I have a printer with an Makerbase MKS SGEN-L V2.0-board. Its working since a year or more. I have set it up with a new Display, MKS 12864 Mini V3.0, also equipped with an SD-Reader.
When starting The Raspberry Pi 3, it is not working. The flashing light stops and it hangs. It boots when i unplug the USB-connection to the mainboard.
The boot works when i disable the SD-Card-Reader on the display.
I tried to alter some settings inside the Marlin-Firmware, its a Marlin Bugfix-Version.
browser.user_agent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/92.0.4515.159 Safari/537.36
connectivity.enabled: true
connectivity.online: true
env.hardware.cores: 4
env.hardware.freq: 1400
env.hardware.ram: 917016576
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.octopi_version: 0.17.0
env.python.pip: 20.2.3
env.python.version: 3.7.3
env.python.virtualenv: true
octoprint.safe_mode: false
octoprint.version: 1.6.1
Will try the following:
I will try to create a firmware using the release-version of Marlin 2.0.
I could not use my old version cause the display was not included.
Perhaps this helps.
In my opinion, the SD-Card connected via USB is blocking the Boot, looks as it tries to boot from the SD-card inside the display.
I have tried this, but i am not sure if i can start Opctopi in Safe Mode the way i need it... The problem only occurs when starting The Pi and the printer by switching them on at the same time.
It also happens when starting the Pi with printer switchedoff power source, cause the Printer gets its 5V via USB.
The pi does not boot until i disconnect the USB, and before doing so there is no Wifi-Access.
The Printer ist not taking power from the Pi. The board has a big powersource, their mains are in the same current-loop, the same power socket. As mentioned in the last post, this only happens when using the LCD-SD-card-slot, it does not happen when using the internal sd-card.
