dev/ttyt8 /dev/ttyvd /dev/ttyy2
/dev/tty12 /dev/tty46 /dev/ttya5 /dev/ttyca /dev/ttyef /dev/ttyr4 /dev/ttyt9 /dev/ttyve /dev/ttyy3
/dev/tty13 /dev/tty47 /dev/ttya6 /dev/ttycb /dev/ttyp0 /dev/ttyr5 /dev/ttyta /dev/ttyvf /dev/ttyy4
/dev/tty14 /dev/tty48 /dev/ttya7 /dev/ttycc /dev/ttyp1 /dev/ttyr6 /dev/ttytb /dev/ttyw0 /dev/ttyy5
/dev/tty15 /dev/tty49 /dev/ttya8 /dev/ttycd /dev/ttyp2 /dev/ttyr7 /dev/ttytc /dev/ttyw1 /dev/ttyy6
/dev/tty16 /dev/tty5 /dev/ttya9 /dev/ttyce /dev/ttyp3 /dev/ttyr8 /dev/ttytd /dev/ttyw2 /dev/ttyy7
/dev/tty17 /dev/tty50 /dev/ttyaa /dev/ttycf /dev/ttyp4 /dev/ttyr9 /dev/ttyte /dev/ttyw3 /dev/ttyy8
/dev/tty18 /dev/tty51 /dev/ttyab /dev/ttyd0 /dev/ttyp5 /dev/ttyra /dev/ttytf /dev/ttyw4 /dev/ttyy9
/dev/tty19 /dev/tty52 /dev/ttyac /dev/ttyd1 /dev/ttyp6 /dev/ttyrb /dev/ttyu0 /dev/ttyw5 /dev/ttyya
/dev/tty2 /dev/tty53 /dev/ttyad /dev/ttyd2 /dev/ttyp7 /dev/ttyrc /dev/ttyu1 /dev/ttyw6 /dev/ttyyb
/dev/tty20 /dev/tty54 /dev/ttyae /dev/ttyd3 /dev/ttyp8 /dev/ttyrd /dev/ttyu2 /dev/ttyw7 /dev/ttyyc
/dev/tty21 /dev/tty55 /dev/ttyaf /dev/ttyd4 /dev/ttyp9 /dev/ttyre /dev/ttyu3 /dev/ttyw8 /dev/ttyyd
/dev/tty22 /dev/tty56 /dev/ttyb0 /dev/ttyd5 /dev/ttypa /dev/ttyrf /dev/ttyu4 /dev/ttyw9 /dev/ttyye
/dev/tty23 /dev/tty57 /dev/ttyb1 /dev/ttyd6 /dev/ttypb /dev/ttys0 /dev/ttyu5 /dev/ttywa /dev/ttyyf
/dev/tty24 /dev/tty58 /dev/ttyb2 /dev/ttyd7 /dev/ttypc /dev/ttys1 /dev/ttyu6 /dev/ttywb /dev/ttyz0
/dev/tty25 /dev/tty59 /dev/ttyb3 /dev/ttyd8 /dev/ttypd /dev/ttys2 /dev/ttyu7 /dev/ttywc /dev/ttyz1
/dev/tty26 /dev/tty6 /dev/ttyb4 /dev/ttyd9 /dev/ttype /dev/ttys3 /dev/ttyu8 /dev/ttywd /dev/ttyz2
/dev/tty27 /dev/tty60 /dev/ttyb5 /dev/ttyda /dev/ttypf /dev/ttys4 /dev/ttyu9 /dev/ttywe /dev/ttyz3
/dev/tty28 /dev/tty61 /dev/ttyb6 /dev/ttydb /dev/ttyq0 /dev/ttys5 /dev/ttyua /dev/ttywf /dev/ttyz4
/dev/tty29 /dev/tty62 /dev/ttyb7 /dev/ttydc /dev/ttyq1 /dev/ttys6 /dev/ttyub /dev/ttyx0 /dev/ttyz5
/dev/tty3 /dev/tty63 /dev/ttyb8 /dev/ttydd /dev/ttyq2 /dev/ttys7 /dev/ttyuc /dev/ttyx1 /dev/ttyz6
/dev/tty30 /dev/tty7 /dev/ttyb9 /dev/ttyde /dev/ttyq3 /dev/ttys8 /dev/ttyud /dev/ttyx2 /dev/ttyz7
/dev/tty31 /dev/tty8 /dev/ttyba /dev/ttydf /dev/ttyq4 /dev/ttys9 /dev/ttyue /dev/ttyx3 /dev/ttyz8
/dev/tty32 /dev/tty9 /dev/ttybb /dev/ttye0 /dev/ttyq5 /dev/ttysa /dev/ttyuf /dev/ttyx4 /dev/ttyz9
/dev/tty33 /dev/ttyS0 /dev/ttybc /dev/ttye1 /dev/ttyq6 /dev/ttysb /dev/ttyv0 /dev/ttyx5 /dev/ttyza
/dev/tty34 /dev/ttyS1 /dev/ttybd /dev/ttye2 /dev/ttyq7 /dev/ttysc /dev/ttyv1 /dev/ttyx6 /dev/ttyzb
/dev/tty35 /dev/ttyS2 /dev/ttybe /dev/ttye3 /dev/ttyq8 /dev/ttysd /dev/ttyv2 /dev/ttyx7 /dev/ttyzc
/dev/tty36 /dev/ttyS3 /dev/ttybf /dev/ttye4 /dev/ttyq9 /dev/ttyse /dev/ttyv3 /dev/ttyx8 /dev/ttyzd
/dev/tty37 /dev/ttyS4 /dev/ttyc0 /dev/ttye5 /dev/ttyqa /dev/ttysf /dev/ttyv4 /dev/ttyx9 /dev/ttyze
/dev/tty38 /dev/ttyS5 /dev/ttyc1 /dev/ttye6 /dev/ttyqb /dev/ttyt0 /dev/ttyv5 /dev/ttyxa /dev/ttyzf
/dev/tty39 /dev/ttyS6 /dev/ttyc2 /dev/ttye7 /dev/ttyqc /dev/ttyt1 /dev/ttyv6 /dev/ttyxb
/dev/tty4 /dev/ttyS7 /dev/ttyc3 /dev/ttye8 /dev/ttyqd /dev/ttyt2 /dev/ttyv7 /dev/ttyxc
/dev/tty40 >/dev/ttyUSB0 /dev/ttyc4 /dev/ttye9 /dev/ttyqe /dev/ttyt3 /dev/ttyv8 /dev/ttyxd
e here
According to the code you posted the only match is ttyUSB0, the problem is that still fails autodetect.
Changing monitoring state from "Offline" to "Detecting serial port"
Serial port list: ['/dev/ttyUSB0', u'/dev/ttyS0', u'/dev/ttyS7', u'/dev/ttyS6', u'/dev/ttyS5', u'/dev/ttyS4', u'/dev/ttyS3', u'/dev/ttyS2', u'/dev/ttyS1']
Trying /dev/ttyUSB0
Could not connect to or enter programming mode on /dev/ttyUSB0, might not be a printer or just not allow programming mode
Trying /dev/ttyS0
Could not connect to or enter programming mode on /dev/ttyS0, might not be a printer or just not allow programming mode
Trying /dev/ttyS7
Could not connect to or enter programming mode on /dev/ttyS7, might not be a printer or just not allow programming mode
Trying /dev/ttyS6
Could not connect to or enter programming mode on /dev/ttyS6, might not be a printer or just not allow programming mode
Trying /dev/ttyS5
Could not connect to or enter programming mode on /dev/ttyS5, might not be a printer or just not allow programming mode
Trying /dev/ttyS4
Could not connect to or enter programming mode on /dev/ttyS4, might not be a printer or just not allow programming mode
Trying /dev/ttyS3
Could not connect to or enter programming mode on /dev/ttyS3, might not be a printer or just not allow programming mode
Trying /dev/ttyS2
Could not connect to or enter programming mode on /dev/ttyS2, might not be a printer or just not allow programming mode
Trying /dev/ttyS1
Could not connect to or enter programming mode on /dev/ttyS1, might not be a printer or just not allow programming mode
Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
Leaving aside ttySxx, you notice that it does not recognize ttyUSB0 as a valid port.
The usb-serial chip is the classic FT232RL and the device that manages it is always ftdi_sio.
It seems that for some reason something goes wrong in detecting what is connected to the port rather than opening the port
... and ttyS0 through 9. Which it then tries to probe. Which fails and the probing fails with your printer too (since it relies on entering programming mode which doesn't always work and which I want to nuke due to this). If it only finds one port matching the pattern it won't probe but just try its luck with that and that usually works.
I also already explained the general issue with the current implementation and that I'm aware of them here
I had already read it and I'm sorry, I'm probably still asleep and I haven't noticed the ttyS0, ttyS1 present in the long list of tty devices.
